B&M Trans Pan
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ctaylor76, Mar 20, 2024.
  1. Mar 20, 2024 at 12:17 PM
    Ctaylor76
    Ctaylor76 [OP] New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Was really beefy , but just kind of a heads up if you install this pan mine had little bit of overspray over the check plug so had to clean that out little bit before install but overall pretty sweet setup.
  2. Mar 20, 2024 at 12:22 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Nice! I am thinking about this as well. This pan uses the OE Toyota gasket still correct?
    Ctaylor76[OP] likes this.
  3. Mar 20, 2024 at 12:22 PM
    2mchfun
    Are you monitoring the pan oil temps? Have before and after temps?
  4. Mar 20, 2024 at 12:31 PM
    Ctaylor76
    Chaz
    Houston
    yeah so the pan overall holds heat very well. So the best way I can explain it, the heat will rise and basically go right back down to that 190-200 almost immediately. I have rear gearing done and a strong tune as well so the heat is still there without the cooler installed but since the capacity is so much higher I’ve noticed it does drop back down very very quickly. 10-15 degree drop maybe overall, but in terms of cooling I would say the pans more effective at taking the heat away much quicker then the stock pan 100%. If that makes sense?
  5. Mar 20, 2024 at 12:34 PM
    Ctaylor76
    Chaz
    Houston
    yes sir, I replaced both gasket and filter.
  6. Mar 20, 2024 at 12:41 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Would this pan prevent the use of the RCI trans skid plate?
  7. Mar 20, 2024 at 12:43 PM
    Ctaylor76
    Chaz
    Houston
    no I don’t think so it’s still tucked in under the frame. If that skid plate sits flush you should be good. Flush as in like as long as the inside of the skid plate doesn’t protrude upwards.
  8. Mar 20, 2024 at 12:46 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    How much does this increase the fluid capacity?
    Xcumminsguy and Ctaylor76[OP] like this.
  9. Mar 20, 2024 at 12:48 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    +3.5Q I believe...
    Henry1jg and Ctaylor76[OP] like this.
  10. Mar 20, 2024 at 12:49 PM
    Ctaylor76
    Chaz
    Houston
    3.5 quarts
  11. Mar 20, 2024 at 12:49 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    :thumbsup:
    Ctaylor76[QUOTED][OP] likes this.
  12. Mar 20, 2024 at 1:02 PM
    Ctaylor76
    Chaz
    Houston
    I think in general the cooler might be a better upgrade if your really doing some serious payload/towing or overland type trucking 100% and I still might do it later on. However, if you’re just doing some basic off roading and not really staying in it like all the time the pan feels like the way to go. Just from my observations, I could give some more data in a few days with HP Tuners, I do have some scan logs from
    Before of the temps hitting 239 without the pan.
  13. Mar 26, 2024 at 4:49 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    what are you using to measure the temp?
  14. Mar 26, 2024 at 5:30 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    500.00+ for a tranny pan? Damn, that’s almost the diy cost for adding a cooler.
  15. Mar 26, 2024 at 5:35 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah but you get a sweet B&M logo on it
  16. Mar 26, 2024 at 5:46 AM
    Xcumminsguy
    NY
    Well, there is that!
  17. Mar 26, 2024 at 6:27 AM
    Ctaylor76
    Chaz
    Houston
    HP Tuners
  18. Mar 26, 2024 at 6:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nope we’ve got this pan on the old man’s rig no clearance issues with the RCI skids
  19. Mar 26, 2024 at 6:37 AM
    Ctaylor76
    Chaz
    Houston
    I actually have the genie transmission cooler kit just never installed it. Wanted to see how the pan was overall and I was pretty shocked at the results. To be honest I bought it for that sweet logo that no one can see
  20. Mar 26, 2024 at 6:55 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I get that. I wish our trucks had a rear diff cover that was removable. Solely so I could have a cool ARB one like other trucks do lol.
  21. Mar 26, 2024 at 6:59 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes.
  22. Mar 26, 2024 at 7:06 AM
    Ctaylor76
    Chaz
    Houston
    Yeah I was actually looking for a cover for awhile but then found out the tundras rear differential is actually sealed from the outside!
    300BLK[QUOTED] likes this.
  23. Mar 26, 2024 at 8:27 AM
    SD Surfer
    Bruce
    So Cal
    It's gotta' add some HP!
  24. Mar 26, 2024 at 9:03 AM
    2mchfun
    Make a custom adapter to go over it so you can make it happen. You might even be able to sell a few if you come up with a decent design. People buy all kinds of auto accessories just cuz they look cool.
  25. Mar 26, 2024 at 9:11 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
  26. Mar 26, 2024 at 9:14 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Henry1jg, Ctaylor76[OP] and reywcms like this.
  27. Mar 26, 2024 at 9:16 AM
    Ctaylor76
    Chaz
    Houston
    that pans not OEM. Doesn’t retain the stock gasket. Even though I am sure it’s just as good as the B&M pan.
  28. Mar 26, 2024 at 10:17 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The B&M pan is a good part. Not knocking it. My post was in reference to the cost as the PML plain finish pan is a little cheaper. I think the higher capacity pans are a great upgrade.
  29. Mar 26, 2024 at 10:26 AM
    Ctaylor76
    Chaz
    Houston
    all good yeah, it’s very difficult to measure the major differences between both pans because they both seem to be made out of the same material, same capacity size I just didn’t like you had to use the gasket they provided. As far as the fins inside the pan, that could potentially yield better results but for them to say our pan doesn’t slosh around is pretty ridiculous.
    Henry1jg and dt325ic[QUOTED] like this.
  30. Mar 26, 2024 at 12:48 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
