  1. Mar 12, 2024 at 6:42 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Added bed lighting. It’s tied into the cargo light circuit.
    JasonC., Tundra2, txagg and 16 others like this.
  2. Mar 12, 2024 at 6:46 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    How did you tie yours in exactly? I've been thinking about doing this but haven't done it yet.
    87warrior likes this.
  3. Mar 12, 2024 at 6:49 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Thats pretty tits
  4. Mar 12, 2024 at 6:49 AM
    VR6T
    Now do the colight mod and you'll be doneskis
  5. Mar 12, 2024 at 6:49 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Behind the dash going up to the left "A" pillar is the wiring for the dome, cargo and high mount lights. The cargo light wire is red with a black stripe. The ground is white with a black stripe. I tied into that and ran a line down through the gromet under the carpet and to the back. Then tied all lights in together hiding the wiring as far up into the inner parts of the bed as I could reach.
  6. Mar 12, 2024 at 7:43 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Sweet. What lights did you use?
  7. Mar 12, 2024 at 7:46 AM
    The Black Mamba
    DFW
    Imma keep it stock
  8. Mar 12, 2024 at 8:16 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Pressed my wheel hubs back into the new bearings / steering knuckles. Installed my CV axles, new lower ball joints, got the steering knuckles in, then the sway bar. Got started on putting the brakes back on then had to stop.
  9. Mar 12, 2024 at 11:37 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Its pretty easy, just need access to an air compressor. You can use the video shifty posted and, yes, the part number I posted is for 13WL calipers not the WE.
    Thanks, it took me about 3 hours and I was taking my time. I just used a wire wheel on a drill. Scothbrite would probably be a good option too.
  10. Mar 12, 2024 at 2:47 PM
    Doing a thing. Shout out to @bmf4069 for the hookup. These will be the sexiest thing on my truck. @shifty` approved gold.
  11. Mar 12, 2024 at 2:55 PM
    cjmustang69
    cjmustang69 New Member
    2005 Grey Tundra Limited 2WD
    After picking this Tundra up on 2/29/24 and then traveling from 3/1/24 through 3/10/24 - I was able to spend a little time cleaning it up today. I had some leftover headlight cleaning materials, which I used on headlights and fog lights. While not perfect, they cleaned up pretty nice. I washed it and put a quick coat of wax on it. Overall, pleased with how it cleaned up. Also drove it to landfill this morning. Really like the engine/transmission combination. Has plenty of power and isn’t constantly shifting when in high gear. Last item I did was remove the glovebox handle (it was broken). The video on how to remove handle from this forum was so very helpful. Now I need to see what I need to do to get the glovebox back in working condition.
  12. Mar 12, 2024 at 3:07 PM
    kentuckyMarksman
    I just installed those yesterday. Definitely an upgrade over stock. Hardest part was holding the end link bolt still while adjusting the nut over top the sway bar, but definitely still doable though.
  13. Mar 12, 2024 at 3:32 PM
    That could have been better described in the instructions. Need a skinny wrench. Or what I did was loosen the bottom nut to slide the base out to get my crescent on it. Then retighten the bottom nut.
    oscardog86, bmf4069, BroHon and 3 others like this.
  14. Mar 12, 2024 at 4:25 PM
    Also stuck the Shifty` Approved sticker on my 2.5Gen frame since it’s so clean. Hope that’s cool. :D
    kidding!!!
    txagg, bmf4069, 805Tundra and 3 others like this.
  15. Mar 12, 2024 at 4:37 PM
    I think the hardest part is holding the lower cam parallel to the ground and preventing it from kicking up while tightening it down. I can't recall if that tidbit is in the instructions they provided with the end links, but it was in one of the versions I either found at their site or got with my replacement bushings...
  16. Mar 12, 2024 at 4:49 PM
    kentuckyMarksman
    Nice! Wish I thought of that. I had an old cheap 9/16" wrench and I thinned it out a little using a bench grinder to make it fit.
  17. Mar 12, 2024 at 5:14 PM
    bfunke
    bfunke Tundra Curmudgeon
    Nothing to my Tumdras. New valve cover gaskets on my 05 Burb. Looks OK for 310K miles.
    Voss, txagg, oscardog86 and 8 others like this.
  18. Mar 12, 2024 at 6:19 PM
    I used cone wrenches that are specifically used to bike wheel teardown. Worked great.
  19. Mar 12, 2024 at 8:41 PM
    ToyotaDude
    ToyotaDude Member
    to 249 for now....
  20. Mar 12, 2024 at 8:49 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Drove mine to work.
  21. Mar 13, 2024 at 5:51 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Mocked up the Auxbeams this morning
    Voss, khooiii, artsr2002 and 11 others like this.
  22. Mar 13, 2024 at 5:54 AM
    Whoa, daddy likey
    Tundra2, BroHon, bmf4069 and 2 others like this.
  23. Mar 13, 2024 at 8:47 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    @The Black Mamba
    How many other people would like to see a glamor shot of those sweet ass gold starfish wheels on the truck!? :boink: ;)
    (unless I missed it somewhere)
    Tundra2, Mr.bee, shifty` and 5 others like this.
  24. Mar 13, 2024 at 8:51 AM
    Tundra2, artsr2002, bmf4069 and 4 others like this.
  25. Mar 13, 2024 at 8:53 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    More gold!
    Tundra2, The Black Mamba and bmf4069 like this.
  26. Mar 13, 2024 at 8:55 AM
    FishNinja
    Lee
    06DC2wd
    damn 2 more in yellow or amber would look the tits.
  27. Mar 13, 2024 at 9:00 AM
  28. Mar 13, 2024 at 9:00 AM
    The Black Mamba
    DFW
    Imma keep it stock
    I haven't even seen them ON the truck yet :rofl:
  29. Mar 13, 2024 at 9:03 AM
  30. Mar 13, 2024 at 9:09 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Voss, KNABORES and bmf4069[QUOTED] like this.
