Adding TRD Pro hood on other trims?
Discussion in '3rd Gen Tundras (2022+)' started by Progressfarms, Jan 8, 2022.
  1. Feb 28, 2024 at 11:30 PM
    #91
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Is this a replacement for the iforce badge or are you placing on a flat hood with no badging?
    I just want a regular hood. I’ve decided that I hate the plastic on my hood.
  2. Feb 29, 2024 at 11:28 AM
    #92
    tundraxp23
    tundraxp23 New Member
    How did you get the Off Road Letters to fit? They won't fit on mine. Thank You
  3. Mar 2, 2024 at 12:48 AM
    #93
    tundraxp23
    What did you use for the background? Was it vinyl wrap? If so, does it adhere well with heat? lastly, what did you use to adhere the letters? Sorry so many questions. Thank You
  4. Mar 10, 2024 at 5:57 PM
    #94
    theTupper
    theTupper New Member
    Jake
    2024 Limited Crewmax HV, Lunar Rock
    Thank you to the many members in this thread who served as inspiration for me to jump in and modify my own set of vents.
    End result:
  5. Mar 10, 2024 at 6:13 PM
    #95
    :101010:
    theTupper[QUOTED] likes this.
  6. Mar 10, 2024 at 6:17 PM
    #96
    Taikowaza
    Taikowaza New Member
    Amazing work!!!! Pls let us know your process! The lights are fantastic too! Very interested in learning how you got the new text “Tundra” perfectly aligned in the TRD part, without needing to worry about the previous TRD pro stippled background
  7. Mar 10, 2024 at 6:19 PM
    #97
    theTupper
    Jake
    Thanks!
    Click through to my build thread (link in signature). I've got the process outlined there. Let me know if you've got questions. :)
    Taikowaza[QUOTED] likes this.
  8. Mar 10, 2024 at 6:22 PM
    #98
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Have you already mounted them to your truck? You wouldn't happen to live in So Cal, would you?
  9. Mar 11, 2024 at 5:32 AM
    #99
    Taikowaza
    Thanks for your post @TacomaTRD4x402 ! I still haven’t mounted the parts to my Tundra. Have been searching for the right parts and process to make the change from Pro to Offroad or something new. I ordered some Amazon and ebay parts but some clearly looked fake (TRD lettering font etc) and others sizing was off etc. I don’t want to mount letters to a damaged digicamo backing after removing the PRO. Definitely got inspired by @theTupper ’s new build, looks super clean. I don’t live in SoCAL I’m afraid! However I’m definitely willing to ship my parts as needed for some quality work!
    #99
  10. Mar 21, 2024 at 11:31 AM
    #100
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    How hard is it to remove?
  11. Mar 22, 2024 at 7:54 AM
    #101
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Couldn't say as the one installing the PPF removed it, but I would think some heat to make the double-sided tape easier to separate and the bolt/nut on the underside.
  12. Mar 22, 2024 at 12:46 PM
    #102
    theTupper
    Jake
    Easy peasy.
    One 10mm nut (under the hood liner on the underside of the hood). Pop the clip that holds the hood liner and reach in there with a socket. After that, it's just clips and 3m tape. Mine came up with minimum effort.
  13. Mar 22, 2024 at 1:34 PM
    #103
    Ipaddick
    Ipaddick New Member
    Canada
    Heat the 3m tape?
  14. Mar 27, 2024 at 12:57 PM
    #104
    theTupper
    Jake
    I was prepared to, but I didn't end up needing to. The factory installed tape on my existing iForce badges seemed to be there in spirit only. It came off clean with literally NO resistance.
    Ipaddick[QUOTED] likes this.
  15. Apr 7, 2024 at 10:04 AM
    #105
    zcardoza1
    zcardoza1 New Member
    Zack
    2022 Tundra Ltd.
    Does anyone know if both TRD and Pro lettering are removable with screws or does one need to be filed out? I might be a complete insert from someone, but prefer to buy the hood vents myself for cheaper.
  16. Apr 7, 2024 at 10:10 AM
    #106
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I saw a website somewhere that sells these vents with customizable inserts. Can’t remember the site though. They had a template if you wanted to drill the holes too.
  17. Apr 7, 2024 at 10:53 AM
    #107
    nkawal
    nkawal New Member
    2024 Tundra Limited
    Rave off road sells them.
  18. Apr 7, 2024 at 12:46 PM
    #108
    theTupper
    Jake
    Both TRD and PRO are plastic welded via plastic rivets in on the back side. A dremel made easy work of removing them. <5 min.
    Rave has 3d printed ones. I don’t personally like them. I laser cut some blank inserts for mine and cut vinyl for the wording so I could change color/design on the cheap in the future if I want. DM me if you want some. I could hook you up. (See my build thread for details on what’s involved).
    zcardoza1[QUOTED] likes this.
  19. Apr 7, 2024 at 1:25 PM
    #109
    Did you ever do this?
  20. Apr 7, 2024 at 2:49 PM
    #110
    TacomaTRD4x402
    Southern California
    Hey there Jim,
    I did not. Got caught up with too many other mods. It is still on the list to just see if matches up. Need to find someone local who has theirs removed. Don't really want to buy one and it not fit.
  21. Apr 7, 2024 at 2:51 PM
    #111
    :thumbsup:
    Just wondering if it does fit.
  22. Apr 7, 2024 at 2:54 PM
    #112
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I can’t believe this thread is still a going thing.
    So many poseurs. The kind of guys who buy a V6 model Mustang or Camaro and put GT or SS badges on it.
    You’re only playing pretend.
    Black widow TRD likes this.
  23. Apr 7, 2024 at 3:03 PM
    #113
    TacomaTRD4x402
    Southern California
    I don't think it's being a poser. If you read through the thread you'll see lots of mention of removing the "Pro" and replacing it with something else. It's for the aesthetics. Does swapping out my Sport grille to a Pro grille make me a poser? If so than that would probably make more than 90% of the Tundra community posers. :confused:
  24. Apr 7, 2024 at 3:10 PM
    #114
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Technically the TRD pro are posers too. The hood vents on the pro also does nothing.
  25. Apr 7, 2024 at 3:21 PM
    #115
    Coal Dragger
    Kung Fu Dick
    The non functional vents hint at more power and torque. But yeah, they’re non functional.
  26. Apr 18, 2024 at 6:14 PM
    #116
    Reaper1911
    Reaper1911 New Member
    2024 White Tundra Limited Off-Road
    -TRD pro reaper bumper panels/fender flares -Catalytic converter cover -Bak revolver x4s tonneau cover
    I just bought a set from Rave, but curious why you don't like their vents. You got me second guessing my purchase now.
  27. Apr 18, 2024 at 6:26 PM
    #117
    TacomaTRD4x402
    Southern California
    Are you in So Cal?
  28. Apr 18, 2024 at 6:36 PM
    #118
    Reaper1911
    I might be stranger danger, why?
  29. Apr 18, 2024 at 6:40 PM
    #119
    TacomaTRD4x402
    Southern California
    Lol :anonymous:
    I've got a 2.5 gen and stumbled into this thread and it got my curiosity juices flowing. If you see my posts early on in here, you'll see what I'm trying to find out. Just want to find out if these things match up to the 2.5 gen hood curve.
    See post # 72 and 74
    Tundrastruck91 likes this.
  30. Apr 18, 2024 at 6:46 PM
    #120
    Reaper1911
    Are you asking to meet up late at night alone so you can see if they'll fit on your hood before I install them?
