Is regearing really this expensive$$$??
Discussion in 'Arizona' started by BillyB, Mar 27, 2024.
  1. Mar 27, 2024 at 9:13 AM
    BillyB
    BillyB [OP] New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I got an estimate at a local Tucson gear shop. Nearly $3500 parts and labor. 5.29 Nitro Gears. No locker(s).
    Is that just what to expect?
    Ctaylor76 likes this.
  2. Mar 27, 2024 at 9:16 AM
    AZBoatHauler
    So.Arizona
    @FrenchToasty
  3. Mar 27, 2024 at 9:17 AM
    BillyB
    Billy
    AZ
    I think he took his up to the dude in Prescott, didn't he?
  4. Mar 27, 2024 at 9:18 AM
    AZBoatHauler
    So.Arizona
    Yes - pulled the diffs and dropped them off and picked them up and put them back in.
    BillyB[QUOTED][OP] and des2mtn like this.
  5. Mar 27, 2024 at 9:18 AM
    2mchfun
    Actually sounds pretty reasonable IMO.
    Mater and BillyB[OP] like this.
  6. Mar 27, 2024 at 9:20 AM
    BillyB
    Billy
    AZ
    Yeah, that's beyond my capabilities, haha. And couldn't have that much downtime.
  7. Mar 27, 2024 at 9:22 AM
    BillyB
    Billy
    AZ
    It was about a grand more than I was expecting. But, I'm getting old, haha.
    2mchfun[QUOTED] likes this.
  8. Mar 27, 2024 at 9:28 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I was planning on buying a new front clamshell assembly and rear 3rd member housing, having it all built out and swap em in myself…but uber low priority
    BillyB[QUOTED][OP] likes this.
  9. Mar 27, 2024 at 9:29 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds about right. ~$1000 in labor per diff, plus cost of parts. And don't forget if you do want a locker or lsd later then you're paying that labor over again since they're taking the diff apart, and decent chance they have to set it up again.
  10. Mar 27, 2024 at 9:31 AM
    BillyB
    Billy
    AZ
    Are you still on stock gearing?
    BiggHertz[QUOTED] likes this.
  11. Mar 27, 2024 at 9:34 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You could get in on a group buy out here at premier west. There’s like a new one every other month it seems. Would save you a grand or so even with REM polish and will be in/out same day. But some things are too good to be true and not worth cutting corners..
    BillyB[OP] likes this.
  12. Mar 27, 2024 at 9:43 AM
    BillyB
    Billy
    AZ
    I did want to add an e-locker, but we'll see.
    Mater and AZBoatHauler like this.
  13. Mar 27, 2024 at 9:49 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I saved a ton in buying gears off someone who didn't install. My mechanic also did them "on the side" as in not officially through his shop.
  14. Mar 27, 2024 at 9:52 AM
    AZBoatHauler
    So.Arizona
    I wouldn’t do gears without putting one in the rear.
  15. Mar 27, 2024 at 9:54 AM
    That’s not a bad price at all with parts and labor. Did you go to Lloyd’s? I definitely think he was a little bit cheaper than going through Zuke but I did what I did
    FirstGenVol, Just_Josh and Mater like this.
  16. Mar 27, 2024 at 9:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    PomDad, Black Wolf, biebs96 and 7 others like this.
  17. Mar 27, 2024 at 9:57 AM
    BillyB
    Billy
    AZ
    Tucson Differential. I didn't go there, just emailed with them. Rated really high.
  18. Mar 27, 2024 at 10:01 AM
    BillyB
    Billy
    AZ
    That's my logic, too. Maybe later this year I'll regear. I bought a transmission cooler to help keep the temps under control. Will be going to nearly 36" tires next week. I saw temps in the old truck getting near 250* with just 295/70/18 going up Mt. Lemmon. I'm guessing the bigger tires will be worse.
  19. Mar 27, 2024 at 10:01 AM
    Check with Lloyd’s, it may be cheaper
  20. Mar 27, 2024 at 10:01 AM
    BillyB
    Billy
    AZ
    Where's that?
    Nevermind, I found it
  21. Mar 27, 2024 at 10:10 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Were you in 4hi? Granted I’m lucky and have a trans cooler from the factory, but that seems really toasty for Mt Lemmon. I try and flip to 4lo if I’m doing any extended climbs that need 4wd so I don’t kill the trans too
  22. Mar 27, 2024 at 10:16 AM
    BillyB
    Billy
    AZ
    This was 2wd up the front side. I think it got up to like 246* or something. I don't remember what time of the year. Going up the back side I also got similar results, but don't remember specifics.
    I generally do 4low on anything that requires going slower. I really don't think Toyota should have eliminated the tranny cooler, that's for sure.
    I haven't monitored anything in the new truck, yet. I'll probably start tomorrow.
    TRDFerguson[QUOTED] likes this.
  23. Mar 27, 2024 at 10:19 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That's mostly what I did. I bought a used front diff from LKQ and dropped it with Zuk for the locker install at his place in Prescott. Then pulled the 3rd before vacation and dropped it with him on the way out of town.
  24. Mar 27, 2024 at 10:21 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    To replace front and rear with nitro 5.29s and ARB rear locker with pump and plumb and wiring also you need a switch panel to run it. Yeah it’s a little expensive. I think I paid about 6 total for mine with full install. But my setup was more of a full custom job with the wiring and the duel compressor setup that required a custom bracket over the fuse box.
    to just do the gears it’s not that bad, but if your going to do gears no reason why you shouldn’t at least add a rear locker.
    I think that if you’re already running big tires and lift it’s nice to have on board air anywhere you go.
  25. Mar 27, 2024 at 10:25 AM
    BillyB
    Billy
    AZ
    I'll probably do an elocker, if I do anything. Heard of too many issues with the air lockers. Not the lockers themselves, but seals, hoses, etc.
    I have a portable compressor. It allows me to take it in any vehicle.
  26. Mar 27, 2024 at 10:25 AM
    AZBoatHauler
    So.Arizona
    No air leakers allowed.
    :spy:
    FrenchToasty, TRDFerguson and des2mtn like this.
  27. Mar 27, 2024 at 10:26 AM
    VWTim
    Corvallis, OR
    If you're not spending a lot of time on rocks, I'd consider a Powertrax Grip Pro LSD also. Day to day and desert driving is awesome with it!
    bflooks, snivilous, Mdl and 1 other person like this.
  28. Mar 27, 2024 at 10:26 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Yup stock gears...to this day still don't feel that I "need" it...though a true rear LSD sounds like a mighty fine addition.
    I'm just gonna wait till a gear set grenades and deal with it all then....
  29. Mar 27, 2024 at 10:29 AM
    BillyB
    Billy
    AZ
    That's good to know, because you're on bigger tires than I.
  30. Mar 27, 2024 at 10:29 AM
    Ctaylor76
    Chaz
    Houston
    the problem with e lockers is they don’t engage that fast, the air locker locks it almost instantly from what I’ve been told.
