Trailer detected! Are these error messages?
Discussion in '3rd Gen Tundras (2022+)' started by COBoondocker, Jun 17, 2023.
  1. Jun 17, 2023 at 4:38 AM
    COBoondocker
    COBoondocker [OP] New Member
    2023 blueprint Toyota tundra limited
    We just towed our new travel trailer, with our new 2023 Tundra, for the first time and I am seeing these messages. The screens alternate between these two. Even if I exit out, they reappear.
    Note: I took these images while in 4L, but it does happen when I'm in 2H or 4H.
    Thoughts ?
  2. Jun 17, 2023 at 4:59 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    PKSB is parking support brake. It deactivates the automatic braking to preventing you from backing into something. RCTA is rear cross assist (I think that's the acronym). It let's you know when someone is crossing behind you. It's totally normal they get deactivated. They are useless with a trailer attached.
    Hella Krusty likes this.
  3. Jun 17, 2023 at 5:20 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Completely normal with a trailer hooked up.
  4. Jun 17, 2023 at 5:50 AM
    OldMotoMan
    OldMotoMan New Member
    2022 Tundra DC SR5
    I forget the menu it's on, but you should've added your trailer to the trailer list, entering the length. I believe this changes the BSM indicator function for the additional length.
    Unfortunately, you have to scroll the menu to re-select the trailer every time you start the truck.
    Hella Krusty and ColoradoTJ like this.
  5. Jun 17, 2023 at 8:21 AM
    COBoondocker
    Thanks everyone!
    ColoradoTJ likes this.
  6. Jun 17, 2023 at 12:55 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Is the truck squatting a lot with the trailer? May be why the VSC shuts down as it goes out of calibration from the angle change.
  7. Jun 17, 2023 at 4:49 PM
    COBoondocker
    Ok. Maybe I will see what happens next time we tow. If That second screen still appears, I'll ask the dealer.
  8. Jun 17, 2023 at 9:06 PM
    xc_tc
    xc_tc New Member
    VSC turns off in 4low and the manual explains that PCS doesn’t work when VSC is off.
    Mattedfred likes this.
  9. Mar 5, 2024 at 5:13 PM
    NewTruck24
    NewTruck24 New Member
    Tundra
    I had this same problem and took it and my trailer to the dealership. They futzed around with it a bit and determined there was nothing wrong and explained to hit the back arrow. Doh!!! Then left and right arrows worked as well. Back arrow is in upper right corner of screen. Hope this helps others and saves a trip to the dealership.
    Rex likes this.
