Trans Fluid and Filter change
Discussion in 'New Member Introductions' started by Matt2012Tun, Mar 8, 2024.
  1. Mar 8, 2024 at 4:16 PM
    Matt2012Tun
    Matt2012Tun [OP] New Member
    2012 5.7 4x4
    Hello Tundra people.
    Anyone have any helpful hints when dropping the trans pan and changing out fluid and filter ? Wont be flushing the system as ive heard it can be produce unwanted results. Just draining the fluid then removing pan and replacing trans filter.
    Probably order the parts from RockAuto. Any suggestions on brands ? Any helpful hints would be appreciated. Thank you in advance.
  2. Mar 8, 2024 at 4:22 PM
    AZBoatHauler
    So.Arizona
    Don’t.
    ATV25, dt325ic, chugs and 4 others like this.
  3. Mar 8, 2024 at 4:23 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Welcome from MA
    You'll break a bolt just drain and fill
  4. Mar 8, 2024 at 4:41 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! But as stated previously, don't so it. The bolts on the drain pan are notorious for breaking off, creating a nightmare repair situation unless you are well acquainted with removing broken off bolts that are very tight in their threads.
    ATV25 and Matt2012Tun[OP] like this.
  5. Mar 8, 2024 at 4:47 PM
    2mchfun
    The filter doesn't need to be changed. Leave it alone unless you want to install an extra deep pan.
  6. Mar 8, 2024 at 4:53 PM
    Matt2012Tun
    2012 5.7 4x4
    That’s some good advice. I did think about just draining the fluid and refilling the same amount I drain out.
    my concern is in not replacing the trans filter though. I have a heavy duty mechanic background so I’m not opposed to drilling out the ones that break off, tapping out the holes and spending the time.
    I’m sitting at 275,000 kms (170k miles)
    Checked the color of the fluid already and it’s not totally black, more brown and does not smell burnt.
    Anyone know what the maintenance schedule is on the trans filter ?
    Just curious.
    and thank you for all the replies.
    Very helpful site so far.
    just joined.
  7. Mar 8, 2024 at 5:11 PM
    2mchfun
    It's fine for at least another 500k. Do a drain and fill every 30-40k and leave it alone.
  8. Mar 8, 2024 at 5:28 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Let me pile on.
    Just do a drain and fill. Then approx. next oil change do another drain and fill. Then approx. next oil change do a final drain and fill. Go ~150,000kms and repeat. You get the idea.
  9. Mar 8, 2024 at 6:27 PM
    Matt2012Tun
    2012 5.7 4x4
    Thanks guys.
    Will leave the pan bolts and filter alone. Way less of a PITA aswell.
    Love my Tundra…my next truck will be another Tundra.
    Cheers from Eastern Canada !
  10. Mar 8, 2024 at 6:35 PM
    2mchfun
    YW! Welcome to the forum, enjoy your stay!
    Matt2012Tun[OP] likes this.
  11. Mar 8, 2024 at 10:33 PM
    Black
    2014 Tundra Limited CrewMax
    It’s not a filter like many folks use it’s more of a strainer so no real reason to swap it.
  12. Mar 10, 2024 at 4:55 PM
    Matt2012Tun
    2012 5.7 4x4
    Thank you again Tundra folks.
    2mchfun and ATV25 like this.
  13. Mar 14, 2024 at 9:52 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal.
