New to me 05 DC 4x4
Discussion in '1st Gen Tundras (2000-2006)' started by 05TunDC, Mar 6, 2024.
  1. Mar 6, 2024 at 9:05 PM
    Nah. If you hang out a little bit around here you'll see the AC vs DC pop up a few times. It's all in jest. Mostly. Well, not really. But you get the point.
    shifty` likes this.
  2. Mar 7, 2024 at 5:48 AM
    bfunke
    bfunke Tundra Curmudgeon
    I’d like to see an LT4 swapped into a nice FGT.
  3. Mar 7, 2024 at 6:57 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    its all fun and games until someone brings up sawzalls and tube bumpers
    bmf4069[QUOTED] likes this.
  4. Mar 7, 2024 at 9:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    So to answer the actual questions :) Deflated airbags shouldn't affect ride height, but may minimally. There is a minimum psi so they don't get damaged. The rear suspension looks stock other than the shocks.
    You can lower it with shackles. I forget the details, but something about our shackles is backwards, meaning lift shackles will actually lower it.
  5. Mar 7, 2024 at 1:00 PM
    As long as elevator guy doesn't see it...:spy:
