Baffling electrical question
Discussion in '2nd Gen Tundras (2007-2013)' started by AnthTreeGuy, Mar 5, 2024.
  1. Mar 5, 2024 at 10:51 PM
    AnthTreeGuy
    AnthTreeGuy [OP] New Member
    Anthony
    2010 tundra platinum
    Howdy, I don’t expect this one solved here. It’s too weird. I suspect I need an ecm. 2010 tundra with intermittent electrical problem. Audio system, power outlets, power mirror adjustment, dome lights coming on as soon as ignition turned off are all failing together intermittently. Here’s another really odd part. The power outlets turn on once ignition is turned off intermittently. Never been through deep water. Any thoughts or idea where to start without just buying a programmed Toyota ecm and saying eff it? $800 seems like an expensive guess.
  2. Mar 6, 2024 at 4:27 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    First, Welcome from LA (Lower Alabama)!
    Those things come ON when you turn off the ignition?? This is a long shot, but check your battery terminals to make sure they are in good shape and tightened own for a good connection. Also look for a loose ground. What was the first symptom and when did it start?
    Radarninja likes this.
  3. Mar 6, 2024 at 4:50 AM
    Radarninja
    Radarninja New Member
    Ca
    Agreed with above post, my first thought was battery, make sure you’re voltage is good.
  4. Mar 6, 2024 at 11:00 AM
    AnthTreeGuy
    Anthony
    Battery voltage is perfect. The first time it acted up I was just sitting at idle and the audio system shut off. The only thing that seems to come back on most of the time when I turn ignition to off is the power outlet.
  5. Mar 6, 2024 at 11:01 AM
    AnthTreeGuy
    Anthony
    It started maybe two months ago.
  6. Mar 6, 2024 at 11:06 AM
    Are these functions all controlled by the integration relay?
  7. Mar 6, 2024 at 11:20 AM
    2mchfun
    Possibly rodent damage, look for signs of rodents. Check the cabin filter too.
    Radarninja and Bakershack like this.
  8. Mar 6, 2024 at 11:22 AM
    2mchfun
    Just noticed that you have a platinum. Does the column adjust automatically every time? Sometimes the wires go to crap from frequent movement.
    KNABORES likes this.
  9. Mar 6, 2024 at 11:59 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I 2nd this possibility as well.
    2mchfun[QUOTED] likes this.
  10. Mar 6, 2024 at 1:45 PM
    AnthTreeGuy
    Anthony
    Steering column does adjust automatically. I’ll pull the plastic apart and have a look. Good thinking.
    2mchfun likes this.
  11. Mar 6, 2024 at 5:07 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Buying ECUs and throwing them in trucks generally fixes nothing. This is definitely not Engine ECU stuff, if anything Body Control module.
    Most likely a wiring, relay, or fuse problem.
    The better in the detail you can describe what’s going on, the better we can help.
    Electrical system in this truck is not crazy advanced, any of it can be fixed if you first fully understand what’s it’s doing wrong.
    2mchfun likes this.
  12. Mar 6, 2024 at 5:33 PM
    AnthTreeGuy
    Anthony
    We’ve got a winner 2mchfun! The short is in the steering column. When I retract the steering wheel everything comes back on. I’ll pull the wheel and cover, find the short and let you know. Thanks!
  13. Mar 12, 2024 at 2:36 PM
    AnthTreeGuy
    Anthony
    Why would anyone do this?!
    coTony likes this.
  14. Mar 12, 2024 at 2:42 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :eek::eek::eek::eek::eek::eek::eek::eek::eek:
    2mchfun likes this.
  15. Mar 12, 2024 at 2:47 PM
    coTony
    Tony
    Montrose, CO
    Man seeing shit like that burns my ass! Then people either get paid for that or they pat themselves on the back for doing such a good job.
    Very good in finding that before things caught fire!
    @2mchfun :hattip:
    2mchfun likes this.
  16. Mar 12, 2024 at 2:47 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    His name was Bubba.
  17. Mar 12, 2024 at 2:48 PM
    coTony
    Tony
    Montrose, CO
    Sorry but after seeing that I would be all through my dash looking for stupid shit
  18. Mar 12, 2024 at 3:25 PM
    2mchfun
    Maybe trying to steal it:notsure:
