Is the coolant level dropping this much overnight normal?
Discussion in '2nd Gen Tundras (2007-2013)' started by YotaMan101, Mar 20, 2024.
  1. Mar 20, 2024 at 8:07 AM
    YotaMan101
    YotaMan101 [OP] New Member
    Is this normal level of coolant dropping over night? I have a 2008 Tundra SR5 4.7
    I took my truck into the shop for leaking coolant, they said an o ring was bad and replaced it. Said it should have fixed it. I took one pic at 7:30pm (The pic with more coolant in the res tank) And the other pic was taken at 9am the next morning. Is the level dropping that much overnight normal? It was cold over night as well. I’m currently running my truck to see if the level goes back to the top or not. Can’t really see any wet marks under the truck as well. So worried about a blown head gasket or something.
  2. Mar 20, 2024 at 8:15 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    The coolant does expand a bit when it gets hot so it’ll usually be higher when the engine is at running temp and then lower once it cools
    YotaMan101[OP] likes this.
  3. Mar 20, 2024 at 8:19 AM
    YotaMan101
    I just took this pic. I’ve let the truck run for about 30ish mins and it’s back to the top. So is that normal?
  4. Mar 20, 2024 at 8:31 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Fluid expansion and contraction. Hot fluid expands, so reservoir is fuller when hot. Cold fluid contracts, so it will draw in coolant from the reservoir
    Squatting Pigeon likes this.
  5. Mar 20, 2024 at 11:11 AM
    Squatting Pigeon
    Holden
    North Texas
    I think you’re all good OP
    YotaMan101[OP] and Johnsonman like this.
  6. Mar 20, 2024 at 11:44 AM
    Retired...finally
    Give it a little time. I've seen the large swings after changing coolant or opening up the system like a water pump change. My Fiat 124 still shows enough difference with ambient temperature changes I could almost use it as a thermometer.
  7. Mar 20, 2024 at 1:29 PM
    boatsnbikes
    boatsnbikes New Member
    As said looks like normal expansion. Look at it two mornings in a row after it has sat and completely cooled. Level should be the same both times
    Gene_in_FL and YotaMan101[OP] like this.
  8. Mar 23, 2024 at 3:13 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    What O ring? Got a bit more detail?
    The overflow works by allowing hot coolant somewhere to go as it expands and the radiator
    cap reaches it's max pressure. When the engine cools it creates a vacuum effect and draws the coolant
    back into the radiator lowering the level of the overflow. I'd say your system is working, although by the pics
    it's overfull. It says right on it, Full - Hot. Full - Cold. Not a deal breaker, just something to follow.
    Don't let it be dry. Always distilled water if used.
  9. Mar 24, 2024 at 6:24 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I would be more concerned about the color of the coolant. Is it mixed with something?
  10. Mar 25, 2024 at 7:09 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Looks like it was replaced with green antifreeze rather than the proper red (OAT?) product.
    The level in my expansion tank responds in the same fashion you are experiencing (normal). I assume it's why they call it an expansion tank... although I have the proper red coolant in mine;)
    WAtundra4x4 likes this.
