2008 Tundra SR5 4.7 leaking coolant
Discussion in '2nd Gen Tundras (2007-2013)' started by YotaMan101, Mar 19, 2024.
  1. Mar 19, 2024 at 9:35 AM
    YotaMan101
    YotaMan101 [OP] New Member
    I’ve been leaking coolant in my Tundra, took it in to get looked at and they said they found a leak with an O ring. They replaced it. And said that should fix it. Well I just popped the hood and opened the oil cap. And this is what I found. (I looked for milky liquid on the oil cap and radiator cap before I took it in and found nothing…Now today I did…what could this mean..
  2. Mar 19, 2024 at 11:46 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    That milky oil on the cap can happen after short drives. Just clean it off.
    MEWaters and YotaMan101[OP] like this.
  3. Mar 20, 2024 at 6:12 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    The white goo is a sign of moisture best case scenario is driving short trips worse case would be a blown head gasket. I would check the oil dipstick to see how that looks and clean the goo off the oil cap and see if it returns
    YotaMan101[OP] likes this.
  4. Mar 21, 2024 at 5:54 AM
    YotaMan101
    Checked the oil dip stick every day, and have found nothing. And I cleaned the oil cap the day I posted this and hasn’t seen it return yet.
  5. Mar 21, 2024 at 7:01 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Has your coolant level been normal since the o ring replacement?
  6. Mar 21, 2024 at 1:11 PM
    YotaMan101
    As far as I can tell. It’s gone down when it gets cold and goes back up once I’ve run the truck for a bit. Before it was going down regardless of running or not running it.
    OldGuy03[QUOTED] likes this.
  7. Mar 21, 2024 at 1:39 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The rise and fall you're seeing in coolant is fairly normal. If you see it drop way below what it looks like when it's cold you know there is a bigger problem than that o ring. Im guessing it's a pretty good assumption that what you saw in the oil cap is a common cause of short trips.
