Abs li light off and on...
Discussion in '1st Gen Tundras (2000-2006)' started by Mikewinters1976, Mar 16, 2024.
  1. Mar 16, 2024 at 5:03 PM
    Mikewinters1976
    Mikewinters1976 [OP] New Member
    My abs light comes off and on, seems symptoms only apparent when braking while making right turns. Feels as if brakes are slipping. Any ideas?
  2. Mar 17, 2024 at 7:53 AM
    shifty` Ten EV 12's so you know I raise hell
    Wheel speed sensors/ABS sensors. Start by pulling the front two, it's one bolt, I think 10mm IIRC. Checking for fragments of shit on them, wipe clean, check the harnesses for rub thru, be sure to reinstall squarely. See if the issue persists.
