O2 Sensor/ECU Question
Discussion in '1st Gen Tundras (2000-2006)' started by f-edtruckgotmemessedup00, Mar 26, 2024.
  1. Mar 26, 2024 at 5:59 AM
    f-edtruckgotmemessedup00 [OP] New Member
    Eamon
    2000 RCLB V8 4WD SR5
    If the O2 sensor detects a problem, does the ECU put the fuel/air mix into a “safe” mode when it runs rich? Less gas mileage but ” no” damage to engine?
  2. Mar 26, 2024 at 6:01 AM
    shifty` Ten EV 12's so you know I raise hell
  3. Mar 26, 2024 at 6:07 AM
    Eamon
    I guess so, it seemed like a more general question.
  4. Mar 26, 2024 at 7:52 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    In my experience, no. The ECU does not default to 'safe mode' when an o2 sensor throws a code. When o2 sensors start to fail, they usually start reporting a lean condition (low voltage), so the ECU increases the amount of fuel (as can be seen in the fuel trims) which hurts your fuel economy. If you unplug the o2 sensors (<- not recommended!) the ECU will receive no voltage reading from the o2 sensors and you will see an increase in the fuel trims.
