Only way to lift the differential is with bigger tires?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Samoan Thor, Sep 11, 2017.
  1. Sep 11, 2017 at 8:29 AM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I've read that the only way to lift the differential is with bigger tires, any lift kit only lifts the body, is that true? I'm enjoying off-roading more and I want more protection so skid plates is a must, plus sliders, a diff skid would be nice but haven't seen one for tundras yet.
    CJ21, T-Rex266 and Toytec Lifts like this.
  2. Sep 11, 2017 at 8:39 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Technically speaking, yes the only way to get more diff clearance is larger tires, but the only way to fit larger tires is by lifting the truck.
    Skid and slider wise, RCI has a nice selection!!
    Here are a few links to the ones they currently offer (unfortunately at this time there is no rear diff skid).
    Front skid: http://toyteclifts.3dcartstores.com...007-2017-Tundra-Front-Skid-Plate-_p_1659.html
    Trans/ Tcase skid: http://toyteclifts.3dcartstores.com...smissionTransfer-Case-Skid-Plate-_p_1660.html
    Sliders: http://toyteclifts.3dcartstores.com...7-17-Tundra-Heavy-Duty-Side-Steps_p_1662.html
    Shoot me a PM anytime with any questions!
    -David
    T-Rex266, csuviper and NewImprovedRon like this.
  3. Sep 11, 2017 at 8:40 AM
    Toytec Lifts
    Denver, CO.
    Welcome to the forum by the way!! :thumbsup:
    Nice Tundra!!
    NewImprovedRon likes this.
  4. Sep 11, 2017 at 8:49 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    David is correct. The diff height is not affected by a lift, only larger tires will increase that clearance off the ground. If you want to go up to a 35 you will need to lift to fit them.
    Toytec Lifts likes this.
  5. Sep 11, 2017 at 8:58 AM
  6. Sep 11, 2017 at 9:01 AM
    csuviper
    Broomfield, CO
  7. Sep 11, 2017 at 9:22 PM
    Samoan Thor
    Thanks David, good information you have provided!
    True, I have seen some with leveled, even stock height able to fit 35's with some minor cutting.
    Thanks Sean, badass truck there brofessor
    Hmmm, interesting, thank you
    Toytec Lifts[QUOTED] likes this.
  8. Sep 11, 2017 at 9:25 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Do you even lift bro?
    Sorry had to... :rolleyes:
    Samoan Thor[OP] likes this.
  9. Sep 11, 2017 at 9:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Portal axels .....
