Avoid buying a Tundra that was used with a Plow?
Discussion in 'General Tundra Discussion' started by fastace, Mar 20, 2024.
  1. Mar 20, 2024 at 4:03 PM
    fastace
    fastace [OP] New Member
    There is a Tundra near me with low miles, 2013 with 70k miles and the Toyota dealer wants 23k OTD for it and will not budge. I test drove the truck and it drives nice but what is concerning to me is that it has a snow plow bracket in the front (Boss name brand) and snow plow controls inside. The carfax shows no accidents and two owners, both for personal use. The first owner owned it 8 years and the second owner for over a year.
    I understand that a snow plow can stress the transmission. Should I avoid buying a Tundra that had been used with a snow plow even if it was just for small time use like plowing their own driveway? I see many Tundras with snow plows and they seem to not sell well.
    Any insight would appreciated.
  2. Mar 20, 2024 at 4:09 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Personally I would not buy a truck that was used for plowing. They take a beating.
  3. Mar 20, 2024 at 4:32 PM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    With snow equipment in place, another issue I would be concerned of would be rust on the frame and body.
    Be sure to address that if you end up wanting the truck, but I personally would stay away from it.
    Even though 2013 does have factory transmission cooler and likely the work environment is way colder than most, but again it is a big strain again what it was made for.
    If a third party inspection can be done, and it checks out OK without too much major repairs needed in the near future, then go for it.
  4. Mar 20, 2024 at 5:06 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Unless you want to buy a jacket with a Mr Plow logo and make some side cash, I would suggest to keep looking.
  5. Mar 20, 2024 at 5:17 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    There is a 0.0 chance I would buy any truck that was used as a plowing vehicle. Way too much wear and tear to a lot of components that I personally wouldn’t feel comfortable dealing with. I am sure some individuals / companies take care of their plow vehicles, but it cannot negate the stress placed on the truck.
    GODZILLA and ZappBrannigan like this.
  6. Mar 20, 2024 at 6:31 PM
    fastace
    They sent me a video showing the truck up on a lift and the mechanic saying how well maintained the truck was. It drove like a new truck but I did not get a chance to take it on the highway tho. I might get it inspected by independent mechanic.
  7. Mar 20, 2024 at 6:39 PM
    fastace
    They sent me a video with the truck on a lift showing the frame and undercarriage in excellent shape, just la little surface rust. The Toyota dealership also sent me a full inspection report, it just showed they replaced rear axle diff vent. I would definitely get an inspection. Do you think I should avoid taking it to another Toyota dealership for a pre-purchase inspection? Or do you think Toyota dealerships are in cahoots with each other? I like using a Toyota dealership master tech because they know exactly what to look for with these Tundras and they provide a video of anything problems found.
  8. Mar 20, 2024 at 6:44 PM
    fastace
    Actually, I thought it would be cool to clear my own driveway when the snow hits hard. It doesn't appear to be a work truck, it is too clean to be one. Could be a side hustle driveway snow plow truck.
  9. Mar 20, 2024 at 6:46 PM
    fastace
    It doesn't appear to be a work truck, probably a side hustle driveway or personal snow plow truck for their driveway. What if I take it to get fully inspected at a Toyota master tech and there are no issues?
  10. Mar 20, 2024 at 6:50 PM
    2mchfun
    It's not the miles, in this case it's the hours. I assure you there on many hours of wear on that truck.
    ZappBrannigan and fastace[OP] like this.
  11. Mar 20, 2024 at 6:56 PM
    fastace
    Carfax says it was always a personal vehicle but I know many people lie and use it for business on the down low. However, it is definitely not a fleet truck.
  12. Mar 20, 2024 at 6:58 PM
    Those 70k are hard 70k, so prob closer to 140k on it (not bad) but all the stress on the ball joints, trans, bearings, etc to push around so much weight
    ZappBrannigan likes this.
  13. Mar 20, 2024 at 7:01 PM
    2mchfun
    Your money, good luck!
  14. Mar 21, 2024 at 9:44 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    My first thought is the front coilovers are probably shot, the rear leafs are flat from the counter weight that it needs.
    Surface rust is on the surface now, but won't be later. Transmission and transfer case are probably beat too.
    Unless you are getting this for a screaming deal, I would spend a bit more money on a pavement princess.
  15. Mar 21, 2024 at 10:49 AM
    fastace
    eh somebody else's trouble now, it was just sold yesterday. It was a RCSB. It is impossible to find a great low mile rust free RCSB 4x4, most down south or out SW are 2wd or a long bed. I guess you can always have the surface rust blasted off and have it coated.
