  1. Mar 11, 2024 at 7:28 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Used the extra hour of light yesterday to remove the shim from my factory gas pedal. Of course I was attempting to calm some of the twitchiness that plagues these trucks. Upon removal I must've cocked the plastic barrel the shim sits behind b/c after removal the pedal wouldn't move at all. Sunday night, light fading fast, staring at Monday morning....yeesh. After a few minutes of fiddling, it pops and re-aligned itself. Off for a test drive and THAT'S MUCH BETTER :)
  2. Mar 11, 2024 at 11:37 AM
    Graeman
    Graeman New Member
    Todd
    Jeep Hauler
    2” lift, 295/70r18, airlift bags
    I changed out the cruise control module and replaced the dry rot roof strips. Also added a Wolfbox camera system with front/rear cameras and gps.
  3. Mar 11, 2024 at 12:34 PM
    JohnnyMoxon69
    JohnnyMoxon69 New Member
    2011 Tundra Limited Crewmax
    Do you have pics of it installed and the placement of the camera?
  4. Mar 11, 2024 at 2:59 PM
    Graeman
    Graeman New Member
    Todd
    Jeep Hauler
    The camera system is the Wolfbox 850. I also bought the hardwire kit for permanent installation instead of the lighter socket. The rear camera is mounted on top of the 3rd brake light. So all of the wiring stayed inside the cab. I disassembled the 3rd brake light and fed the camera up through the headliner and out the roof and double sided sticky taped the camera on top.
  5. Mar 11, 2024 at 3:02 PM
    Graeman
    Graeman New Member
    Todd
    Jeep Hauler
    The front camera is attached to the mirror. In my Jeep I use an Amazon FooKoo 10” screen dual camera system that has night vision capabilities and both of those cameras are mounted outside of the Jeep. They work great on the trails when I need to see the trail - Moab, Utah has very steep trails and you only see the sky when looking out the windows.
    joseph_womack likes this.
  6. Mar 12, 2024 at 11:45 AM
    Condor94
    Condor94 New Member
    2008 Toyota Tundra
    FOX 2.5 275/70R18 Coastal Offroad Bumper
    Finally finished the install of my relay box. Here is the before and after:
  7. Mar 12, 2024 at 12:01 PM
    Graeman
    Graeman New Member
    Todd
    Jeep Hauler
    So this is like an Auxbox. Do you have a dash/switch panel or individual switches and outlets inside the truck?
  8. Mar 12, 2024 at 1:55 PM
    Condor94
    Condor94 New Member
    2008 Toyota Tundra
    I went with some switches from air on board that fit into the blanks in the dash.
  9. Mar 12, 2024 at 2:05 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Looks like we went with the same relay box off Amazon! (Old photo)
  10. Mar 13, 2024 at 5:19 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Picked it up from the shop today. It's sooooo smooth!
  11. Mar 14, 2024 at 6:34 AM
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Thanks for the kind words, as Oldguy said I'll customize and make it however you like. Im planning to build a full plate version soon
    joseph_womack and OldGuy03 like this.
  12. Mar 14, 2024 at 8:53 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Rolled over to 200,000 while driving to pick up my new boat!
  13. Mar 15, 2024 at 4:54 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    New shoes (Nokian Outpost-nat) and new to me TRD wheels mounted up the ol’ longbed… courtesy of the local tire shop and many digitally transferred dollars.
  14. Mar 15, 2024 at 9:25 PM
    j5offroad
    j5offroad New Member
    Wisconsin
    2010 Tundra SR5 5.7L DC
    Hey, how do you activate the sequential turn signals? I have these headlights and haven’t been able to figure it out
  15. Mar 15, 2024 at 9:39 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Have you tried voice activation?
    OldGuy03 likes this.
  16. Mar 16, 2024 at 7:27 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Hit 210K this morning
  17. Mar 16, 2024 at 7:53 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My first instinct is "the clapper" when asked how to turn on/off, anything.
    ...It never works
  18. Mar 16, 2024 at 8:07 AM
    COTundie
    Trey
    Pretty things
    Picked up an early birthday present, and have been playing with mounting location and addition of x-gauges.
    Stoked that I'm able to monitor tire pressures and trans fluid temperatures. They were the main motivation for sourcing a Scan Gauge II. Haven't been able to get tire temperature to display, nor the elevation code for some reason, but those aren't a big deal to me.
    Also, finally wrapped the upper, passenger "oh shit handle" with paracord to match all the other handles I did some time back. Can see one of the sweet Boost Auto tow mirrors installed earlier this year too!
    chugs, dondino, Mountun Goat and 2 others like this.
  19. Mar 16, 2024 at 8:40 AM
    Shanet421
    San Diego,CA
    Haha that’s so 90s! Nowadays if it’s not voice controlled it’s soon to be thought activated
    :monocle: :nuclear:
  20. Mar 16, 2024 at 2:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The instructions left a bit to be desired. I had to call the customer support for help, even sent them pics of the harness connections
    Turned out I had bypassed some of the harnesses /connections on the new lights. All of the harnesses have to be connected. Once every harness was connected the DRLs worked.
    If all of your harnesses are all connected I would give them a call.
    Good luck!
  21. Mar 16, 2024 at 4:02 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    I replaced my drip rails and driver's side window switch with an all auto-up/auto-down one.
    Medicineman and COTundie like this.
  22. Mar 16, 2024 at 8:09 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Car wash day.
    chugs, Ohannon7, Mountun Goat and 8 others like this.
  23. Mar 16, 2024 at 9:33 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Haha same.
    I also reset the VSC and cleaned out the inside of the truck.
  24. Mar 16, 2024 at 10:47 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    https://optoffroad.com/products/00-20-tundra-scangauge-mount
    thats the mount I have for mine, it works great, I can get you some pics tomorrow, but they have pictures on their website as well
  25. Mar 17, 2024 at 10:56 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Found that my wp is leaking again. Lasted less than 5yrs.
    Ordered WP, idler pulley, tensioner pulley, thermostat, rad cap, and belt. Figured I'd get it all taken care of while I have it apart again. I'll go ahead and drain/fill the PS also.
    PhotoNerd likes this.
  26. Mar 17, 2024 at 11:33 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's just irritating.
  27. Mar 17, 2024 at 11:51 AM
    Windsor
    Homeless in Oregon
    Some.
    It's my fault, got the last one from napa. Ordered from Olathe Toyota this time.
  28. Mar 17, 2024 at 3:58 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Before/after. I want to put the old voltmeter in the bed with some USB charging outlets so I upgraded the one in the cab to a nicer OLED display. So fancy voltmeter.
  29. Mar 18, 2024 at 2:24 PM
    j5offroad
    Wisconsin
    Thanks for the reply, I appreciate the help. I wasn’t able to get to it over the weekend, but I think a call with Alpharex support is definitely in my near future.
    Trooper2[QUOTED] likes this.
  30. Mar 18, 2024 at 3:44 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    Mounted a Smitybuilt 6x6 awning on the camper rack. Fishing rod tube is in the works next.
