Advice for Cooling System Drain/Flush?
Discussion in '1st Gen Tundras (2000-2006)' started by WaterOp, Mar 7, 2024.
  1. Mar 7, 2024 at 4:43 PM
    WaterOp
    WaterOp [OP] New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    Hi All,
    I am preemptively changing the original radiator on my 2005 access cab.
    I was wondering if anyone has a good method to flush the old coolant out of the whole system, block, heater core, etc.?
    Usually I just warm up the vehicle and pull off the bottom radiator hose, but it always seems to make a mess with coolant going everywhere, and I never feel like the whole system gets drained. :eek2:
    Anyone out there have a better method? :help:
  2. Mar 7, 2024 at 6:11 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    4.7 has block drains. Attach some hose and drain into pan or bucket if on a lift. No mess and it should get most of it.
    KNABORES likes this.
  3. Mar 7, 2024 at 7:33 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    ATBAV8 likes this.
  4. Mar 7, 2024 at 7:33 PM
    AZBoatHauler
    So.Arizona
    Has it been getting a new water pump with the timing belt service? That seems to do just about a complete drain.
    ATBAV8 and Mr Badwrench like this.
  5. Mar 7, 2024 at 7:36 PM
    Mr Badwrench
    Mr Badwrench New Member
    ^ this. I'd just wait until the next timing belt and water pump replacement.
    Hummer likes this.
  6. Mar 7, 2024 at 10:05 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Just pulling the radiator hoses should get you almost 2gals out.
    Top it off with fresh Toyota Pink 50/50 and you’ll be fine.
  7. Mar 8, 2024 at 6:43 AM
    FishNinja
    Lee
    06DC2wd
    if he's throwing down the $$ for a fresh rad. I'd just do the job 100% perfect to ensure the longevity of the new rad.
    Weagle likes this.
  8. Mar 8, 2024 at 7:16 AM
    AZBoatHauler
    So.Arizona
    The price of SLL is getting out of control.
  9. Mar 8, 2024 at 7:19 AM
    FTFY
  10. Mar 8, 2024 at 10:03 AM
    shifty` Ten EV 12's so you know I raise hell
    And it wouldn't bother me so much that it's LITERALLY EVERYTHING, but it's LITERALLY EVERYTHING FOR NO FARKING REASON (except greed and profit). Like, no legit policy changes that would cause it. No new taxes/tariffs/fees, no supply shortages due to pandemic/war&tumoil/demand increase, there's no friggin reason. Companies are just greedy, the shareholders want higher dividends, and the C-level wants raises to their already-inflated salaries and bonuses for the c-suite. It's such a f'n joke. And this inflation BS will never end as long as those assholes keep inflating prices arbitrarily on everything, just because some computer algorithmic model tells them, "here's how you can make more $$". And the computer's not wrong, but the computer can't grasp the fact that our corporate overloads have us by dangling by the short-and-curlies as it is.
    Weagle and FirstGenVol like this.
  11. Mar 8, 2024 at 6:18 PM
    WaterOp
    So Lake Tahoe, CA
    Timing belt, water pump, and most hoses were done a couple of years ago. I should have done the radiator at the same time, but... well... that's coolant down the drain:(.
    The original radiator is fine right now, but I'm concerned about the real probability of the "pink milkshake", probably a legitimate concern considering the radiator is 20 years old at this point, so for the price of the new radiator and a couple of gallons of coolant it seems smart to just go ahead and change it out.
    I thought as long as I'm doing it it would be good to get as much of the old coolant/water mix out of the entire system, block, heater core, etc, as possible. It's probably overkill on my part, but why not.
    I can just shove a garden hose into the old radiator and run the engine until it all runs clear, but I had hoped others might have a better solution as that method always ends up with coolant on the ground or down a storm drain, neither of which is very environmentally friendly. Plus being in Tahoe, we have bears, coyotes, and other critters around and they have all been know to lap up coolant spills.
  12. Mar 8, 2024 at 6:20 PM
    AZBoatHauler
    So.Arizona
    Please don’t do this. Introducing all those minerals into the system is way worse than just leaving a gallon of coolant that’s two years old. I’m sure there are block drains (did it on the 3UR) but you risk breaking them or having a seep/leak if they don’t seal back up.
    Weagle and Hummer like this.
