Oil Filter Housing
Discussion in '2.5 Gen Tundras (2014-2021)' started by morgaj1, Mar 5, 2024.
  1. Mar 5, 2024 at 9:31 AM
    morgaj1
    morgaj1 [OP] New Member
    AL
    2021 Tundra Platinum CM 4x4
  2. Mar 5, 2024 at 12:52 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    This is what I got from my local dealer
    Wynnded, equin and morgaj1[OP] like this.
  3. Mar 5, 2024 at 6:37 PM
    morgaj1
    AL
    Thank you
  4. Apr 21, 2024 at 12:32 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Does anybody know if there's anywhere I might be able to go TODAY(it being a Sunday) to buy this OEM filter housing? Looks like all dealerships parts stores are closed Sundays.
    Do any of the auto parts stores sell this OEM part?
  5. Apr 21, 2024 at 1:23 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Probably not
  6. Apr 21, 2024 at 1:27 PM
    bfunke
    bfunke Tundra Curmudgeon
    FLAPS don’t carry the OEM housing. You might find a Dorman part. Where are you located. Someone may have one near you.
  7. Apr 21, 2024 at 1:30 PM
    TacomaTRD4x402
    Southern California
    I'm in So Cal near Corona. I've checked OfferUp, marketplace and Craigslist :(
  8. Apr 21, 2024 at 1:30 PM
    agrestic1
    2016 CrewMax
    Just be careful of the Dorman , it's a universal fit for Toyotas..
  9. Apr 21, 2024 at 1:31 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Advanced Auto
    TacomaTRD4x402 likes this.
  10. Apr 21, 2024 at 1:35 PM
    bfunke
    Auto zone has the Dorman metal one in stock.
  11. Apr 21, 2024 at 1:38 PM
    bfunke
    All 5.7 and several other engines use this cap. Just be sure to use the longer tower inside as some models use the shorter filter. Transfer it from your old housing. No need to bend the tabs - just use a trim tool to slightly squeeze the tube just above one of the tabs and it pops right out.
  12. Apr 21, 2024 at 1:49 PM
    TacomaTRD4x402
    Southern California
    Looks like this dorman aluminum comes with 3 sizes but what's the difference between the 2? :confused:
  13. Apr 21, 2024 at 2:09 PM
    bfunke
    I would use the OEM tower which has the tabs. The Dorman looks like it has a short tower with tabs and then you slip one of the two over it. It should work either way as all the tower does is keep the paper filter from collapsing.
