Parking Brake Adjustment
Discussion in '2.5 Gen Tundras (2014-2021)' started by millerstone, Sep 12, 2017.
  1. Sep 12, 2017 at 11:36 AM
    millerstone
    millerstone [OP] New Member
    2017 TRD Pro DC Cement
    Hi guys,
    I have a 2017 Tundra and the parking brake has been lackluster at best. When it was brand new I had to push the pedal nearly all the way to get it to hold on a hill. Now it's just completely cocked and rolls even at full push. I used to be a bike mechanic so I'm aware that cables settle in and stretch over time, would I be correct in assuming I just need to take the slack out of the parking brake cable? Are the parking brake shoes normally adjusted correctly from the factory or will I have to do a complete overhaul? I've never driven with the e-brake on, I'm almost certain it's just the new cable stretching.
    Thanks in advance.
  2. Sep 12, 2017 at 1:18 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    not sure this is related, but owners manual says:
    ■Drum-in-disc type parking brake system
    Your vehicle has a drum-in-disc type parking brake system. This type of brake
    system needs bedding-down of the brake shoes periodically or whenever the
    parking brake shoes and/or drum are replaced. Have your Toyota dealer perform
    the bedding down operation.
    millerstone[OP] likes this.
  3. Sep 12, 2017 at 1:20 PM
    RussellVaughan
    Houston
    How many clicks do you hear when you press the brake down all the way?
    Also from owners manual:
    Parking brake pedal travel*2 6 — 9 clicks
    Bear likes this.
  4. Sep 12, 2017 at 1:35 PM
    RussellVaughan
    Houston
    From the factory service manual...
    Noob here, Joe333x, LS3 and 3 others like this.
  5. Sep 12, 2017 at 2:17 PM
    millerstone
    Thanks for the reply. I'll check the clicks when I'm out at my truck. I know for a fact that I use every last one of them though, not sure where it tops out.
  6. Sep 12, 2017 at 5:47 PM
    millerstone
    I get a full 15 clicks. Still rolls on a steep hill.
  7. Sep 13, 2017 at 9:31 AM
    RussellVaughan
    Houston
    if you do the adjustment, consider writing a walkthru and posting it for us. i'd like to do this as well, but man...those instructions in the service manual lol
  8. Sep 13, 2017 at 10:47 AM
    millerstone
    I think I'm just going to take the slack out of the cable and see where I stand. I can't imagine the shoes are out of adjustment this soon in, makes more sense that the cable stretched. If my truck weren't so new I'd probably give the whole adjustment a go though. I'll post back later today after I do it with my results.
  9. Sep 13, 2017 at 2:30 PM
    millerstone
    LS3, FirstGenTundra, TTund16 and 3 others like this.
  10. Sep 13, 2017 at 2:48 PM
    This is so easy to do, you got this...trust me.
  11. Sep 13, 2017 at 3:58 PM
    RussellVaughan
    Houston
    Should cover it under warranty. Don't pay anything for this
  12. Sep 13, 2017 at 4:03 PM
    millerstone
    I definitely won't. My dealership has treated me pretty well so far. I'd try it myself but I live in an apartment and space is limited, plus I don't have a good jack or jack stands. If anyone in SLC reads this and wants to let me use their space and stuff let me know!
  13. Sep 13, 2017 at 4:29 PM
    Yeah, I just noticed you have a 17'. Dealership time!!!
  14. Jul 15, 2018 at 12:42 PM
    TheWoods
    TheWoods New Member
    2010 Tundra TRD 5.7
    Great video above. just recently went to a boat ramp that was steeper than my usual one and found out I was not going to trust the truck to stay with just tranny lock. Never truly noticed before this. Just assumed normal wear and tear. Plus I don't want a You Tube video of my truck and boat in the water.
    classiccat likes this.
  15. Jul 15, 2018 at 1:27 PM
    tacomawv
    tacomawv New Member
    Richard
    I have added this to my list of things to do.
  16. Jul 15, 2018 at 11:20 PM
    TheWoods
    TheWoods New Member
    2010 Tundra TRD 5.7
    looked and found this on the adjuster. Seized and cable slack. Thought at first maybe broken cable but just never adjusted. Hope to do adjustement per video tomorrow.
  17. Jul 23, 2019 at 1:19 PM
    Rustlewood2017
    Rustlewood2017 New Member
    I've got my parking brake shoved all the way to the floor on my 2017 Tundra (with less than 6,000 miles). The parking brake will not hold the truck on my dad's driveway or a nearby boat launch. So, took it to the dealer to have it adjusted under warranty. The dealer refused to adjust it, because they said it's already within the Toyota manufacturer's specification. This is not safe!
  18. Jul 24, 2019 at 12:16 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    How did you end performing the adjustment?
  19. Apr 28, 2020 at 8:54 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I’m at 16!!
    looks like I’m going to spend a bit of time adjusting some brakes
  20. Apr 28, 2020 at 8:57 AM
    timsp8
    NY
    It’s not hard to do. There is a hole in the rotor to turn the star bolt thing. Should be able to turn it with a narrow flat head screwdriver. But it is much easier to take the rotor off to get to it.
  21. Apr 28, 2020 at 9:43 AM
    AZBoatHauler
    So.Arizona
    I had this issue with my truck when new. The dealer adjuster the parking brake under warranty when I only had a few thousand miles on the truck. It is the only warranty item I’ve had.
    Toyotoholic likes this.
  22. Apr 28, 2020 at 10:14 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    X2∆∆∆
    Had them do it at the service interval... No charge.
    AZBoatHauler[QUOTED] likes this.
  23. May 18, 2020 at 3:57 PM
    nj636
    nj636 New Member
    NJ
    2017 Super White TRD
    Guy’s, there’s no need to be messing with the star wheel on the drum brake trucks... that is meant for adjusting the brakes themselves.
    My ‘17 with rear disc has an adjuster by the driver side catalytic converter - just under the driver side door. I would imagine the older trucks with drum brakes have the same adjuster. My 2005 & 2006 Tacoma’s with rear drum brakes had a similar adjuster that was under the center console.
    Like the others are complaining - since new, my 2017 Off Road has had a weak parking brake and i’ve just lived with it. Now with 77k miles I decided to get under there & make an adjustment. I found the adjuster located on the drivers side by the catalytic converter, basically right below the driver seat along the frame rail.
    The adjuster is a 12mm nut with a 12mm lock nut. The threaded portion of the cable was not rusted, but grimey enough that I had to hold the end of it with vise grips while making the first few turns on the adjuster, after that I could turn the adjuster by hand.
    You can see how many turns I had to make to get the parking brake firm with about 6-8 clicks of the pedal.
    Easy task, took a total of 10 minutes.
    AFAB1CA7-E901-439B-A3E4-ACC056344696.jpg 3FF16615-D1EB-4DDE-8CEE-F6F5302756D9.jpg BD43C856-22BE-4C70-8B53-4145BEE89259.jpg 06B4ABF9-3668-405E-A1AE-2FBF1490449B.jpg
  24. May 20, 2020 at 3:05 PM
    TTund16
    TTund16 New Member
    Good to know!
    Thanks
    nj636[QUOTED] likes this.
  25. May 20, 2020 at 4:00 PM
    mightyowl
    mightyowl New Member
    cool info
  26. Jan 10, 2022 at 5:13 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I am way late to this party but great thread. Very informative video. I'll be doing this to my 2014 Tundra next time I change the oil and rotate the tires. I bought the truck used in 2016 with 11k miles and have never been impressed with the parking brake. We recently bought a 2018 Sienna AWD for my wife and the parking brake holds the van fast even when put in drive and I and try to move. I was so impressed with its parking brake that it got me thinking about trying to figure out why my trucks brake isn't similar. Thanks for posting!
    BravoDeltaRomeo likes this.
  27. Jan 11, 2022 at 3:50 AM
    Retired...finally
    I see Toyota dealers still haven't been checking the parking brakes during dealer prep. First day of ownership had me under mine with two 12mm wrenches and anti seize compound.
  28. Jan 11, 2022 at 6:18 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Parking brake was set kind of weak on both my '18 and '21 Tundras. Been wondering about this.
    On another note, I wish they'd use a parking brake setup like the 2nd gen manual transmission Tacomas. The straight pull back T-handle on the lower dash, I liked that setup a lot. I hate the toggle pedal for a parking brake; it's stupid and kind of dangerous. More than once I've bumped that pedal on the way in or out and unintentionally released it.
  29. Dec 2, 2022 at 1:25 PM
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    Hey Guys, thanks for this post.... I had some free play in the ebrake pedal on my 2015 and sure enough I could totally move this cable adjuster by hand it was so loose. 2 - 12mm wrenches and alot of luck it wasn't rusted up. Loosened jam nut a few licks of anti seize on the threaded assembly and just snugged it up. Beautiful now. I have a feeling when my brakes were done at the stealership 1 yr ago there was no attention paid to this adjuster and the amount of play in pedal. Anyhow, good to go. I really appreciate the help of these posts. Cheers
    coldcanuk and HD59019 like this.
  30. Jan 30, 2023 at 12:34 PM
    olshaggy
    olshaggy New Member
    Andrew
    USA
    2016 regular cab long bed 4WD SR
    Can anyone clarify where we should be adjusting the parking brake cable? I see the adjuster nuts pictured above (post #23) that sit next to the driver side catalytic converter, but I also found the ones depicted in both the factory service manual (post #4) and the Haynes manual, located just above the foot pedal in the under-dash panel. Which set should I be adjusting?
    In case some additional context helps, my truck's a 2016 regular cab, and the parking brake is so soft that at 9 clicks, it rolls on even a slight incline.
