hi peeps, new member introduction
Discussion in 'New Member Introductions' started by cody c, Nov 28, 2023.
  1. Nov 28, 2023 at 2:14 PM
    cody c
    cody c [OP] New Member
    cody
    blue 2006 tundra double cab 4x4
    retractable fog lights, dry box mounted winch
    Hey y'all, the name is Cody, i live in Calgary and purchased a 2006 tundra double cab this year after my 1992 6bt swapped Landcruiser got t-boned, flipped and written off...
    It was a fun ride, super duty D60 and 14b rear axle, 1st gen cummins with NV4500, and Yoyota full time t-case, running on airbags and 40" tires in the summer and 42" studded iroks in the winter (beadlocks). There is a thread on ih8mud about it title'd: "the one ton swap thread" in the 80 series section.
    Anyways, picked up a low-ish mileage 2006 tundra in Omaha and brought it home this year. have done some basic maintenance including (aisin or denso) timing belt spark plugs, air filter, serpentine, bosch brakes, and put in a aluminum dry box with a 2500lb quad winch in it for retrieving elk/moose.
    Also working on retractable fog lights, which I have wired up in the center console, modded the skid plate and will hopefully be installing this weekend.
    Anyways, stoked to download some wiring diagrams etc off the site and be a contributing member to the forum/community.
    Cody.
  2. Nov 28, 2023 at 8:20 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Nov 28, 2023 at 9:15 PM
    Welcome from NY.
  4. Nov 29, 2023 at 8:28 AM
    cody c
    cody
    Thanks Kelly & Jim!
    on the hunt now for threads and more info on LBJ failures and potential mods for improving what seems to be the Achilles heel of the 1st Gen if anyone knows of some links!
  5. Nov 29, 2023 at 8:31 AM
    Welcome aboard. Your 2006 has the upgraded LBJ design, which unfortunately is beefier, but prone to the same failures. The “fix” is to get rid of the original IFS setup. Maybe some long travel kits have a different LBJ design. Solid axle swap would certainly eliminate it.
  6. Nov 29, 2023 at 8:40 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Check out the 1st Gen forums. There are some really knowledgeable people in there that can help you.
  7. Dec 3, 2023 at 11:51 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  8. Mar 18, 2024 at 2:47 PM
    cody c
    cody
    I think I'm going to use the intro thread as a bit of a build inventory (update pictures later).
    So after I got the Tundra back from a very long drive (Omaha to Calgary) I left it for a couple weeks and then got into it with some OEM (Aisin etc) parts
    Timing belt
    Serpentine belt
    Water pump
    spark plugs
    air filter.
    The exhaust needed a fix as the stock pipe was rotted. Look how pinched the stock pipe is where the two pipes connect (new is 2.5" to 3" stainless from cats)
    Went with the biggest 3" muffler for diminished noise.
  9. Mar 18, 2024 at 2:48 PM
    cody c
    cody
    Next step was dealing with my paranoia about catalytic converters disappearing at night, created a CAD file and bent some aluminum
    Also added a dry box with a quad winch for pulling in wild game, always wanted to do this
  10. Mar 18, 2024 at 2:50 PM
    cody c
    cody
    I've update the aged stereo with new and some speakers and deadening, and found a deal on some used Raptor shocks for projects on this in the future
    Also, just got:
    • passenger wheel bearing,
    • brake pads and
    • front sway bar links replaced,
    • new coolant,
    • Keyed gas cap
    • rear view camera wired in
    • dry box winch got synthetic cable and aluminum fairlead installed and wired
    • some USB chargers mounted in the dash.
    Just_Josh likes this.
  11. Mar 18, 2024 at 2:55 PM
    Just_Josh
    Just_Josh New Member
    2005 Tundra
    Softopper
    Hey, just signed on. I'm from the PNW and have had my 05 Tundra for a year now. Haven't done much other than throw a Softopper on it and build a bed in the back for camping. Before my family started growing I did a fair amount of rockcrawling/Jeeping but currently do just light touring/overlanding. I found the forum when looking to upgrade my foglights.
    cody c[OP] likes this.
  12. Mar 19, 2024 at 7:30 AM
    cody c
    cody
    Hey Josh, welcome to the forum!
    You should post your own intro thread and some pictures of your truck as well.
    Did you find the forum with the foglight video i had posted on youtube?
    https://www.youtube.com/watch?v=sH0pdkaEA9w
    I still have to mount the second one
    Just_Josh[QUOTED] likes this.
  13. Mar 19, 2024 at 9:49 AM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Welcome from West MO
