“Hub-Centric” Rings
Discussion in '3rd Gen Tundras (2022+)' started by darksidetundra, Mar 4, 2024.
  1. Mar 4, 2024 at 11:19 AM
    darksidetundra
    darksidetundra [OP] New Member
    • My dealer said that I don’t have “hub-centric” wheels and said I needed a ring. What size, you can tell, can anyone recommend I get? Link would be great. 18inch KMCs
    Also, how much of an issue is this. Brought my truck in originally to have wheels balanced after going off-roading and noticing a shake.
  2. Mar 4, 2024 at 12:10 PM
    pursuit2550
    pursuit2550 New Member
    Wheels are usually hub or lug centric or like OEM, both. Call KMC and see what they tell you. I remember long ago wheels would bring a centric ring already if it needed it.
  3. Mar 4, 2024 at 12:46 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  4. Mar 4, 2024 at 12:53 PM
    2mchfun
    Best option is to buy wheels with the correct center bore and sell what you have to help fund or maybe fully fund the purchase. The wheel bore and the hub diameter can both be measured with a sliding caliper tool, one side is for outside diameter, the other is for inside diameter.
  5. Mar 4, 2024 at 4:59 PM
    darksidetundra
    Is there any potential damage to the vehicle if I don’t get the rings or replace the wheels as you mentioned?
  6. Mar 4, 2024 at 5:00 PM
    darksidetundra
    I’m guessing you had the same or similar issue with the wheels you purchased, correct? Is this a viable fix for wheels that aren’t necessarily made for your truck but you want to put them on anyways?
  7. Mar 4, 2024 at 5:07 PM
    2mchfun
    If you consider broken lug studs an issue, you should get the situation addressed quickly.
  8. Mar 4, 2024 at 6:08 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Many wheels are designed to fit many vehicles so they make the hub size large. Buy some rings. It’s an easy/cheap fix.
  9. Mar 4, 2024 at 6:13 PM
    darksidetundra
  10. Mar 4, 2024 at 6:31 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    Did you not get rings with the wheel purchase? Anytime I e purchased non hub centric wheels (tirerack.com) hub rings were included with the wheels.
  11. Mar 4, 2024 at 6:36 PM
    darksidetundra
    Ironically I bought them off my dealer manger and I didn’t know anything about needing them.
  12. Mar 4, 2024 at 6:45 PM
    NickBrewer
    They should work just fine, that is the same hub bore as the Method wheels I have on my Tundra.
  13. Mar 4, 2024 at 6:49 PM
    darksidetundra
    Ordered! Thanks for the help man. Do you think I have caused any damage riding like this for a little over a year?
  14. Mar 5, 2024 at 9:40 AM
    Oldandfat
    Cannuckastan
    dealer should have known, and provided rings.
    yakeng likes this.
  15. Mar 9, 2024 at 4:48 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    Can someone post up a link to some plastic hub rings? 95.1mm to 106.25mm Going to use these with my Method 318s, only ones I can find are aluminum.
  16. Mar 9, 2024 at 9:36 AM
    NickBrewer
  17. Mar 9, 2024 at 11:39 AM
    codename607
    Chicago
    2024 Tundra
