Anyone know which sensor this is next to intake manifold? (4 on each side)
Discussion in '2nd Gen Tundras (2007-2013)' started by dzzardeneta, Mar 25, 2024.
  1. Mar 25, 2024 at 2:13 PM
    dzzardeneta
    dzzardeneta [OP] New Member
    IMG_0386.jpg IMG_0391.jpg IMG_0387.jpg IMG_0384.jpg Hey guys, mechanic came for a Valve cover gasket replacement, when putting everything back together some sensors right next to the intake manifold snapped, noticed there are 4 on each side right next to every cylinder (Left 4 are red , Right 4 are yellow) anybody know the name of the sensor or part#? Looked at diagrams online and none tell me the name of the part.
  2. Mar 25, 2024 at 2:33 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Are those your injector harnesses? Red locking clips look like ones I've seen on fuel injectors (in other vehicles).
    There would also be 4 injectors per bank of cylinders like you suggest.
    dzzardeneta[OP] likes this.
  3. Mar 25, 2024 at 4:03 PM
    SAGE63
    San Diego County
    that sounds like it would be bad...
  4. Mar 25, 2024 at 4:06 PM
    COTundie
    Trey
    Pretty things
    Hopefully it's the wire side and not the injector side which are broken
  5. Mar 25, 2024 at 4:08 PM
    dzzardeneta
    after doing some research i believe it is called the fuel injector connector.
  6. Mar 25, 2024 at 4:10 PM
    AZBoatHauler
    So.Arizona
    What’s the story with the HG failure? Did it overheat?
  7. Mar 25, 2024 at 4:13 PM
    SAGE63
    San Diego County
    Did the truck run before the mechanic worked on the heads... if so Then my guess is the mechanic broke them.....IMHO
    Guess I am a little jaded on some mechanic's...
  8. Mar 25, 2024 at 4:57 PM
    dzzardeneta
    Correction to the first post i made a typo it was NOT a head gasket**** , it was the valve cover gasket my apologies did not notice****
