Bakflip MX4
Discussion in 'Tonneau Covers, Caps and Shells' started by RexKwonDo, Mar 18, 2024.
  1. Mar 18, 2024 at 6:05 PM
    RexKwonDo
    RexKwonDo [OP] New Member
    2023 Tundra SR5 4x4 TRD Sport
    20240318_162656.jpg 20240318_162643.jpg Just finished installing the Bakflip MX4. For anyone who has this cover or has experience with it, I have a couple questions.
    Is the rubber seal supposed to go completely over(cover) the foam bulkhead seal?
    Is this too much gap between the tailgate and the end of the cover?
  2. Mar 18, 2024 at 9:45 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Yes, the rubber lip up front just sits with pressure on the foam seal. It appears a little far back (to the rear) based on the overlap on the gate. I’ll get some pics of how mine is in the am/daylight.
  3. Mar 18, 2024 at 10:51 PM
    RexKwonDo
    I thought it looked a bit off. Thank you I would appreciate that.
  4. Mar 18, 2024 at 11:28 PM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Yeah same with me .
  5. Mar 21, 2024 at 1:58 PM
    PNW Tundra Mike
    Southern Cal
    Sorry man, had to fly out of State for a family emergency after saying I’d check some clearances for you. Will be back to my truck Sat night.
    RexKwonDo[QUOTED][OP] likes this.
  6. Mar 21, 2024 at 2:13 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Looks right. You should be able to close the tailgate without opening the cover. You don’t want the side seal hanging over into the tailgate gap. That gap looks normal. IMG_6291.jpg
  7. Mar 26, 2024 at 11:52 AM
    RexKwonDo
    No worries, this isn't that important.
  8. Mar 26, 2024 at 11:53 AM
    RexKwonDo
    Thank you. I just wasn't sure on how it's supposed to sit.
    GIN•OKUMA[QUOTED] likes this.
  9. Mar 26, 2024 at 2:47 PM
    PNW Tundra Mike
    Southern Cal
    Sorry for the delay. The rear gaps look the same as yours which only allows a little water down between the gate and bed. You can see the amt of overhang on the top of the gate. That overhang on the gate actually stops it from automatically opening when either unlock button is pushed.
    In front you can see how the small foam pads go around the corner and under the front rubber flap. Note my rubber flap edge is flush with the leading edge of the bed in the center. (foam rubber stick-on weatherstrip underneath) Theres a little bow in the front edge of the bed I think your cover is a little further back.
    Not sure if that helps.
  10. Mar 26, 2024 at 6:47 PM
    RexKwonDo
    I appreciate it. This helps alot to compare mine. Looks pretty similar
