100,000 mile 2018 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by CptYoda, Mar 5, 2024.
  1. Mar 5, 2024 at 6:46 PM
    CptYoda
    CptYoda [OP] New Member
    2018 Tundra
    Sooo.. I just bought a 2018 4wd crew cab Tundra from a Ford dealership of all places. It has just over 100,000 miles on it. What kind of maintenance would you recommend to perform on it. I plan on changing the front and rear diff gear oil. Engine oil was just changed and plan on taking it to the local Toyota dealership for a full diagnostic test when the next oil change is due, but thought I would just throw it out to the group.
    WILLINH and BillyB like this.
  2. Mar 5, 2024 at 6:51 PM
    Welcome aboard!! And congrats. Transfer case, transmission, power steering, brake fluid, coolant, and lube all greasable points. Spark plugs too. Cabin air if it hasn’t been changed.
  3. Mar 5, 2024 at 6:52 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Items to consider:
    Transmission fluid - maybe perform a couple of drain & fills.
    Serpentine belt replacement, check pulleys when belt removed.
    Spark plugs are officially due at 120k miles, but no harm in changing them at 100k.
    KNABORES likes this.
  4. Mar 5, 2024 at 6:53 PM
    forgot this one!
  5. Mar 5, 2024 at 6:55 PM
    Battery if original is near end of life.
    MedCityMoto likes this.
  6. Mar 5, 2024 at 6:55 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I did my plugs at 100k, but I haven't done the belt yet at 120k, heh. There a recommendation on doing the thermostat and tensioner at the same time?
  7. Mar 5, 2024 at 6:56 PM
    My thermostat on the 2000 Tundra went 212k miles without failure.
  8. Mar 5, 2024 at 7:01 PM
    2mchfun
    Welcome from OKC! 100K? It's not just mileage, there's years to consider here. I would be going through it pretty thoroughly and definitely screen the HVAC fresh air intakes under the windshield cowling. Otherwise rodents will be all over in your truck.
  9. Mar 5, 2024 at 7:03 PM
    CptYoda
    2018 Tundra
    Thanks guys, and I appreciate the warm welcome! You never know with some of these forums these days. Lol! This is my dream truck, took me 48 years to get it, but I have it. I have a 2020 Honda accord as my main vehicle, so I am looking to keep this truck for a long time. Some of this maintenance I can do on my own, some may be more challenging. Start with the diffs, trans, and grease points. Anyone know of a diagram for the grease points, everything I saw online is saying they did away with the grease nips
  10. Mar 5, 2024 at 7:14 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Welcome and congrats on your recent purchase. I would consider this forum like a campfire with a good crowd, where it gets raunchy but also solves life's greatest mysteries. Good community of very intelligent, unhinged individuals. BS is shut down pretty quickly, tell you the truth I haven't seen anything spicy in a bit. And it makes me sad.
  11. Mar 5, 2024 at 7:15 PM
    Gotta hang out in the right threads…..
    OHwendTrd[QUOTED] likes this.
  12. Mar 5, 2024 at 7:19 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :burp: true also. Oh and get ready to spend money.
    grant.ducckk and 2mchfun like this.
  13. Mar 5, 2024 at 7:19 PM
    2mchfun
    There's always a chance parts have been changed and grease zerks are included in the changes. For example, I only had about 20k on my truck but had to replace the boot on my driveshaft slip yoke due to a barbed wire stub poking out of the weeds and finding its way right into a u joint. That became a nightmare quickly that led to new U joints with grease zerks. Also found out that the slip yoke wasn't lubed very well from the factory. Just look closely at rear shackles, control arms, driveshafts, ball joints, sway bar links, and tie rod ends.
  14. Mar 5, 2024 at 7:25 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Oil threads (viscosity battles are ok, but I prefer oil change interval for entertainment), biggest tire without a lift threads, gas mileage threads, inter-generational pissing contest threads...
  15. Mar 5, 2024 at 7:29 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Congrats on the dream truck. This forum has the answers to all your questions. Many times I’ve brought issues up to my dealer that had no clue but I showed them solutions from the forum. This is a great place to learn something new or get great ideas. Enjoy your Tundra and post some pics.
  16. Mar 5, 2024 at 7:33 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Watching some friendly bashing sprinkled with some feathered in insults, followed by few of these :popcorn:, ending with a thread lock and ban hammer! Yeah, gets me going for the day.
  17. Mar 5, 2024 at 8:31 PM
    Welcome from NY.
  18. Mar 5, 2024 at 8:36 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    Don't forget the MGM bashing thread. I've gotten a lot of amusement reading through that recently...been my favorite thread lately :rofl::D
  19. Mar 5, 2024 at 8:37 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well good on you for picking the best year tundra!
  20. Mar 5, 2024 at 8:38 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    You mean the jealousy thread?
    Terndrerrr likes this.
  21. Mar 5, 2024 at 8:39 PM
    vmkeith
    Vince
    Clark County, Wa
    Could be. I'm new to the forum and actually like how the MGMs look...I just find it amusing asf!!!!
    ZappBrannigan[QUOTED] likes this.
  22. Mar 5, 2024 at 8:39 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Purchased my 2018 new off the Yota lot. Check the battery date, engine oil, front/rear/Tcase (probably just do it at 100k), spark plugs, brake pad thickness, maybe swap the brake fluid. After that, check the rear shocks for any minor leakage up top and the cam tower seals. Basic stuff. However the cam tower seals replacement is pricey at the dealer.
    engine oil and the rear/front/TCase is very simple to drain and fill. Spend the extra few dollars for replacement plug washers. Just saying. Also don’t read TOO much on the exact fluid needed. Use good judgement.
    ZappBrannigan likes this.
  23. Mar 5, 2024 at 8:42 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’d do your differentials too.
    Do the diff breather hose mod.
    Might need new shocks if they are original.
    Brake fluid flush if it’s nasty.
    Power steering fluid change.
  24. Mar 5, 2024 at 8:43 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Depends on gen and year. Crawl under and look for the nips. No pun intended. Used to have them. Afterwards they were nipless. If aftermarket on a used, they might have nips……for greasing of course. 100k, might want to check.
  25. Mar 5, 2024 at 8:45 PM
    offsetplayer2
    2018 Inferno CM 4WD
    We all know Inferno is the best……
  26. Mar 5, 2024 at 8:45 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Don’t take the bait
  27. Mar 5, 2024 at 9:04 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Because it’s looks the best! You have good taste. None of this rental car white crap.
    AZBoatHauler likes this.
  28. Mar 5, 2024 at 9:12 PM
    AZBoatHauler
    So.Arizona
    Some people like looking like contractors
  29. Mar 5, 2024 at 9:13 PM
    vmkeith
    Vince
    Clark County, Wa
    The sign of a working man!!!!
  30. Mar 5, 2024 at 9:18 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Or a state worker :crapstorm:
    AZBoatHauler and ZappBrannigan like this.
