Anybody had any luck with inchannel wind deflectors?
Discussion in '3rd Gen Tundras (2022+)' started by LR Pro 2022, Mar 8, 2024.
  1. Mar 8, 2024 at 4:46 PM
    LR Pro 2022
    LR Pro 2022 [OP] New Member
    2022 LR Pro
    Just wondering if anybody’s wind deflectors are causing the window to pop back down “safety measure” after installing wind deflectors. Id like to get some but don’t really want my window constantly retreating when rolling it up. Let me know the brand and style if they work good or if they pop back down on auto up.Thanks for any info.
  2. Mar 8, 2024 at 5:01 PM
    devron11
    devron11 New Member
    Ron
    Denver
    AVS brand work great on my 22 SR5
    mrfreeman likes this.
  3. Mar 8, 2024 at 5:05 PM
    LR Pro 2022
    2022 LR Pro
    Thanks devron, how long you had them?
  4. Mar 8, 2024 at 5:07 PM
    devron11
    devron11 New Member
    Ron
    Denver
    August '22
  5. Mar 8, 2024 at 5:23 PM
    LR Pro 2022
    2022 LR Pro
    If youve had them that long with no issues, then im not worried about it, thanks for the info
    devron11 likes this.
  6. Mar 8, 2024 at 5:54 PM
    mrfreeman
    mrfreeman New Member
    Kenny
    Buffalo
    2024 Tundra SR5
    I have the same on my 22 and have had them about as long. I’ve had 0 issues through 2 winters.
  7. Mar 8, 2024 at 6:06 PM
    dreamcatcherxo
    dreamcatcherxo New Member
    i have the EGR's and their installation instructions say to sort of pull the window visors out a bit while rolling up the window. when the window is fully up, keep holding the button so it works its way upwards. then leave it closed for as long as possible (overnight maybe?) so it seats in there. i had a few problems with it not accepting the window visors on my passenger side, but i was able to get it to fit properly without the safety mechanism rolling back down.
  8. Mar 8, 2024 at 7:50 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I have the EGRs as well. They look great and for the most part operate as they should. Every once and awhile the windows struggle to close due to safety mechanisms. Only the fronts, never had an issue with the rears. But …I’m starting to experience wind noise… I’m thinking these are playing a factor. I’m planning on removing to see what happens.
  9. Mar 8, 2024 at 7:52 PM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    EGR here They will pop back now and then
    I just get it closer and I do small touches till its closed completely
    If you can, pass some W40 with your finger, lightly once a month on the rubber top of the window it will slide in a little easier
    You know what I am saying
  10. Mar 9, 2024 at 2:11 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    EGR here to,great fit looks proportionate with window gaskets & zero problems closing but when window is down I do have some rattling, I will need to put thin application of two way tape on them when it warms up.
