Obd2 scan tool for transmission temp
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Mar 27, 2024.
  1. Mar 27, 2024 at 8:32 PM
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Does anyone have or know of a obd2 scan tool for gen3 tundra that shows tranny temp?
  2. Mar 27, 2024 at 8:51 PM
    Hella Krusty
    Hella Krusty New Member
  3. Mar 28, 2024 at 5:54 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    For other vehicles I use the OBD Link MX+. But for some reason they haven't updated to read out 22+ Tundras. Hopefully its imminent.
  4. Mar 28, 2024 at 6:44 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    ScanGage 2 and 3 can report trans fluid and engine oil temps.
  5. Mar 28, 2024 at 7:29 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  6. Mar 28, 2024 at 8:38 AM
    Oregona
    2022 TRD OR
    Nada
    Thanks!
  7. Mar 28, 2024 at 8:38 AM
    Oregona
    2022 TRD OR
    Nada
    Thank you
  8. Mar 28, 2024 at 10:51 AM
    PKFan
    2018 Inferno! DC SR5 4x4
  9. Mar 28, 2024 at 11:07 AM
    jctmundra
    Northern VT
    Careful with the dongle, do your research. I have had 3 different inexpensive dongles cause issues with a GM vehicle, appears to be spewing noise onto the canbus. Occasional connect was ok, it's when left on the port that issues arose.
  10. Mar 28, 2024 at 11:13 AM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    I have the Carista and still in the free month trial. I’ll check shortly and see if it gives trans temp. I have only used to to turn the fake engine sound off so far but didn’t mess around with it much after doing that. Will keep you posted.
    edit: just confirmed it will give you live trans temp. But you would need to open the app and check it.
    389 24/7[OP] likes this.
  11. Aug 7, 2024 at 1:01 PM
    BDATundra
    BDATundra New Member
    Bob
    2024 1794 Edition 4x4 (non-hybrid)
    None - yet...
    Just purchased Carista and downloaded app. I don’t see any options for trans temp? What am I doing wrong? Just wanted to bump an older thread here. Been reading a lot about types of dongles to get and what they show. Thanks.
  12. Aug 7, 2024 at 1:09 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    What kind of issues?
  13. Aug 7, 2024 at 1:27 PM
    Mossy Creek
    Mossy Creek New Member
    East Tennessee
    2024 WCP 1794
    I used my Carista to get the trans temp for a fluid change on my wife’s Lexus. During my one month original subscription, I also confirmed that it provides the trans temp for my 24 Tundra.
    BDATundra likes this.
  14. Aug 7, 2024 at 1:46 PM
    BDATundra
    Bob
    None - yet...
    Awesome. Thank you!!
  15. Aug 7, 2024 at 1:48 PM
    BDATundra
    Bob
    None - yet...
    Sorry, meant to ask. Which Carista do you have. It appears there are two types. One apparently provides more info?
  16. Aug 7, 2024 at 2:59 PM
    Mossy Creek
    East Tennessee
    2024 WCP 1794
    I have the Carista OBD module (the $39.99 module).
  17. Aug 7, 2024 at 3:42 PM
    BDATundra
    Bob
    None - yet...
    Thanks!
  18. Aug 10, 2024 at 5:23 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I got the $39 version about a month ago. I used the free mont subscriptions to tweak the seatbelts and AC.
    I downloaded an app, Car Scanner ELM OBD2 and it easily connects to the Carista. I have it set to Toyota OBD-II / EOBD ~2016 - Present CAN + Extra sensors and it reads something for Transmission temperature. It is a neat app, can log values while driving but it is a little clunky to figure out.
    I have not tinkered with the Carista App, but it did just tell me there was an update.
    BDATundra[QUOTED] likes this.
  19. Aug 11, 2024 at 7:49 AM
    BDATundra
    Bob
    None - yet...
    Just an update. Purchased Carista EVO, and man, you can change a lot of things, but you can also see tire pressure, trans temp, time engine has been running, coolant temp, and many other things. All through the Carista app. I never used another app. Made a few changes last night. AC change, seat belt chime for each seat, windows down with long press of remote. You can even change the HUD, but I'm still figuring that out. Thanks again everyone!
    303Gen3 likes this.
  20. Aug 11, 2024 at 8:01 AM
    DRP
    DRP Old Member
    Dave
    Do you have to keep paying for the Carista app though to be able to see trans temp etc.?
  21. Aug 11, 2024 at 8:10 AM
    BDATundra
    Bob
    None - yet...
    Yes, I believe you do. You'd have to pay to do anything with Carista after the free 30 days.
  22. Aug 11, 2024 at 9:20 AM
    DRP
    DRP Old Member
    Dave
    I did use Carista to make to changes, but like sandiegosteve, I've been using Car Scanner to get the trans temp and other parameters. I did pay a one time fee but if I remember correctly it was under $10. I think it worked for a few months for free but then had to pay. Not bad for the money though. Just FYI in case you don't want to pay the subscription.
  23. May 27, 2025 at 10:10 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Where do you find trans temp? I scrolled through all of the sensors in the list and nothing shows trans temp. Is there a different menu I am not seeing?
