Put Some 275/60/R20 BFG K02s on my Platinum Today
Discussion in 'Wheels & Tires' started by PJSD, Jan 3, 2024.
  1. Jan 3, 2024 at 8:26 PM
    PJSD
    PJSD [OP] New Member
    In case anyone was wondering if they'd fit and what they look like. 100% stock, no issues or rubbing. Fills out the wheel well a little better compared to the 275/55/R60 K02s I had on there. Pretty happy with them. I have to fit the truck under some parking garages, etc. so I can't get a leveling kit, lift etc. I think that this is about as high as I can go...
  2. Jan 3, 2024 at 10:08 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    275/65/R20, BFG here at stock, no issues.
    PJSD[OP] and dondino like this.
  3. Jan 3, 2024 at 11:14 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Those look good.
    Lifer and PJSD[OP] like this.
  4. Jan 4, 2024 at 5:26 AM
    attillatundra
    attillatundra New Member
    Looks good. How is the ride now compared with the stock tires? Did you go with P rated or LT?
  5. Jan 4, 2024 at 10:38 AM
    PJSD
    I went with LT rated, the ride is quite good as far as I can tell. It's smooth, comfy, not too loud at all on streets and freeways. When the prior set wore down a bit they got louder. Of course the P rated stock tires would be smoother I suppose, but it's a truck and needs truck tires that are mud and snow rated.
  6. Mar 21, 2024 at 7:11 AM
    LUGNUT
    LUGNUT New Member
    Corey
    SoMD
    2020 Voodoo Platinum
    No rubbing? Did you have to remove mudguard or anything to accomodate? Any pics?
  7. Mar 21, 2024 at 7:12 AM
    LUGNUT
    LUGNUT New Member
    Corey
    SoMD
    how’s the ride? About to pull the trigger but back and forth between the KO2’s and the KO3’s
  8. Mar 21, 2024 at 7:16 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Nice!
  9. Mar 21, 2024 at 8:59 AM
    PJSD
    The Ride is great... no issues. I don't know about the K03's, I decided to go with what I know works well instead of something new that a lot of folks haven't tried out yet.
  10. Mar 21, 2024 at 9:00 AM
    PJSD
    No modifications at all, my truck is totally stock. No rubbing at all. No lift or leveling or anything like that.
  11. Mar 23, 2024 at 7:51 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Stock w/ no rub or alterations.
