  1. Mar 20, 2024 at 4:26 PM
    #6001
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    All done wiring everything up, just need to tuck in the deutch connectors on passenger front that I used to wire in the marker lights in the grill. Took way longer than I needed to to tuck all the wiring and make my own harness but very happy with the results. About had a panic attack when it didn’t fire up though. The add a fuse came with one slot filled with a 5amp fuse and didn’t realize that not only did I need higher amp fuses but that both slots needed to be filled. Used double 15s and voila, all is well.
    Thanks to @KClav for his write up on the OEM switch!
    DIYReid, NWFLATundra, Pgain88 and 2 others like this.
  2. Mar 20, 2024 at 4:52 PM
    #6002
    lapoolboy
    lapoolboy New Member
    Where are you in Texas? Wanna help me swap mine? :fingerscrossed:
  3. Mar 20, 2024 at 6:43 PM
    #6003
    Momcar160
    Momcar160 New Member
    22 TRD Sport 4x4
    details on this badge?
  4. Mar 20, 2024 at 6:58 PM
    #6004
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Tacos 4 cheap
    Link and note made 3rd gen Buy Sell.
  5. Mar 20, 2024 at 7:37 PM
    #6005
    BigElliott
    BigElliott New Member
    2025 TRD Pro
    That looks good!! Where did you get that?? Do you happen to have a part number??
  6. Mar 20, 2024 at 8:59 PM
    #6006
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    no need for high amp fuse if youre just powering up a relay. 5a will be just fine for that. What fuse size does the fuse cover call for in the slot you tapped into?
    Goobax[QUOTED] likes this.
  7. Mar 20, 2024 at 9:09 PM
    #6007
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Same here!
  8. Mar 21, 2024 at 4:50 AM
    #6008
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I had two-pack of add fuse that came with various lights that included a 2 and 5 amp single fuse in each respectively. The slot I used was under towing which is listed as a 30amp. Open to suggestions on dropping the fuses down appropriately but I have a relay and a canbus adapter for the oem switch.
    I’m in Pearland. I can help supervise but honestly it’s extremely straight forward. I used the Yota Xpedition video and it was the best I found to refer to.
    https://youtu.be/RdnlAkrzFFE?si=ac5EEZt7oRc7UQR_
  9. Mar 21, 2024 at 7:23 AM
    #6009
    eddiefromcali
    Eddie
    100% Stock
    I would put a 30a back in there for the oem circuit and a 5a for the relay/box activation. The 30a might be for the 12v source at the trailer plug if it was under "towing", so keeping a 15a in there wont "harm" anything since youre dropping the rating, not increasing.
  10. Mar 21, 2024 at 9:03 AM
    #6010
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Thank you!
    I picked it up on Sparks Parts. Here are the part numbers.
    Malinois38 likes this.
  11. Mar 21, 2024 at 10:34 AM
    #6011
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    it should be
    55476-0c060-B0
    @BigElliott
  12. Mar 21, 2024 at 10:36 AM
    #6012
    Black widow TRD
    Manuel
    You’ll want all three pieces so the entire trim matches across the dash. My OCD kicks in with mismatched pieces. It’s not too bad… but it’s not the same.
    benca1 likes this.
  13. Mar 21, 2024 at 10:37 AM
    #6013
    benca1
    benca1 New Member
    those are all 3 different ones. You have the correct one listed on the bottom :) He doesnt need to order all 3 :)
  14. Mar 21, 2024 at 10:43 AM
    #6014
    benca1
    benca1 New Member
    Oh I see what you ordered and why. I thought he just wanted that one piece. :) I understand OCD. The texture of the pro piece will match the other pieces you ordered across the dash :)
  15. Mar 21, 2024 at 12:29 PM
    #6015
    BigTrout
    BigTrout New Member
    2024 Tundra Platinum TRD Off Road
    Ceramic coat finished just in time for the snow that’s forecast tonight. Freaking “Murphys Law” in full affect (or effect? O never remember)
  16. Mar 21, 2024 at 1:24 PM
    #6016
    benca1
    benca1 New Member
    How do you like the TRD filters? What light bar did you go with as well?
  17. Mar 21, 2024 at 1:27 PM
    #6017
    benca1
    benca1 New Member
    what light bar do you have ?
  18. Mar 21, 2024 at 2:41 PM
    #6018
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I’d be lying if I told you I heard/felt a difference with the filters but I had some store credit from when I bought my truck and my dealer matched online prices so I used it for that. Light bar is Diode Dynamics combo throw. Really like it
    benca1[QUOTED] likes this.
  19. Mar 21, 2024 at 5:20 PM
    #6019
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    You just need to remove the center console. It comes apart fairly easy. This video helped.
    https://youtu.be/0p0-j9Ea1OU?si=5QdY0-Yrn5aW07d8
    TN Tundra2 likes this.
  20. Mar 21, 2024 at 5:23 PM
    #6020
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
    I got tagged at some point. I didn’t notice it til a co-worker pointed it out. It was pretty easy to replace both. The color match from Painted OEM Parts is spot on !
  21. Mar 21, 2024 at 8:06 PM
    #6021
    BigElliott
    2025 TRD Pro
    Awesome!! Thanks so much!!
  22. Mar 21, 2024 at 9:05 PM
    #6022
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Painted OEM parts is clutch! Did you transfer over the parking sensor?
  23. Mar 21, 2024 at 9:14 PM
    #6023
    Prescott87
    Jonah
    Brentwood, Ca
    There’s a plastic bracket with adhesive that’s used to hold the sensor in place. Once I took it off, it wouldn’t restock. I was going to try some silicone or super glue to hold it until I can find a part number for a new one.
    Tundrastruck91 likes this.
  24. Mar 21, 2024 at 9:24 PM
    #6024
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    Ah. I reheated mine with a heat gun, and it's been sticking (so far). Unless @ryanwgregg can help find a part number. Looking for the adhesive that holds the round parking sensors to the back of the bumpers.
  25. Mar 21, 2024 at 9:33 PM
    #6025
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    Could possibly be PNC 89C48A, but can't confirm an actual part number for it.
    ryanwgregg and Prescott87 like this.
  26. Mar 21, 2024 at 9:52 PM
    #6026
    Prescott87
    Jonah
    Brentwood, Ca
    I ran into the same issue finding that number. I found this on eBay and it looks similar. I’m going to order it and see if it works. I’ll give an update if it’s the right one.
    Tundrastruck91, ryanwgregg and TundrX like this.
  27. Mar 22, 2024 at 6:47 AM
    #6027
    BigTrout
    BigTrout New Member
    Detailer showed my truck on ticktock!
    Pretty cool
  28. Mar 22, 2024 at 4:02 PM
    #6028
    GrandPooPaw
    GrandPooPaw New Member
    2024 Platinum
    looking and researching
    Looking good, I am down to this and the BAK Revolver X4s. Still can’t make up my mind. Any issues with losing the bed room?
  29. Mar 22, 2024 at 4:07 PM
    #6029
    lapoolboy
    There is no comparison between a Retrax and a BAK! Anything BAK is garbage.
    Hank Hill likes this.
  30. Mar 22, 2024 at 4:23 PM
    #6030
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Toyota Tundra LED Tailgate Light Bar PK539-34N00. I saw this listed for $525 CDN which seems a bit pricey for these but the also have a back up light in the middle and a wiring harness.
    Has anyone spent the bucks and put a set of these in?
