Hmm. Time for a coolant change, or new hose?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MedCityMoto, Mar 15, 2024.
  1. Mar 15, 2024 at 7:18 PM
    MedCityMoto
    MedCityMoto [OP] SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    2016 5.7 with 120k - Noticed this pink buildup here at the edge of the hose/radiator connection, there was a little more that flaked away when I touched it:
    Coolant was replaced in 2022 when I purchased the vehicle (supposedly) and is still pretty light pink and clean:
    Think it's something I can fix with tightening the hose, swapping the coolant, or should I be thinking replacing the hose and clamp, or thinking bigger than that even?
    k0diak8o8 likes this.
  2. Mar 15, 2024 at 8:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    If that was mine, I would back that clamp off a few inches and pull the hose slightly back, then clean and reposition everything. If it continues to seep I would consider replacing that clamp. That coolant looks perfectly fine to me, especially if its only a few years old.
  3. Mar 16, 2024 at 8:17 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I agree with Tilly, when you disconnect to clean you can assess the hose too — replace if it’s getting stiff as that affects seal.
  4. Mar 16, 2024 at 8:35 AM
    MedCityMoto
    I'll do that then, thanks guys, by age of the coolant I was thinking of doing this drain and refill this summer anyway. So if I can just clean things up for now, place a better hose clamp there, and stop things where it's at, that'll do for a while.
    When the weather's more agreeable to a day in the shade, I'll drop my skid plate, drain the coolant, swap this hose, refill, and call it a day!
  5. Mar 16, 2024 at 10:03 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Use hose clamp or spring clamp? I’d remove clean and hose clamp it back.
