2004 Toyota Tundra Framing
Discussion in 'New Member Introductions' started by Msllpaige, Mar 6, 2024.
  1. Mar 6, 2024 at 8:07 AM
    Msllpaige
    Msllpaige [OP] New Member
    Lenora
    2004 Toyota Tundra
    none
    Hi All:
    I am new here and I am looking for help with my 2004 Toyota Tundra. The rear support needs welding and is causing an issue with the break line. It is my understanding that there was a recall on the rear end and has expired. What should my next steps be?
  2. Mar 6, 2024 at 8:22 AM
    Can't weld rust. That sucks.
    2mchfun likes this.
  3. Mar 6, 2024 at 8:30 AM
    Msllpaige
    Lenora
    2004 Toyota Tundra
    none
    What would you suggest?
    2mchfun likes this.
  4. Mar 6, 2024 at 8:39 AM
    Have the frame inspected for overall road worthiness, no sense throwing money at an unsolvable problem. If it's determined that there are only a few areas that need attention (difficult to believe based on that photo), then major rust remediation needs to occur first. Heavy wire wheel and / or needle descaling needs to take place prior to trying to weld back together or weld in reinforcement plates. Then the whole thing needs to be treated to prevent further corrosion. This can likely be bandaided for short term continued use, but it's also likely the corrosion is too far advanced to save it long term. Some owners have still been able to get frame replacements under a recall from Toyota, but those reports are dwindling as the campaign has ended. More pics of the frame in various locations may help to assess how bad it is overall.
    2mchfun likes this.
  5. Mar 6, 2024 at 8:54 AM
    2mchfun
    Welcome from OKC! If the rest of the truck is great, maybe a frame swap from salvage would be something to consider. Might be able to get lucky and find one of those replacement frames from the recall.
  6. Mar 6, 2024 at 9:09 AM
    Msllpaige
    Lenora
    2004 Toyota Tundra
    none
    Thank you. We are looking at all angles. The truck still runs good and not looking to get rid of it soon. Hoping we can resolve the issue.
    2mchfun likes this.
  7. Mar 6, 2024 at 9:15 AM
    2mchfun
    If you do in fact get a decent frame, something like Woolwax or Fluid Film will be a good investment to protect it from rust.
  8. Mar 6, 2024 at 11:58 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I hope you can get it all fixed up!
  9. Mar 7, 2024 at 2:45 PM
    Welcome from NY.
  10. Mar 14, 2024 at 9:53 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal.
