  1. Mar 26, 2024 at 4:28 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Pretty good product for how cheap and easy it was huh?! Hopefully it lasts but if not it would be easy to do again every year or two.
  2. Mar 26, 2024 at 7:05 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Thanks, I will look into these.
  3. Mar 26, 2024 at 7:32 AM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    For the price and limited true amount of work that goes in to it, I am alright if it last two years. However, I am not letting them get that bad before reapplying it again. 2nd hand to me, and the lights were that way.
    blackoutt[QUOTED] likes this.
  4. Mar 26, 2024 at 9:09 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I did this stuff but obviously still have some work to do bc the dash speakers need another screw and recessed. I also gotta finish trimming and reinforcimg the plastic panels. These 6x9s still hit the glass rail inside door with Metra spacer kit so I cut up the black spacer to make it work. Previously I had hertz 5.25 component with tiny tweater in the dash but I blew the speakers from spraying cleaner in the grill I think. Anyways, I have a tiny in dash amp pushing the speakers so it sounds louder and not strained when turned up but I need to adjust eq still as well.
  5. Mar 26, 2024 at 9:17 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I also un-tinted my front windows bc I previously put 2 layers of film on it and it got blurry. The first layer was so easy but the second layer was harder. The worst part was the residue. That glue ONLY came off from a product called Rapid Remover that I learned about on a car wrap subreddit.
    I was planning to retint myself but being able to see out of my widows clearly again is new and exciting so I think I'm going to leave them un-tinted for awhile.
  6. Mar 27, 2024 at 11:55 AM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    I sure can. The rear suspenson consists of.
    3.0x16 king triple bypass shocks
    2.0x2 king bump stops
    Califab bump brackets
    Limit straps
    Camburg bed cage
    Camburg spring under kit
    Camburg shackles
    Deaver I96 spring under leaf pack.
    Camburg steel braided extended brake lines.
    I have a build thread that I keep up to date on my truck that you can check out in the 2nd gen build thread
  7. Mar 27, 2024 at 4:42 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Meso customs LED overhead lights - midnight edition
  8. Mar 28, 2024 at 7:59 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Well today was the first day we all really got to enjoy the changes made over the past couple weeks.
    We went to DD, no big deal.
  9. Mar 30, 2024 at 4:38 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Today I replaced my gas pedal with the 78110-0C012 one. Hopefully this solves the random throttle jumpiness!
  10. Mar 30, 2024 at 11:17 PM
    Optic15
    Optic15 New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    Thanks for the heads up lol, noticed after it sat for a few days the charge was low, makes sense now. Just got the items I need tor that, just waiting on the diode so looks like I’ll have to drive at least daily in the mean time.
    Randy Morton[QUOTED] likes this.
  11. Mar 31, 2024 at 7:27 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Finally picked up the truck after 2 months at the shop. Ended up needing a new front diff and they had to install a double cardan front drive shaft due to the extreme angle from my lift.
  12. Mar 31, 2024 at 7:41 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Hit a milestone yesterday.
  13. Mar 31, 2024 at 8:55 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    nice to be rolling again.
    Mountun Goat likes this.
  14. Apr 1, 2024 at 9:13 AM
    Kerplunk
    Kerplunk New Member
    22 MPH?
    Tripleconpanna and Ohannon7 like this.
  15. Apr 1, 2024 at 9:46 AM
    20GR8 Super
    Corey
    PNW Outskirts
    I mean it is white. Depending on who you ask that's about as fast as it will go.
  16. Apr 1, 2024 at 11:19 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Fresh oil change of 5w30 Mobile 1 and a new 27f Interstate battery.
    It supposed to be spring here, yet it snowed yesterday.:confused:
  17. Apr 2, 2024 at 5:32 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Removed my console safe and listed it on the market place
  18. Apr 4, 2024 at 11:52 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Anyone know how much weight the tailgate can handle realistically and how long I could let it sit there till I push the rock off into a gorilla cart?
    I bought a couple rocks to add to landscape and hopefully be able to use my RC crawlers on eventually. The big one is 689 lb.
    Peeeheeuuu and Mountun Goat like this.
  19. Apr 4, 2024 at 12:01 PM
    Optic15
    Optic15 New Member
    SF Bay Area
    Probably a while, I mean really it just depends on the age of your rear suspension in my opinion. Mainly cause with age and miles the insides of shocks degrade over time so that’s the only thing I could think of.
  20. Apr 4, 2024 at 12:04 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Ok I'm a dum dum sorry. I just used the Google and it said 500-2000 lbs. For some reason I thought the tailgate would snap with that much weight. TYVM
  21. Apr 4, 2024 at 12:04 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Why not just take the tailgate off when you go to unload that boulder?
  22. Apr 5, 2024 at 4:08 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I thought about it. I don't really want to bash the bumper though. I'm gonna do it this weekend when I have more hands and backs.
    My neighbor suggested going in reverse and then quickly driving forward. :eek:
    I think I'll back the truck to the grass, use a chop saw table I have to slide the rock on, and then off that table on to a garden pull cart. It's a stair step approach I guess.
    OldGuy03 and Wynnded like this.
  23. Apr 5, 2024 at 4:12 AM
    Danny3737
    This is still available in the marketplace. Lowered the price to $60. It’s in excellent condition with all the paper work and both keys or you can set your own code. Must be able to pick up. Takes less than 10 minutes to install
  24. Apr 5, 2024 at 6:11 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Your neighbor and I have a lot in common. But I think your approach is more thought out and a safer way to handle this.
    Ohannon7[QUOTED] likes this.
  25. Apr 5, 2024 at 7:24 AM
    SAGE63
    San Diego County
    how about using an engine puller to lift it then drive the truck away and then drop it in the garden pull cart
  26. Apr 6, 2024 at 5:26 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Done. Time to find some mud.
    Thanks for suggestions all!
    I ended up sliding rock onto a 2' square piece of plywood so it would slide off the tailgate and on to the wagon.
  27. Apr 6, 2024 at 7:04 AM
    Retroboy1989
    Northern Utah
    Sweet slipper.
  28. Apr 6, 2024 at 7:44 AM
    Ericsopa
    Ericsopa Old man and the sea
    Installed PowerStop Z36 rotors and pads @ 211K miles and adjusted the parking brake. Changed oil & filter, changed diff lube.
  29. Apr 6, 2024 at 1:03 PM
    Danny3737
    I lowered the price to $50 if anybody is local to me
  30. Apr 7, 2024 at 8:44 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Just made a similar trip again, 1 year later & with a working cruise control! 283k on the odometer this time.
    PhotoNerd, OldGuy03, omgboost and 2 others like this.
