Spare Tire Hoist
Discussion in 'Wheels & Tires' started by agrestic1, Aug 20, 2021.
  1. Aug 20, 2021 at 2:01 PM
    agrestic1
    agrestic1 [OP] New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    2016 , so I went to lower the spare tire and finally realized that I need to use the "security" socket tool to lower it...I got that to fit but of course it won't turn, Soaking it with penetrating oil..Is there a way to get the regular Hook on the tool end to fit into the hoist, looks like rubber is blocking the slots...Thanks.
  2. Aug 20, 2021 at 2:15 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Aug 20, 2021 at 2:17 PM
    frichco228
    Frank
    Virginia
    bulldog93 likes this.
  4. Aug 20, 2021 at 3:22 PM
    agrestic1
    2016 CrewMax
    Here it is
    GaryKramlich likes this.
  5. Aug 20, 2021 at 4:20 PM
    That's a spare tire lock that someone installed on your truck. The trucks don't come with them from the factory.
    bulldog93 and 15whtrd like this.
  6. Aug 20, 2021 at 4:55 PM
    agrestic1
    2016 CrewMax
  7. Aug 20, 2021 at 5:04 PM
    Black
    2014 Tundra Limited CrewMax
    I think you have replace the whole hoist. Ran in to this terrible design on my buddy’s Tacoma.
    The lock appears to be pressed in there very well. May be able to get it with a bunch of work but a new hoist is only $50 so not worth the hassle and worth the price to not have to fight with the key matching up on the side of the highway or a muddy trail.
  8. Aug 20, 2021 at 5:05 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    That black hook between your hand and the security socket is what you insert into the opening to lower the tire. It doesn’t actually hook in just insert the rounded end into the opening and turn slightly to make it engage and then unwind the mechanism to lower the tire.
    Save that security lock so you can remove a tire.
  9. Aug 20, 2021 at 5:15 PM
    Black
    Nope you have to put the key on the end as shown and line it up blindly and by feel only to crank it down. The lock is pressed into the slot that the hook makes contact with for us that don’t have the lock.
    It is a gigantic pain in the nut sack!!
  10. Aug 20, 2021 at 5:16 PM
    ScenicRoute
    well that’s silly.
  11. Aug 20, 2021 at 5:20 PM
    Black
    Beyond silly.
    Took us like 20 minutes to line it up properly. That picture there is no tire so you can easily see it.
    With the spare in place there is no way to see the key/lock orientation.
  12. Aug 21, 2021 at 4:09 AM
    agrestic1
    2016 CrewMax
    Super silly and stupid IMO. The wheel locks were a pain when the special socket had snapped & I'm not far from The McGard factory and got a replacement. Got rid of those.. Now this..after owning the truck for 5 years, shame on me I guess for not doing this sooner..May have to cut the chain and replace it. Thanks..
  13. Aug 21, 2021 at 8:56 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    I ran into this when I bought my truck, as the PO didn’t include the security socket to lower the spare.
    Because the plate that holds the wheel onto the chain has a spring, I used a pry bar to pry down one side of the plate and used a hammer to tap the plate over until it was off-center and tilted enough to pop through the center hub of the wheel. Once the wheel was off I could remove the lock so the standard square end of the jack tool lowers the wheel.
    Mine is just the standard steel wheel, not sure how an aluminum wheel would hold up to that steel plate sliding across it.
  14. Aug 21, 2021 at 9:01 AM
    agrestic1
    2016 CrewMax
    Thats an option, have a steel wheel spare,,,thanks..
  15. Aug 21, 2021 at 9:03 AM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I attach my drill to mine to make it light work. I only have the hook not security bit. Best of luck.
  16. Aug 23, 2021 at 1:45 PM
    agrestic1
    2016 CrewMax
    Finally able to loosen it & lower the spare tire down. Removed the old hoist and have one coming without the security key..Thanks again for the info.. BTW, the bolts are 8 x 1.25mm..
  17. Aug 31, 2021 at 3:43 AM
    agrestic1
    2016 CrewMax
    Update, I had ordered a used one from Ebay, it got cancelled by the seller and refunded. So for kicks, I heated the outside of where the security lock fits in the hoist , grabbed security lock with vice grip, hit the assembly with a hammer and it came out.. so I'm back in business with original setup..
    SAGE63 likes this.
  18. Jan 13, 2024 at 2:10 PM
    GaryKramlich
    GaryKramlich New Member
    Gary K
    2015 Tundra CrewMax TRD
    Thank you agrestic1! I also tried for 20 mins to lower the tire with just the hook, thinking it was for the tires.
    Nope, it seats in the mechanism and is there to keep the spare tire from being lowered by miscreants and ne'er-do-wells.
  19. Mar 16, 2024 at 6:40 PM
    aparker81
    aparker81 New Member
    Yeah, this took me way too long to realize than I'd like to admit. The security bit was lodged in the tire iron bag and I didn't realize it. After finally attaching it, the hoist was easily engaged. I dropped the spare on my '20 TRD Pro to prep and inspect it.
    Here's an image of the tire iron with security key inserted into the hoist
  20. Mar 17, 2024 at 5:42 AM
    agrestic1
    2016 CrewMax
    Wish mine looked that clean. I removed my security bit..
