06 4.7 intake manifold gasket
Discussion in '1st Gen Tundras (2000-2006)' started by ScubaTuba, Mar 15, 2024.
  1. Mar 15, 2024 at 3:23 AM
    ScubaTuba
    ScubaTuba [OP] New Member
    Stephen
    2006 toyota tundra
    Just had valve job done and got a complete gasket kit. In that kit there is an upper intake gasket. Is this only for the cast version of the intake manifold? Has anyone ever tried to open up the plastic version?
  2. Mar 15, 2024 at 4:46 AM
    Yeah, it's only for the 00-04 trucks. What kit did you use? I've had numerous problems with non OEM/Felpro IM gaskets blowing out.
  3. Mar 15, 2024 at 5:06 AM
    ScubaTuba
    Stephen
    2006 toyota tundra
    It's a felpro kit, but on the plastic IM version the gaskets are just "rubber" ovals
  4. Mar 15, 2024 at 8:45 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Mine was two rubber orange pcs that went into the grooves on each side
    2x - 17171-50030 Manifold Gasket $13.56
