Alarm goes off every 12 hours
Discussion in '2nd Gen Tundras (2007-2013)' started by rnciholson14, Mar 14, 2024.
  1. Mar 14, 2024 at 9:13 PM
    rnciholson14
    rnciholson14 [OP] New Member
    The alarm system is going of every 12 hours (happens around noon and midnight). Just started happening a couple days ago and it is now showing to be consistent at these times. Any ideas of what could be causing it are greatly appreciated. (2012 limited.)
  2. Mar 14, 2024 at 9:20 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Do you have sunroof? Mine did that when I accidentally left it open for some weird reason.
  3. Mar 14, 2024 at 9:24 PM
    rnciholson14
    Nope, no sunroof. And I’ve checked to make sure all windows are up. It’s just so weird to me that it’s almost exactly every 12 hours
  4. Mar 14, 2024 at 9:26 PM
    2mchfun
    No idea, but have you tried to disconnect the battery?
    Medicineman likes this.
  5. Mar 14, 2024 at 9:29 PM
    rnciholson14
    No not yet. Going to try that tomorrow
    Medicineman and 2mchfun[QUOTED] like this.
  6. Mar 15, 2024 at 3:42 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Was going to suggest checking the battery itself. All sorts of gremlins can appear when a battery is bad or nearing end of useful cycle.
    rnciholson14[OP] and PlatinumPro like this.
  7. Mar 15, 2024 at 5:42 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Years ago I had same issue with our minivan. Finally found corrosion in the body control module from a leak that happened months before. Something else to check.... Good Luck!
    Medicineman and rnciholson14[OP] like this.
  8. Mar 15, 2024 at 7:31 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    My Celica had an aftermarket system and would do this when the battery started dying, I had a remote that would beep in conjunction with the car alarm, let me tell you that whenever I lost my keys I would kick a tire and set off the alarm on both and it made it easy to find my keys. My mom was so sick of this she disconnected the battery for 6 months, and someone stole my oem speakers... lol... Anyway I would test the battery, not sure about your alarm system, but my oem alarm has never gone off, but I think it's preventing me to turn it on, using it's keys..
  9. Mar 15, 2024 at 7:38 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    agreed. when mine was losing voltage my seat would automatically move forward when i started it trying to pin me against the wheel. Bought a new battery and hasn't happened since.
  10. Mar 17, 2024 at 4:43 PM
    lowercaseg
    lowercaseg New Member
    2013 Tundra Crewmax TRD
    Putting a new battery in your key fob might help. Fixed an alarm problem for me a few years ago.
  11. Mar 17, 2024 at 4:50 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    +1, when my battery started to go (which wasn't picked up by the battery health checker at AutoZone) it would start fine but the alarm would randomly go off. Since replacing I haven't had that issue anymore.
  12. Mar 17, 2024 at 8:50 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Also check the battery clamps and make sure they are free of corrosion.
    My 2005 had similar issues and there was the thinnest layer of corrosion on the POS post.
    A $3 post cleaning brush fixed it..
