Disconnected wire engine bay - where to reconnect?
Discussion in 'Electrical' started by Timdan, Mar 22, 2024.
  1. Mar 22, 2024 at 9:05 AM
    Timdan
    Timdan [OP] New Member
    2008 CM Limited 5.7
    2008 CM Limited 5.7 - Anyone know what this wire is supposed to go to? Noticed it was loose when replacing my engine filter…assuming it’s some sort of ground wire but no idea where it’s supposed to go. 2nd pic is where one end it attached to…other end is loose. Engine seems to start and run fine…no CEL or any warnings on the dash
  2. Mar 22, 2024 at 9:15 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Looks like it’s the same as the ground wires attached to side panels in engine compartment. It’s got the little tab on end like similar ones in my truck.
    Timdan[OP] and PolishedTRD like this.
  3. Mar 22, 2024 at 9:34 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That ground wire attaches to the body right behind the air box right here.
    Timdan[OP] and 1lowlife like this.
  4. Mar 22, 2024 at 2:17 PM
    Timdan
    2008 CM Limited 5.7
    Thank you - I ended up attaching it to another ground point that I was able to get it to without having to mess with unmounting the air box!
    TILLY likes this.
