My attempt at 100K maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by Damie Street, Mar 23, 2024.
  1. Mar 25, 2024 at 1:02 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Also if your truck is a flex-fuel, you can reset the fuel alcohol percentage.
    If you ONLY want to see codes, there are $30-40 code readers for that purpose. They may even be cheaper than that now. Some use BT and are tied to an app on your phone. Pretty handy.
  2. Mar 25, 2024 at 1:04 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Main reason I got the xtool was for the fuel reset. Those BT ones are very useful for the money.
  3. Mar 25, 2024 at 1:33 PM
    Damie Street
    Damie Street [OP] New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    I think I'm just looking for something to read the codes. I'm not a tech guy so I would be lost with that xtool. :rofl:
    So think I'm going to order this one.
    ToyoMafia likes this.
  4. Mar 25, 2024 at 1:35 PM
    ToyoMafia
    Magic carpet.
    Perfect.
    that will get it done.
  5. Mar 25, 2024 at 1:39 PM
    Damie Street
    Edsel
    Will this also tell you Temps? Like the transmission fluid temp?
  6. Mar 25, 2024 at 1:46 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    You have to spend quite a bit more to get a reader to give you fluid temps. The cheapest way I've found is using the Veepeak dongle ($14) and the Car Scanner ELM OBD2 app (free) available for your phone. Note that this is for Android only, but for a few bucks more you can get a Veepeak that speaks both Android and iOS and Car Scanner is also available for iOS. That will give you ATF, coolant, etc., temps all day long.
    BTW, this will also allow you to read the DTC codes that the above reader will do.
    Northbound Train likes this.
  7. Mar 25, 2024 at 1:47 PM
    ToyoMafia
    Magic carpet.
    I have no clue I bought the “fancy” one.
  8. Mar 25, 2024 at 1:47 PM
    ToyoMafia
    Magic carpet.
  9. Mar 25, 2024 at 1:48 PM
    ToyoMafia
    Magic carpet.
    wtf is Android??
    @Outbound please clarify
  10. Mar 25, 2024 at 1:48 PM
    Damie Street
    Edsel
    I'm ordering that for the transmission. maintenence. Per your recommendation. But I do want a code reader and eraser.
  11. Mar 25, 2024 at 1:53 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Fairly certain the OBDII dongle and OBD Fusion app will read and erase codes.
  12. Mar 25, 2024 at 1:56 PM
    ToyoMafia
    Magic carpet.
    I’m pretty sure as well.
    Damie Street[OP] likes this.
  13. Mar 25, 2024 at 2:10 PM
    Outbound
    Aaron
    Northern Alberta
  14. Mar 25, 2024 at 2:18 PM
    ToyoMafia
    Magic carpet.
    @Damie Street all jokes aside. Makes me smile to see ya tackling the service on ur own. Good on you.
  15. Mar 25, 2024 at 3:37 PM
    Damie Street
    Edsel
    Thank you my friend. Doing that and the washing/waxing of the vehicles too. Finally got a G9 polisher! Thank again for all your help.
  16. Mar 25, 2024 at 4:10 PM
    ToyoMafia
    Magic carpet.
    Love my G9.
  17. Mar 26, 2024 at 3:57 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    Yes the fusion app does read and erase codes. Had to do it this past weekend on my daughters car, (she didn't put the gas cap on properly and threw some evap codes).
  18. Mar 26, 2024 at 4:27 AM
    Damie Street
    Edsel
    Going to tackle the power steering today. Going to use this:
    300BLK, KNABORES and ToyoMafia like this.
  19. Mar 26, 2024 at 9:43 AM
    Damie Street
    Edsel
    I was able to return the coil to O'Reilly. That got me the $105 back
  20. Mar 26, 2024 at 9:51 AM
    #50
    AZBoatHauler
    So.Arizona
    Did you put some dielectric grease in the boots? That will help ensure good contact between coil pack and plug.
  21. Mar 26, 2024 at 10:02 AM
    #51
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    Regarding the transmission service, the truck itself will tell you when the temp is correct for the fluid check. Put it in trans temp check mode instead of using some other gauge or reader, literally what it was designed for. Lots of fans of this fella on here, I'd pay attention to him. Good luck! Oh, and get around to doing the front diff, too :thumbsup:
    https://www.youtube.com/watch?v=NUAuGmDGntY
    Henry1jg and Damie Street[OP] like this.
  22. Mar 26, 2024 at 10:03 AM
    #52
    Damie Street
    Edsel
    I actually think I used too much the first go round that's why the coil wasn't making contact or floating/running away.
  23. Mar 26, 2024 at 10:07 AM
    #53
    Damie Street
    Edsel
    I have that video saved and a couple others for when I'm ready to tackle the transmission. :thumbsup:
  24. Mar 26, 2024 at 2:29 PM
    #54
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I use one of these Mightyvac syringes for fluid extraction and filling. Mine is a 200ml size.
    https://www.amazon.com/dp/B00MPQ8RBG
    Just suck out the steering fluid, refill, and turn lock to lock about 10 times. Do this a few times and your fluid is gonna look really fresh.
    I also use it to fill my front differential. Suck oil out of the just and shoot it into the diff.
  25. Mar 27, 2024 at 4:38 AM
    #55
    Damie Street
    Edsel
    Power steering maintenance went well. The Mityvac tool was easy to use. 2 things I wish I could change/do better next time: had a more narrow funnel, the one I had had too big of a mouth and I made a little mess. And wish the container for the Mityvac was larger.
    Next on to the brake fluid and coolant...
    JimboSlice413 and ToyoMafia like this.
  26. Mar 27, 2024 at 5:30 AM
    #56
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Doing the brake fluid can be a little tricky. The proper way is to open the bleeder screws and each brake caliper and vacuum out the brake fluid and refill the reservoir. This can be a little tricky and you need to have a helper fo help to beed the braking system. Also if you're in the rust belt there is a good possibility the the bleader screws will be seized in the calipers and you could break them off trying to undo them. I suggest that you use your Mityvac to remove the brake fluid from the brake reservoir and refill with new dot 3 brake fluid. That way you don't have to mess with bleeding the brake system or opening up bleeder screws. Make sure your Mityvac vacuum pump is clean of oil. Any oil left in the hoses and contain can contaminate the brake fluid and even small traces will cause problems. Use brake cleaner to clean out you vacuum pump hoses before putting then in the brake reservoir.
  27. Mar 27, 2024 at 5:38 AM
    #57
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you do the coolant just drain the the radiator and fill back up with Toyota Super Long Life coolant. Don't mix with other coolants. Different coolants don't play well together. There is a drain at the bottom of the radiator you can get to without removing the skid pan. Use a hose over the bottom of the drain so that you can direct it into a container. Only open the drain about one full turn. You will need about a gallon of coolant.
  28. Mar 27, 2024 at 5:39 AM
    #58
    Damie Street
    Edsel
    Thank you for the advice much appreciated. I saw a couple YouTube videos that seem to make it look easier. I may just remove and fill the brake fluid. And wait to bleed when I upgrade my brake lines. I have a little road trip planned the first weekend in April so I would like to have the 100K maintenance done before I head out, but its not completely necessary if a couple things are left unfinished. I believe I could do the break fluid, coolant and front diff this week and tackle the transmission drain and fill next week.
    https://youtu.be/jpiXOBRkZs4?si=W0AVlSm-PPvixvYS
    Henry1jg and Ruggybuggy[QUOTED] like this.
  29. Mar 27, 2024 at 5:41 AM
    #59
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The dirtiest fluid is in the brake lines, especially close to the calipers. I understand the risk with rusty calipers and bleed screws, but he could verify that before beginning.
  30. Mar 27, 2024 at 5:43 AM
    #60
    Damie Street
    Edsel
    That's all? I saw a copy videos where the drained the reservoir and took off the front wheels and did those drains as well. So all that may be unnecessary?
    https://youtu.be/OivwKhMyLxs?si=nPGOJtCG_5a8KX46
