Power steering over filled at Toyota dealership.
Discussion in '1st Gen Tundras (2000-2006)' started by Squeakyduck4, Mar 17, 2024.
  1. Mar 17, 2024 at 12:49 PM
    Squeakyduck4
    Squeakyduck4 [OP] New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    Should I get a turkey baster and just get rid of the extra or just leave it? Thanks, and
    hope you're having a great weekend.
  2. Mar 17, 2024 at 2:22 PM
  3. Mar 17, 2024 at 2:23 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    Okay thanks for the reply
  4. Mar 17, 2024 at 4:18 PM
    That thing works....for a while. I got so frustrated with mine I threw it out. I wish someone made a better one that would work.
  5. Mar 17, 2024 at 4:19 PM
    I’ve got a 60cc syringe and some tubing for it. Works great for this kind of thing.
    PKFan, Dirt Ferguson and FrenchToasty like this.
  6. Mar 17, 2024 at 4:36 PM
    I’ve never had an issues with mine but I really don’t use it much.
  7. Mar 17, 2024 at 11:33 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Bro, leave it. Worst that will happen it will overflow when it gets hot. I keep mine higher than that normally.
    whodatschrome likes this.
  8. Mar 18, 2024 at 1:39 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I use a straw. That way I can taste to be sure they used the right fluid as well.
  9. Mar 18, 2024 at 5:41 AM
    The taste test is infallible.
    FrenchToasty and w666[QUOTED] like this.
  10. Mar 18, 2024 at 6:52 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    +1
  11. Mar 20, 2024 at 10:31 AM
    cody c
    cody c New Member
    cody
    blue 2006 tundra double cab 4x4
    retractable fog lights, dry box mounted winch
    I know of no risk (other than overflow and spillage) to having more fluid in the reservoir. Personally I would overfill it a bit. And actually having more volume may disperse contaminants and have more volume to disperse heat, although the benefits would be minor.
  12. Mar 20, 2024 at 8:12 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    This ^^^
  13. Mar 21, 2024 at 6:15 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I've pumped out fluid from my power steering reservoir using a cheap transfer pump from Harbor Freight. It works well and would take care of your issue.
  14. Mar 21, 2024 at 7:01 AM
    FishNinja
    Lee
    06DC2wd
    Turkey baster and some tubing is what I used.
  15. Mar 21, 2024 at 7:57 AM
    coTony
    Tony
    Montrose, CO
    Is there a video on the proper taste procedure? :popcorn:
  16. Mar 21, 2024 at 8:07 AM
    cody c
    cody c New Member
    cody
    I don't know about the IFS steering rack, but I have pulled apart to rebuild landcruiser steering pumps, as well as steering boxes (to replace some seals and drill/tap for hydraulic assist/ram).
    My perspective on it would be to dump the fluid, and put new in. Get your tires off the ground, disconnect the lowest hose(s) and turn the steering wheel left to right a few times to evacuate fluid. Maybe turn the pump over for half a second to get any fluid out.
    Steering fluid isn't that expensive and they don't hold that much, easy enough to do a "flush" by filling it with cheaper generic stuff, cycling it back and forth a couple times, draining again and then putting new fluid in.
  17. Mar 21, 2024 at 8:12 AM
    FishNinja
    Lee
    06DC2wd
    You mean something like this
    https://youtu.be/ywRzmvWVMqw?si=b5cMvNeauP-XALN_
  18. Mar 21, 2024 at 8:19 AM
    Jack McCarthy likes this.
  19. Mar 21, 2024 at 8:33 AM
    FishNinja
    Lee
    06DC2wd
    the under the hood shot. It's just clear brown. LOL
  20. Mar 21, 2024 at 4:30 PM
    w666
    Maryland
    Indeed!
    coTony[QUOTED] and FrenchToasty like this.
