  1. Mar 28, 2024 at 12:29 PM
    It's really a super freaking easy update, as long as you pop off the door cards so you can remove the hinge assembly.
  2. Mar 28, 2024 at 12:34 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    So metal ones are good just make sure to fully remove the whole latch assembly and do it on the bench to reduce the chance of breaking then?
  3. Mar 28, 2024 at 12:52 PM
    Yup. I took a short scrap piece of 2x4 and drilled a 1/2 hole in it as a receiver. Then used punches to tap the pin into the hole on the soft wood, keeping your eye on the position of the piece you're tapping out (i recommend tapping out one side, install one side of the replacement, then tap out the other and repeat. If you don't have a punch assortment, a 10 penny nail with the tip ground off should suffice. Hell, I can't remember if I tossed mine, but if I can find them and you want them, they're yours. I'll cover the ride if they're going to you, specifically.
    When I ordered replacement OEM assemblies, they arrived in beige b/c that's apparently the only color you can get, any color you order is beige now. So I had to punch pins out AGAIN to swap my charcoal covers onto the new OEM assemblies... Such tedious shit.
  4. Mar 28, 2024 at 3:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I just ziptied mine shut haha
  5. Mar 28, 2024 at 5:33 PM
    oscardog86
    oscardog86 New Member
    Southern California
    455h0le_dachshund likes this.
  6. Mar 28, 2024 at 5:35 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Replaced the 3 AC panel T10 Chinesium bulbs with......different Chinesium bulbs because I will never learn. Do y'all have a part number for the plastic bulb holder? My middle one is almost kaput and wiggles in the socket. Thanks.
  7. Mar 28, 2024 at 5:36 PM
    Does the bottom half just flop around when disco'd?
    What stops the swaybar from spinning around and potentially getting jammed up where you don't want it?
    I've genuinely never been able to fathom how you can QR swaybar links and not potentially create more problems.
    oscardog86[QUOTED] likes this.
  8. Mar 28, 2024 at 5:38 PM
    Oh and I'll save others the pain of navigating that Perry website. Apparently it doesn't like Chrome on Win10 very much. Here's 1GT products: https://www.perryparts.com/tundra-1st-gen
  9. Mar 28, 2024 at 5:42 PM
    oscardog86
    Southern California
    Yea that is definitely something i wondered about as well. I dont have a sway bar on the front anymore so not something im in the market for, but just wanted to share.
  10. Mar 28, 2024 at 5:44 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Fixed my broken wheel stud today. Got the stud fixed and broke the lugnut setting the stud into place . Then spent an hour trying to find a thin 6 point blah lugnut for my scs wheels. Super nice dude at a custom wheel shop got me an almost identical, but 7 point lug but threw in the wrench adapter all for $10. Threw him a $20 and called it done.
    in other news, the rear brakes look good!
    Voss, bmf4069, VR6T and 3 others like this.
  11. Mar 28, 2024 at 5:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty sure you can buy em at superbrightleds.com
    Tundra2 and artsr2002[QUOTED] like this.
  12. Mar 28, 2024 at 6:12 PM
    I would have sprayed a whole can of Brakleen on that and relubed the contact points. But I'm a freak sometimes.
  13. Mar 28, 2024 at 6:28 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I was doing a “roadside repair” I only had the jack for the spare tire, a tiny hammer and a few sockets. Believe me I would have like to clean all that crap out of there
  14. Mar 28, 2024 at 7:01 PM
    Road is the best place to do it - less stains on your driveway :rofl:
  15. Mar 28, 2024 at 7:11 PM
    artsr2002
    'Yonder
    Ordered. Thanks. I'll update if they fit correctly.
  16. Mar 28, 2024 at 7:24 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    quoted you in the other thread that you linked haha oops
  17. Mar 29, 2024 at 7:12 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    "the" deer? I mean there's been like 5 or 6 deer between you & pops & sequoia & Tundrii....
    "the deer" :boom:
  18. Mar 29, 2024 at 1:04 PM
    The replacement window seals for my topper finally came in from ARE. It's a completely different design and I was worried at first but the window seems to seal a lot better now. I can tell a difference when I close it. Especially the non broken window.
    The previous design tucked into this channel all the way around. This rides on top. I'll report back if it still leaks. Total cost for 25' was $100. Which sucks but sleeping in water sucks more. I have 4' left over. I'm guessing similar products can be found online for less. The part # is ARE-19019
    Side by side comparison. Old on left.
    Voss, bmf4069, BroHon and 5 others like this.
  19. Mar 29, 2024 at 1:18 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Tundra2[QUOTED] likes this.
  20. Mar 29, 2024 at 2:02 PM
    VR6T
  21. Mar 29, 2024 at 2:11 PM
    oscardog86
    Southern California
    des2mtn likes this.
  22. Mar 29, 2024 at 2:36 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Trans is out. Rear main replaced. Truth is, I don’t believe now that it was leaking. Yeah yeah, somewhere shifty posted that the rear main rarely leaks, but I was certain that it had been leaking for years. Of course, it was old and now it’s new. But I’m now convinced that the back side of the valve covers were leaking this whole time.
    upload_2024-3-29_16-33-3.jpgupload_2024-3-29_16-33-3.jpgupload_2024-3-29_16-33-3.jpgupload_2024-3-29_16-33-3.jpg
    upload_2024-3-29_16-36-19.jpgupload_2024-3-29_16-36-19.jpgupload_2024-3-29_16-36-19.jpg
    Voss, bmf4069, Filthyphil and 12 others like this.
  23. Mar 29, 2024 at 2:54 PM
    Oh you dirty tease you.....
    Voss, bmf4069, BroHon and 4 others like this.
  24. Mar 29, 2024 at 3:29 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    New oil leak unlocked, I just did the value cover gaskets about 16k miles ago. This is on the passenger side rear, Any help were I should be looking
  25. Mar 29, 2024 at 3:43 PM
    Is that power steering fluid?
    jerryallday[QUOTED] likes this.
  26. Mar 29, 2024 at 3:47 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    The reservoir is full at the moment, pretty sure it’s engine oil.
  27. Mar 29, 2024 at 3:48 PM
    Check the hose connections at the PS reservoir for giggles
  28. Mar 29, 2024 at 4:06 PM
    I'm always amazed at the things you guys pick up in the background of pictures. Things I never notice.
    bmf4069, BroHon, oscardog86 and 4 others like this.
  29. Mar 29, 2024 at 4:25 PM
    Tundra2 and VR6T[QUOTED] like this.
  30. Mar 29, 2024 at 4:30 PM
    Glad you got it sorted either way. I'm not one to be a dick and say stupid shit like "ITYS", I'm just glad you've got a clearer pic. I agree it's probably your VC, maybe half moon plugs or something. Just reminds me, I should probably check mine after doing my gaskets.
    I suspect this is the case for the last few people who claimed RMS was the source.
