  1. Mar 22, 2024 at 4:02 PM
    #6031
    GrandPooPaw
    GrandPooPaw New Member
    2024 Platinum
    looking and researching
    Looking good, I am down to this and the BAK Revolver X4s. Still can’t make up my mind. Any issues with losing the bed room?
  2. Mar 22, 2024 at 4:07 PM
    #6032
    lapoolboy
    lapoolboy New Member
    There is no comparison between a Retrax and a BAK! Anything BAK is garbage.
    Hank Hill likes this.
  3. Mar 22, 2024 at 4:23 PM
    #6033
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Toyota Tundra LED Tailgate Light Bar PK539-34N00. I saw this listed for $525 CDN which seems a bit pricey for these but the also have a back up light in the middle and a wiring harness.
    Has anyone spent the bucks and put a set of these in?
  4. Mar 22, 2024 at 5:11 PM
    #6034
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    A tundra in front of me had it yesterday. It looks good quality. Not my style though.
    Tundrastruck91 likes this.
  5. Mar 22, 2024 at 5:25 PM
    #6035
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I normally wouldn’t consider this but I have covered my 3rd brake light with my tent.
    I might try to add a light to the back of the tent.
  6. Mar 22, 2024 at 6:28 PM
    #6036
    Regiuleather
    Regiuleather New Member
    Reg
    2024 SR5 TRD Sport, Advanced Tech Pkg, grey
    KBS roll-on bed liner
    Received a roll of 3M paint protection film, and a gallon of KBS bed liner. Weather did not permit but next week I’ll be applying the ppf to roof and paint the bed (mine comes naked, no lining).
  7. Mar 22, 2024 at 7:00 PM
    #6037
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    100% agree. Had 2 bak covers just take a shit in less than a year. Never again
  8. Mar 23, 2024 at 6:29 AM
    #6038
    omglas3r
    omglas3r Member
    im also in the same boat. I wonder if the opposing end of the plug is there and if you could just add a pin to where the blue wire would be to get power.
  9. Mar 23, 2024 at 7:30 AM
    #6039
    Riverfisher
    Riverfisher New Member
    2022 Double cab TRD Off Road
    I’ve thought about it but the vast majority of my use of the radio is communicating with others on GMRS or FRS.
  10. Mar 23, 2024 at 11:09 AM
    #6040
    BigElliott
    BigElliott New Member
    2023 Tundra Platinum
    Quick question….were the part numbers you gave me for the matching black air vents?? And if so do you have part numbers for all of them so they are all black or was that what you gave me??
  11. Mar 23, 2024 at 7:11 PM
    #6041
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    No the three part numbers were the garnish and 2 small matching pieces left and near driver :) the textured silverish.
  12. Mar 24, 2024 at 8:28 AM
    #6042
    Big Baker
    Big Baker New Member
    2022 Tundra Limited 2WD in Blueprint
    I need more light when backing up. What model are your lights and where did you get them?
    Did they just wire into the tail lights? How did you wire them?
  13. Mar 24, 2024 at 8:41 AM
    #6043
    Ipaddick
    Ipaddick New Member
    Canada
    They’re ss2 from diode dynamics. They also have a no cut option which I have. It’s a 7pin harness so plug and play and simple.
    Riverfisher likes this.
  14. Mar 24, 2024 at 9:18 AM
    #6044
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    Found some TRD Boards on marketplace and im stoked, never thought id be able to grab em lol
    ElectricMan likes this.
  15. Mar 24, 2024 at 9:52 AM
    #6045
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    kirkb likes this.
  16. Mar 24, 2024 at 2:24 PM
    #6046
    Boomer08
    Boomer08 New Member
    2024 white platinum I Force Max
    Shouldn’t have any issues. The plastic piece only deploys when driving 35 mph and retracts at 27 mph. There is a video of someone getting pulled that has these tow hooks
  17. Mar 24, 2024 at 4:44 PM
    #6047
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Finally swapped in AJT cup holder and their trim piece to ditch the piano black before it gets any more scratches. Also wired in my MagSafe chargers using a jump harness I made to tie into the cigarette lighter. No more cables or slow charging like the Qi and others out currently.
  18. Mar 24, 2024 at 6:56 PM
    #6048
    Regiuleather
    Reg
    Question about the TRD skid plate, what's the size of the last two bolts toward the rear?
  19. Mar 24, 2024 at 7:35 PM
    #6049
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Finally made some changes to my truck! Installed the rear seat USB plugs and added billet tie downs to the bed.
    I also got the TRD anti sway bar and skid plate but waiting to put them on with suspension.
    FlyinBrian, Mr Rick and omglas3r like this.
  20. Mar 24, 2024 at 7:58 PM
    #6050
    Riverfisher
    Ditto to what @Ipaddick said “They’re ss2 from diode dynamics. They also have a no cut option which I have. It’s a 7pin harness so plug and play and simple.”.
    I installed the flush mount kit. It came with a switch, relay, and wiring harness. They do have a kit that mounts to the rear of the bumper and plug directly into the hitch harness. I liked the look of the flush mounts and, given that I’ve nearly torn my rear bumper off while exploring, I’m a bit overly sensitive to anything that makes my departure angle any worse.
  21. Mar 24, 2024 at 8:02 PM
    #6051
    Riverfisher
  22. Mar 24, 2024 at 8:22 PM
    #6052
    eddiefromcali
    Eddie
    100% Stock
    Do not get the hitch pod..it sucks. I sold it and got the baja designs pod and it's way brighter. Those dual lights are probably brighter than any pod, should work well for everyone
    Troyboy84 and Baja Designs like this.
  23. Mar 25, 2024 at 12:15 PM
    #6053
    Regiuleather
    Reg
    Installed the EGR, aka Toyota, bug deflector. Cause we are all bugs right. This one for Tundra is more wobbly than the equivalent for ForeRunner, so the seven (not just four but seven!) rubber cones are actually necessary.
    Black widow TRD likes this.
  24. Mar 25, 2024 at 6:12 PM
    #6054
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    You added the plug in the bed too?
  25. Mar 25, 2024 at 6:38 PM
    #6055
    az 3rdGen
    Arizona
    nope. The truck came with that.. I just added the tie down.
  26. Mar 26, 2024 at 6:26 AM
    #6056
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Added some bed features.
  27. Mar 26, 2024 at 9:41 AM
    #6057
    Bayoutundra
    Bayoutundra New Member
    2023 Lunar Rock Limited TRD Off Road
    2.25" icon spacer with Cornfed 1" rear spacer, 35x11.50 Wildpeak AT3 on stock TRD wheels. TRD Pro grill swap, protech cluster radio and bezel screen protectors.
    Added Mountain Hatch tailgate panel with Gator Skyn matting
  28. Mar 26, 2024 at 1:24 PM
    #6058
    LagoCJ
    LagoCJ New Member
    New truck needs new toys. Just got my Terra TRD Pro and LOVE it...of course, can't leave it alone, even though it has almost everything you could need. I chose to get the Retrax EQ tonneau and did a self-install. First, the end result is amazing and very happy with how it turned out. Second, Retrax documentation is BAD (F***ing BAD). There were about 20 steps left out of the install guide, right at the start where you need to 'make sure that...' and 'to keep from having ...., do ....', there is a jump from 'unpack the parts' to 'have a friend help you lift it on your truck'. There were also errors in their install videos, including a plug location that was completely wrong and almost had me making irreversible modifications to an electronics connector when they said 'unplug the top most black connector and replace it with the female end of the T cable'. Turns out, it's the BOTTOM most black connector that needs to be unplugged and replaced.
    Be super careful folks...enjoy your trucks, enjoy your toys, and make sure to share your help with others, as well as make sure the gear manufacturers keep their instructions and support up to date and correct!!
  29. Mar 26, 2024 at 3:56 PM
    #6059
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    OK, I'll bite. What did you put in the box of the truck?
    cartage1 likes this.
  30. Mar 26, 2024 at 3:56 PM
    #6060
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Couple hogs..
