Driver window won't work despite new switches and motors
Discussion in '2nd Gen Tundras (2007-2013)' started by Chrisp1988, Oct 23, 2023.
  1. Oct 23, 2023 at 5:28 PM
    Chrisp1988
    Chrisp1988 [OP] New Member
    2008 tundra sr5 4x4
    Lifted
    Guys I really need some help.. so I have a 08 tundra sr5 the driver window main switch broke and I was using a pin to activate the window. I finally replace the main window switch and now my driver window will not move up or down. I have tried 2 different switches from Amazon and even 2 window motor assembies. Nothing fixed the issue. I have also check fuses and cannot find any blown fuse.. all the other windows function properly on all switches. Drivers side (Auto) button is illuminated
  2. Oct 23, 2023 at 5:34 PM
    Have you tested the motors? Or the switch? Or the wiring at the motor when activating the switch? Assuming you’ve checked the fuses already? Not visually, but actually tested them?
    ZappBrannigan likes this.
  3. Oct 23, 2023 at 5:50 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Check to see if you’re getting power at the window motor
  4. Oct 23, 2023 at 5:50 PM
    Chrisp1988
    2008 tundra sr5 4x4
    Lifted
    I testing the while hitting the switch and it picking up voltage
  5. Oct 23, 2023 at 5:50 PM
    How are the grounds?
  6. Oct 23, 2023 at 5:59 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    So you have voltage going to the window motor when the switch is engaged and the motor isn’t moving?
  7. Oct 23, 2023 at 6:15 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    The same thing happened on the wifes Malibu. Drivers side window wouldn’t roll down but all others would. Bought a master switch from Amazon and I still had the same issue. Returned that one and bought another one from Amazon and still the same issue. Before I tore into it any deeper thinking it was the window regulator I decided to buy one more but I bought it from Rockauto. Installed it it and every window worked. Definitely possible you are getting bad switches.
    PhotoNerd and ZappBrannigan like this.
  8. Oct 23, 2023 at 7:07 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
  9. Oct 26, 2023 at 12:25 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Was it not repaired as per the TSB. Why spend the money when it can be replaced with an OEM part for free99
  10. Mar 7, 2024 at 3:19 AM
    Fishkiller
    Fishkiller New Member
    2008 Tundra Dbl Cab X-sp
    blackdemon__tt, is there a link to the TSB. I can’t find what you’re referring to and free99 sounds great!
  11. Mar 7, 2024 at 10:09 AM
    blackdemon_tt
