Drivetrain throwing grease
Discussion in '1st Gen Tundras (2000-2006)' started by BlueGarden, Mar 24, 2024.
  1. Mar 24, 2024 at 6:09 PM
    BlueGarden
    BlueGarden [OP] New Member
    Paducah, KY
    2002 Tundra Limited 4x4 4.7L
    2002 tundra limited ac 4x4.
    Is it normal for these driveshaft parts to throw grease? I'm having vibrations when the truck is moving at just about any speed, and I'm trying to look for any obvious parts that need to be replaced.
    Am I out of luck repairing the double cardan joint u-joints if it is bad? Will I just have to replace the entire driveshaft? From what I'm reading that seems to be the case.
    Thanks!
  2. Mar 24, 2024 at 6:53 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    They generally throw some grease just after they are greased. That stuff looks pretty old and crusty. When was the last time they were greased? Recommended to grease every 5K-10K. If they're dry you could get some vibrations and noise.
    BlueGarden[OP] likes this.
  3. Mar 24, 2024 at 6:55 PM
    koditten
    Kirk
    Midland of the Mitten
    Mine looks like that. I have replaced u joints on occasion, so mine now have grease zerks.
    I had a vibration I chased. It was a wheel bearing.
  4. Mar 24, 2024 at 7:05 PM
    shifty` Ten EV 12's so you know I raise hell
    Vibration that happens consistently at basically all speeds is highly unlikely to be anything in the driveline. You need to be looking at your wheels and brakes. Especially if the vibration doesn’t increase in frequency with RPMs. Does the vibration stop or reduce when you tap the brakes?
  5. Mar 24, 2024 at 7:41 PM
    BlueGarden
    Paducah, KY
    Unsure of when they were greased. Just bought the truck a few months ago. I will try to put some grease in them.
  6. Mar 24, 2024 at 7:48 PM
    BlueGarden
    Paducah, KY
    I haven't noticed if the vibration changes when applying brakes. I will check that tomorrow. It does seem to get worse at higher speeds.
    I have suspected u-joints and/or carrier bearing being bad since I get a weird noise when I take off quickly from a dead stop too. No jerking or anything, just a weird grinding type noise, and only when I take off somewhat quickly.
  7. Mar 25, 2024 at 5:52 AM
    That sounds like pinion bearing to me. Any whining at all?
  8. Mar 25, 2024 at 5:54 AM
    And I don't know how common bad pinion bearing is for 1GT, but this is one of a couple of examples of how to check. Again, I'll reiterate: I don't know if this specifically applies to 1GT or not, but the "grinding at takeoff" combined with vibration throughout speed range would have me suspecting pinion.
    https://www.youtube.com/watch?v=RfGQjhIvAFo
    BlueGarden[OP], ATBAV8 and koditten like this.
  9. Mar 25, 2024 at 2:23 PM
    BlueGarden
    Paducah, KY
    So I payed close attention while driving today, and the vibration does seem to happen above 50 mph, and it stops vibrating when I let off of the gas and the engine is not under a load while at the same speeds above. I'll get out there and feel for any play like shown in your video Shifty.
  10. Mar 25, 2024 at 2:23 PM
    BlueGarden
    Paducah, KY
    No whining, just vibration.
  11. Mar 25, 2024 at 2:53 PM
    U-joints.
    87warrior and FrenchToasty like this.
  12. Mar 25, 2024 at 4:36 PM
    BlueGarden
    Paducah, KY
    So does that mean the double cardan fall in with those as well? And does the entire driveshaft have to be replaced IF the u joints in the cardan are bad? I can't find a source for the cardans anywhere? There's more to the cardan than just u joints from what I've read... A ball joint type connection between them.
  13. Mar 25, 2024 at 4:59 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Yes, there are no double cardan parts. But you might not need them. Try replacing just the 2 u-joints and you may be surprised.
    87warrior and shifty` like this.
  14. Mar 25, 2024 at 6:37 PM
    koditten
    Kirk
    I've never had a Double C u joint fail. It's always the joint at the pinion.
    I've only had 1 carrier bearing go bad in 25 years. The bearing wasn't bad, just the rubber bushing around the cb. Even then the only time I noticed it was during aggressive shift changes.
    I think your issue is down stream.
    Pinion bearing or wheel bearing.
  15. Mar 25, 2024 at 6:45 PM
    I don’t disagree on pinion bearing because of the grinding symptom. It’s pretty unique. But the other symptoms are pretty classic u-joint. I highly doubt it’s carrier. If it was wheel bearing I’d expect some WUB WUB WUB at speed with the vibration.
    BlueGarden[OP] and FrenchToasty like this.
  16. Mar 25, 2024 at 7:57 PM
    BlueGarden
    Paducah, KY
    JasonC. likes this.
  17. Mar 25, 2024 at 8:08 PM
    BlueGarden
    Paducah, KY
    Thanks everybody, I will sleep better having a better idea of what's probably going on.
