General Supercharger Thread
  1. Mar 14, 2024 at 5:30 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Assuming you aren't already FFV ( can't recall) I wonder if a FFV FPR would bump just enough to keep in 10's. Is the Injector DC hitting 100?
    Silver17 likes this.
  2. Mar 14, 2024 at 5:46 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Not saying the 650s aren’t also maxed, but I bet it wouldn’t matter since I don’t think the magnuson provided pump is up for meeting the capacity of 650s even at the base 43 psi, so it’s even less likely it would be able to effectively make the 650s work like 750s at 60psi. I have a feeling even the 650s at the current 43psi could do better and maybe not totally max out for him if the Maggie pump could feed them adequately. I’ve never been able to find the rating on that pump provided anywhere, but to feed 650s at 43psi it would have to be at least a 312lph pump running full out to come close to supporting them. Makes me wonder in this case, is the problem that the injectors are too small or the pump is too small or both.
    ARES35 and ViktorG like this.
  3. Mar 14, 2024 at 5:49 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    The mag pump is 340, so it should be capable of maxing out the 650’s
    HulkSmurf14 likes this.
  4. Mar 14, 2024 at 5:53 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah I spoke to sniv about that. We are comfortable with the way things are running now. Split second 11’s is fine with me personally.
    I may snag one and try but will need to see if my fuel pump can handle the extra pressure first otherwise it’s moot. They’re cheap enough to try if the pump can keep up. Or I upgrade the pump and ffv fpr lol but as sniv and I agreed on…it snowballs fast lol. Need 22 diff things to support one more thing. Once you get done with the last thing you’re like hmm maybe now I need this that and a built block if I keep going down this path lmao
  5. Mar 14, 2024 at 6:01 AM
    VWTim
    Corvallis, OR
    Very true. And with most of us using these trucks as trucks, they're not wrapped to redline except for draggy runs or data logging.
    I always have to remember that, as my past tuning experience was SCCA and hillclimb cars. Redline and occasionally overrev was the norm.
  6. Mar 14, 2024 at 6:04 AM
    Silver17
    Eastern PA
    How did you determine that it is a 340? Genuinely curious because I’ve never seen anyone say with confidence what the heck it is! I agree though it’s probably not worth messing with for you to enjoy the supercharger. DAP has tuned more of these than anyone and he tunes all of his to run around 11.2 IIRC, and his tuned trucks are not blowing up left and right by any means.
    reywcms likes this.
  7. Mar 14, 2024 at 6:20 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Another member here told me the size. It appeared the same as my old aero340 from a diff car. I just asked SCOL to confirm size so will report back with real data/confirmation
  8. Mar 14, 2024 at 6:26 AM
    koditten
    Kirk
    Midland of the Mitten
    I appreciate all the supercharger info. As a future member of this group, I'm slowly putting the information together that I can understand.
    I come across statements that I can not put into context.
    The above info on fuel pumps and injectors I was able to understand, except for the "11.2" reference.
    Without units, I'm drawing a blank what this means.
    If it's a stupid, common reference, please forgive my ignorance.
    I'm here to learn everything I can before I drop the coin.
  9. Mar 14, 2024 at 6:28 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    He’s talking about AFR or air/fuel ratio
  10. Mar 14, 2024 at 6:52 AM
    koditten
    Kirk
    Thankyou.
    I'll be honest, I thought it was quarter mile times. I'm thinking, that's pretty damn fast for a truck!
    HulkSmurf14 and ViktorG[QUOTED] like this.
  11. Mar 14, 2024 at 7:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  12. Mar 14, 2024 at 8:44 AM
    Silver17
    Eastern PA
    I didn’t think we were talking about an FFV pump, I thought we were talking about the pump supplied with the magnuson SC kit.
    Mdl[QUOTED] likes this.
  13. Mar 14, 2024 at 9:03 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I mixed up the posts. My dog was up early several times this morning....sleep!
    Thanks
    Silver17[QUOTED] and koditten like this.
  14. Mar 14, 2024 at 9:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I am comforted by your humility.
    I've been in this S/C'd arena for a couple years and am still sitting way up in the cheap seats.
    I'm still learning from these guys, albeit at a disastrously slow pace.
    If need be, come sit up here with me & we'll watch the game in unison.
  15. Mar 14, 2024 at 9:08 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    This finding is on the smaller pulley correct?
    NatesNightMare likes this.
  16. Mar 14, 2024 at 9:09 AM
    koditten
    Kirk
    I'll second that it's easy to lose the context of the posts.
    Please keep bombarding me with random data.
    I have never been a person to bounce my vehicle engines off the rev limiters, and I hope this doesn't change when I get a supercharger.
    But you never know.
  17. Mar 14, 2024 at 9:18 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yes with the 76mm sniv pulley
  18. Mar 14, 2024 at 9:20 AM
    Saltyhero13
    Gotchya. Wasn't sure what the stock size of the Maggie 2650 was but thanks for clarifying?
  19. Mar 14, 2024 at 9:26 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    If you would like a good old fashioned read on superchargers and their implementation on engines, pick up a copy of Supercharged by Corky Bell. Some of the info is a little dated, as technology has moved on since it was written, but the basics are the same.
  20. Mar 14, 2024 at 9:53 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Maggy 2650 stock pulley is 10mm bigger than snivs
    Saltyhero13[QUOTED] likes this.
  21. Mar 14, 2024 at 10:04 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yup.
    Stock 86mm
    Sniv 76mm for higher elevation... or low elevation looking for extra power
    Sniv 70mm for higher power in higher elevation... or low elevation in search of a hole in the block.
  22. Mar 14, 2024 at 10:11 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Although... it appears the mag 2650 is spinning around 16k rpms... with people running these blowers (other vehicles) at 25psi and around 28k rpms... THERE IS ROOM LEFT.
    I'm sure @snivilous would whip up a 55mm pulley for anyone with a built motor looking to see high hp numbers
  23. Mar 14, 2024 at 11:37 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just buy one and set it on your mantel for that day!
  24. Mar 14, 2024 at 12:40 PM
    carn_dogg
    Pat
    Eastern Shore MD
    I
    might be worth it for the comments from my wife alone
    NatesNightMare and Mdl[QUOTED] like this.
  25. Mar 14, 2024 at 2:38 PM
    NatesNightMare
    Pinetop Az
    Hoping to get an 80mm cause even up here at 7k ft with the 76 im hitting my limit like you at sea level :notsure: though not as bad
    Mdl likes this.
  26. Mar 14, 2024 at 4:46 PM
    ARES35
    ARES35 New member for life
    Mile high
    Have any of y'all had a P0101 MAF sensor code? Randomly came on during the back end of a 9 hour road trip. Reset it hasn't came back but haven't hit the road to test since were getting pounded with snow.
  27. Mar 14, 2024 at 4:52 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Are you getting near the 5V limit?
    Mdl and ARES35[QUOTED] like this.
  28. Mar 14, 2024 at 4:59 PM
    ARES35
    Mile high
    Looks like my max was @4.35V. Was in cruise control moving along when she popped up.
    Mdl likes this.
  29. Mar 14, 2024 at 5:01 PM
    snivilous
    SW UT
    I know my truck once or twice a year will throw a random MAF code. I wouldn't be worried about it unless it becomes a common occurrence.
  30. Mar 14, 2024 at 5:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Was just going to say same. Random p0101 codes would pop up when I wasn't even at max. Hasn't happened in a while.
    snivilous[OP] and ARES35 like this.
