Compatible Engine for '07 4.7L?
Discussion in '2nd Gen Tundras (2007-2013)' started by Javostorm, Nov 30, 2023.
  1. Nov 30, 2023 at 9:27 AM
    Javostorm
    Javostorm [OP] New Member
    2007 Tundra SR5 4.7L
    Hello everyone,
    My 2007 SR5 suffered a complete engine failure recently, and I am now looking for a replacement engine/radiator for it-will a 4.7L from either an '05 or '06 be compatible?
  2. Nov 30, 2023 at 9:50 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I assume you overheated? That 4.7 is a tough one to break otherwise.
  3. Nov 30, 2023 at 11:36 AM
    Javostorm
    Must have been the case: no warning signs, tho, other than sudden flashing VSC and 4Lo lights on dash. No prior leaks of oil or coolant. I'll post a vid of the ticking sound it was making in the minutes before it completely shut down....
  4. Nov 30, 2023 at 12:46 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Wonder if your timing belt slipped a tooth or two
  5. Dec 1, 2023 at 3:48 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    why not rebuild the blown motor? is it completely wasted?
  6. Dec 4, 2023 at 8:47 PM
    Javostorm
    I've been told by a local mechanic that the intake is fused to the block; and that the radiator melted.....so not likely salvageable.
  7. Dec 4, 2023 at 10:39 PM
    Did it catch on fire?!
  8. Mar 14, 2024 at 9:28 PM
    tabbygreye
    tabbygreye New Member
    I basically have the same question. My 2007 4.7 SR5 had a timing belt malfunction at 210,000 miles, and is a lost cause. No, it didn't catch fire. Just seized up and not repairable. As we were having some very minor oil leakage before the mishap, we don't want to rebuild it. I want to put in a replacement engine, something not rebuilt, pulled from a junk yard truck, hopefully with fewer miles than what ours had. What year Tundra engines are compatible with my 2007 model?
    Thanks in advance.
