Looking for dyno results for TRD air intake
Discussion in 'Performance and Tuning' started by Panathrasher, Mar 24, 2024.
  1. Mar 24, 2024 at 3:19 PM
    Panathrasher
    Panathrasher [OP] New Member
    2021 White Tundra Limited 4WD
    So far just the wire harness to connect the tailgate to the power locks and the bed step.
    I haven't been able to find dyno results for the TRD air intake. I was wondering if anyone has a comparison dyno from the stock air box, unmodded, to the TRD air intake. A dyno comparison of all three would be nice.
    I have read a lot of threads that say the SABM is the best way to go and that most other aftermarket intakes cause you to lose power. I researched K&N and they boast a gain of about 9 HP and 14 ft/lbs of torque. My problem is that I live in California. A factory part like the TRD air intake would not raise any eyebrows but lord have mercy on you if they catch you with anything that isn't CARB-compliant. Needless to say, I am a little hesitant to go with the K&N intake so I am looking for some dyno results.
  2. Mar 24, 2024 at 3:34 PM
    Purely cosmetic.
  3. Mar 24, 2024 at 3:43 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just do a drop in air filter
  4. Mar 24, 2024 at 3:45 PM
    18" TRD Off Road Wheels
    The stock box is already a cold air intake. You don't gain anything changing it, even to the TRD box.
    Also, sounds like you need to move or band together to change the stupidity in CA.
    Fobroader, BR73, Mdl and 1 other person like this.
  5. Mar 24, 2024 at 3:57 PM
    Panathrasher
    I have been wanting to move out of this overbearing state for a long time.
    snivilous and GODZILLA[QUOTED] like this.
  6. Mar 25, 2024 at 8:10 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    aFe posts dyno results for their cold air intakes. They're a good company.
  7. Mar 25, 2024 at 9:03 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think dyno results that show a small difference are complete BS. The test setups aren't accurate enough to show a true scientific repeatable change. I have a friend that was a lead engineer at one of the big exhaust companies and he said they would claim the power improvement of an exhaust with whatever dyno run (once) gave the highest value, and just as often the runs would make less power. But one run said a 9hp increase so let's claim that even though it isn't repeatable!
    And let's be real, a power difference that small isn't noticeable. Biggest change would be how the intake noise sounds so it SOUNDS FASTER. I wouldn't base any stock replacement intake purchase on anything except looks.
  8. Mar 26, 2024 at 3:42 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    aFe provides all of the ambient conditions during the tests in their dynos: time, elevation, humidity, temp, fuel, gearing, etc…they control for just about every variable you can.
    Combustion is air + fuel + spark.
    There’s no doubt that more air and cooler (more dense) air aids in more efficient combustion.
  9. Mar 26, 2024 at 5:47 AM
    Skip the airbox mods and racing filters, no good for the long haul.
  10. Mar 26, 2024 at 10:48 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    With one exception. The TRD velocity stack/ air flow accelerator changes the sound in a subtle but pleasing way, is dirt cheap, and you can keep factory filtration
  11. Mar 27, 2024 at 4:52 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This is the only air intake that will affect a dyno
    BR73, tundra_20, Mdl and 9 others like this.
  12. Mar 28, 2024 at 4:31 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    1900 or Harrop?
    I’m planning for a Harrop soon. Definitely intent on feeding it more, colder air too.
  13. Mar 28, 2024 at 4:33 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Harrop. 2650
    1900's and all Magnuson's are upside down. :crapstorm:
    or maybe...since the Harrop is Australian...mine is upside down.
    ponderous.
    bulldog93 and reywcms like this.
  14. Mar 28, 2024 at 9:50 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Gold intakes work lol
    Mdl and bulldog93 like this.
  15. Mar 28, 2024 at 10:47 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Do you know if you went to a 4.5 inch intake would it increase boost or would that just be purely the pulley size ?
  16. Mar 28, 2024 at 10:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You'd gain slightly but not much. I'm moving from a 4.5" to 5" and also from the 84mm rcf to 103mm LS throttle body. I'm expecting to gain some.
  17. Mar 28, 2024 at 10:52 AM
    Ctaylor76
    Chaz
    Houston
    do you know if the magnuson tsv2650 kit comes with a 4.5 inch ? I noticed on that kit it does come with a airbox but I can’t tell if it’s any bigger then the stock airbox from the factory.
    yeah I was looking at that RCF TB but I didn’t like the fact you had to hallow out that snout.
  18. Mar 28, 2024 at 10:56 AM
    snivilous
    SW UT
    The intake tube is bigger by ~0.5", but it's not to make more power but to keep the MAF sensor within it's voltage range.
    Performance per dollar a pulley can't be beat. That's not to say other stuff doesn't have its place, but I would argue are more of supporting modifications as opposed to purely chasing power like the pulley is for.
  19. Mar 28, 2024 at 10:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    And I don't believe now you need to port the inlet of the 2650 to match better.
    Mdl likes this.
  20. Mar 28, 2024 at 11:08 AM
    Ctaylor76
    Chaz
    Houston
    oh okay. So I could probably move up to that RCF throttle body without having to modify?
  21. Mar 28, 2024 at 11:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes, you will need a throttle body spacer from @snivilous and why not throw a pulley on it also.
    Mdl, Ctaylor76[QUOTED] and snivilous like this.
  22. Mar 28, 2024 at 11:28 AM
    snivilous
    SW UT
    Prospeed has a spacer. Not worth it for me to machine one when someone else offers one :rofl:
    Mdl, Ctaylor76[QUOTED] and reywcms like this.
  23. Mar 28, 2024 at 11:32 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Is there's now available for the new maggy 2650?
  24. Mar 28, 2024 at 11:34 AM
    Ctaylor76
    Chaz
    Houston
    can you go to a 76mm without adjusting the injectors for that blower ? I was thinking I would just adjust pulley and the tb.
  25. Mar 28, 2024 at 11:39 AM
    Ctaylor76
    Chaz
    Houston
    so idk because on the website it just shows a 1900.
  26. Mar 28, 2024 at 12:01 PM
    ssmokedz
    Shelton CT
    I don't know if you saw it or not but you've got some coolant crusties there you gotta take care of.
  27. Mar 28, 2024 at 12:05 PM
    snivilous
    SW UT
    I'd assume it's the same spacer since they both use the tundra bolt pattern and both have a 90mm intake size.
    I'm tagging @carn_dogg a lot since him and I went through this exact same thing a few weeks ago. The stock injectors were running out at 5000rpm, so yes I would say injectors are needed with the 76mm (and subsequently a tune to make the injectors work). The 76mm gave him a ~50% increase in boost so the truck is making a lot more power. That's with a stock throttle body. Magnuson kit with the 76mm and 650cc injectors and he's at 12psi.
  28. Mar 28, 2024 at 12:11 PM
    Ctaylor76
    Chaz
    Houston
    that’s crazy! 5 pounds of boost just swapping injectors and a pulley… that’s hawt.
  29. Mar 28, 2024 at 1:34 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    good eye.
    It hasn’t gotten any worse since I originally had the darn thing installed
    yes, I’m lazy
    reywcms likes this.
  30. Mar 28, 2024 at 1:35 PM
    Ctaylor76
    Chaz
    Houston
    is that just a gasket leaking or why is coolant coming out of that area ?
