Leak from Engine Block Blown Head Gasket?
Discussion in '1st Gen Tundras (2000-2006)' started by newb24, Mar 7, 2024.
  1. Mar 7, 2024 at 11:02 AM
    newb24
    newb24 [OP] New Member
    01 V8 197k
    Do these wet spots look like the head gasket is blown? Something else? Sorry, it’s a bit difficult to take photos of.
  2. Mar 7, 2024 at 12:22 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Head gasket and valve cover gaskets are two VERY different things. Looks like your valve cover gaskets are seeping. Might just be able to torque bolts to proper values.
    newb24[OP] and AZBoatHauler like this.
  3. Mar 7, 2024 at 3:22 PM
    shifty` Ten EV 12's so you know I raise hell
    Your valve cover gasket is leaking. Additionally, you spark plug tube gasket is leaking on that one cylinder. You should refresh all of them. Everything you need to know is here, or linked from the reply I made with part numbers here: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    Whatever you do, stick to either OEM gaskets OR Felpro. And get quality FIPG to do the job right. Expect to pay upwards of $600 (based on someone else's recent quote) or more to have a shop do the work for you.
    newb24[OP] and KNABORES like this.
  4. Mar 7, 2024 at 6:16 PM
    newb24
    Whew, thanks so much for your replies. I really appreciate it. I’ll start with torquing the bolts and follow your guide, @shifty` when I have a chance. Do you have any input on how bad it is to drive like this until I have the time/money to fix it?
  5. Mar 7, 2024 at 6:40 PM
    Those leaks don't look major. Check your oil. If OK, check again in a week and see if it's the same or close. If so, check again in 2 weeks. If cool, keep checking monthly until you resolve the issue.
    Note there's a snap risk with valve cover bolts. It's very easy to over-tighten. Proceed with caution.
  6. Mar 7, 2024 at 6:51 PM
    AZBoatHauler
    So.Arizona
    I’d say it would be hard to find a 4.7 that’s spotless with 200k miles on it. Snug the cover, spray some brake clean and run it imo.
    I would replace the leaking spark plug tube o ring.
    newb24[OP] likes this.
  7. Mar 8, 2024 at 6:20 AM
    newb24
    Awesome. Thanks so much for your help everyone! The oil looks fine for now, and I’ll keep an eye on it. I’ll be sure not to over-tighten the bolts as well.
  8. Mar 8, 2024 at 6:38 AM
    Use an inch pounds torque wrench. Torque to spec. Don't guess.
    newb24[QUOTED][OP] likes this.
  9. Mar 8, 2024 at 7:45 AM
    bfunke
    bfunke Tundra Curmudgeon
    I would replace the valve cover gaskets, plug tube seals and valve cover bolts. You will need a tube of FIPG as well. That keep you good for. Another 150-200K
  10. Mar 10, 2024 at 4:35 PM
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    Not super urgent, but like others have said, check your oil often. Being that it looks like its only leaking at the spark plug gaskets and not the actual valve cover gasket you're probably not loosing that much oil, but still good to check.
