  1. Mar 7, 2024 at 2:20 PM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Good choice.
    InfernoBoyz[QUOTED] likes this.
  2. Mar 7, 2024 at 2:30 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Easy peasy. Appreciate it!
    Threw in the new wheel bearings today. Extended studs arrive tomorrow. Didn’t want to reuse my old ones.
  3. Mar 7, 2024 at 2:36 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Cheap, convenient that it’s in Costco, online testing shows it comparable to Mobil 1.. what’s not to like?
    Use it in both Tundra and 4runner.
  4. Mar 7, 2024 at 3:36 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Got tired of the hood bulge popping out. Bolted the SOB down. Went through many different retainer clips, even the green recommended ones. They all failed.
    This is what it looks like from inside the hood, it’s aftermarket but should be the same for oem. Bolts were a little long but I’ll eventually get around to cutting off the excess.
    four 6” 1/4-20 hex bolts and one 5” 1/4-20, all I had lol but it works. Things pretty solid now. No more dealing with dumb clips.
  5. Mar 7, 2024 at 3:48 PM
    Jeff Spicoli
    Jeff Spicoli New Member
    2019 Platinum
    Dual Magnaflow exhaust, Bakflip MX4, Taylor's Audio amp, speakers and subwoofer for Tundra JBL.
    I just received my Hertz door speakers from Taylor’s Audio. Planning to install them this weekend.
  6. Mar 7, 2024 at 3:53 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Had the dealer perform a transmission fluid flush today. They made me sign a waiver that they wouldn't be responsible if my transmission failed after the service, weird. They were concerned that my 195k truck wasn't going to like it, seems to shift fine after. I did a full change on my Sequoia at 315k (factory fluid) and it worked out well.
    WFD473, bulldog93 and CaptRussia253 like this.
  7. Mar 7, 2024 at 3:55 PM
    centex
    centex New Member
    Did you glue the bolts to the hood bulge?
  8. Mar 7, 2024 at 3:58 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    no glue, wanted to have free movement in the bolts for easier mounting. just slotted the bolt heads into where the clips would go, the hex head is large enough to hold but a washer can be throw in too.
  9. Mar 7, 2024 at 4:16 PM
    Bergy24
    Bergy24 New Member
    How did you like the Fox suspension compared to the stock suspension?
  10. Mar 7, 2024 at 4:18 PM
    Bergy24
    Bergy24 New Member
    What’s it look like on the hood bulge side?
  11. Mar 7, 2024 at 4:21 PM
    RobertD
    Robert
    DFW, Texas
    No different... he slid the hex head where the clips slide into.
    Ryuu and Bergy24[QUOTED] like this.
  12. Mar 7, 2024 at 4:27 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    yep, no different from normal. I didn't want any bolt heads sticking out.
    had seen one where they just ran self tapping bolts from the top of the hood bulge down into the hood and another where I guess they just drilled holes top to bottom to put screws with anodized countersunk washers, but I didn't like that too much.
  13. Mar 7, 2024 at 4:42 PM
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    Substantial improvement. They really are tuned properly for a tundra. On highway and high speed driving the truck felt planted and comfortable. Slow driving it was a bit soft around town and the truck had more noticeable sway.
    Off road they were really good at first and the truck really felt much more capable and had better travel. Pretty plush ride slow or fast off roading. I’m hoping this install takes my truck back to that or better. They’re toast now and driving my truck is miserable. I’m planning to get them rebuilt and put them back on if I don’t feel the Bilsteins are an upgrade. From what I’ve read, they will be.
  14. Mar 7, 2024 at 5:16 PM
    Excellent tires. We have them on our 4Runner.
  15. Mar 7, 2024 at 5:35 PM
    kbahus
    kbahus New Member
    MI
    @InfernoBoyz How many miles are on the Fox suspension? My Fox 2.5’s on my GX had 100k and still felt surprisingly good.
  16. Mar 7, 2024 at 5:39 PM
    InfernoBoyz
    Reno, NV
    previous owner claimed 20k. I have at least 40k with tons of off roading fully loaded and towing. I know the previous owner off roaded as well with a rack/tent set up. Under my use case, 60k seems about right. They claim to last 60k.
    kbahus[QUOTED] likes this.
  17. Mar 7, 2024 at 5:49 PM
    kbahus
    kbahus New Member
    MI
    With that kind of use that does seem reasonable.
  18. Mar 7, 2024 at 7:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Down in front? Baja Designs S8 30”
    Rakso[QUOTED], bulldog93 and RobertD like this.
  19. Mar 7, 2024 at 8:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Got the OnX6 mounted up top…
    still gotta chase down a gremlin in the wiring… Switch Pro isn’t liking something
  20. Mar 8, 2024 at 6:50 AM
    grant.ducckk
    grant.ducckk New Member
    Grant
    2019 DC Cavalry Blue Limited 4x4
    I do not know a huge deal about suspension setups, but that is exactly what I am planning on getting when the budget allows. Are the single shims standard (I can see there are two on the driver's front)? Or are they coachbuilder shims?
  21. Mar 8, 2024 at 6:57 AM
    Do those shackles rattle and bounce around? I have the Gear America anti-theft shackles on my rear bumper. They don't move at all with the rubber washers installed.
    bulldog93 likes this.
  22. Mar 8, 2024 at 7:20 AM
    AZBoatHauler
    So.Arizona
  23. Mar 8, 2024 at 8:14 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
  24. Mar 8, 2024 at 8:14 AM
    Rakso
    Oskar
  25. Mar 8, 2024 at 8:16 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Behind license plate
  26. Mar 8, 2024 at 8:30 AM
    CaptRussia253
    Ruslan
  27. Mar 8, 2024 at 8:33 AM
    AZBoatHauler
    So.Arizona
    RobertD and Mater like this.
  28. Mar 8, 2024 at 8:35 AM
    AZBoatHauler
    So.Arizona
    Yes, both. Few soft shackles ( 1- Yankum , 2 Badlands) and a bow shackle along with a 30’ yankum kinetic rope. Factor 55 pulley ring.
    :anonymous:
  29. Mar 8, 2024 at 8:58 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Decided to upgrade to this: LPX LICENSE PLATE LIGHT BAR UNIVERSAL KIT
    Had to tap into the tail light, so when parking lights are turned on, the LED lights will come on. Also works as a 4th brake light which is awesome.
    Reverse light.
  30. Mar 8, 2024 at 9:10 AM
    InfernoBoyz
    Reno, NV
    coachbuilder 2/1 driver passenger with their 1/4” shims. Should total 1” driver and .5” passenger to help lean.
