Added security, tundra cab hacked 3 times in my driveway with extra lighting added
Discussion in '2.5 Gen Tundras (2014-2021)' started by FloydH, Mar 4, 2024.
  1. Mar 4, 2024 at 3:21 PM
    FloydH
    FloydH [OP] New Member
    Hank
    Tundra 2015
    My tundra 2015 was opened three times. Electronic hacking i think. Don’t keep any valuables there except handicap placard. Was thinking of putting a switch on the electrical circuit to the door lock device. I think there are two front and back?
    Any suggestions? New to the forum.
  2. Mar 4, 2024 at 4:30 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Do you have footage of the hack?
    If it's a proximity key fob you can use a faraday bag for your fobs or just store them in a metal container you can seal.
    bflooks and FloydH[OP] like this.
  3. Mar 4, 2024 at 4:45 PM
    Retired...finally
    Did you find the truck unlocked after you remote locked it or find evidence of someone getting inside the truck?
  4. Mar 4, 2024 at 4:45 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    All I have are questions.
  5. Mar 4, 2024 at 5:17 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Place keys in the microwave.. Cheap faraday cage, just make sure you don't cook them...
    FloydH[OP] and Retired...finally like this.
  6. Mar 4, 2024 at 5:32 PM
    2mchfun
    Plant some airtags inside a couple of things inside the truck and wait for them to grow legs. Then let the games begin.
  7. Mar 4, 2024 at 11:01 PM
    FloydH
    Hank
    Tundra 2015
  8. Mar 4, 2024 at 11:03 PM
    FloydH
    Hank
    Tundra 2015
    How do I respond to a comment? New…
  9. Mar 4, 2024 at 11:19 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    You just did reply, but if you meant quote...in the post you want to quote, on the right side you should see links for "Like, Multi Quote, and Quote". Just click "Quote" and in the message box you see the message of the post you're quoting and replying to. Hit enter a a couple times and then write you reply.
    Does this help?
    FloydH[QUOTED][OP] likes this.
  10. Mar 5, 2024 at 9:53 PM
    FloydH
    Hank
    Tundra 2015
    Yes thanks!
    vmkeith[QUOTED] likes this.
  11. Mar 5, 2024 at 9:55 PM
    FloydH
    Hank
    Tundra 2015
    I am now using one of those but no attack recently.
    Saltyhero13[QUOTED] likes this.
  12. Mar 5, 2024 at 9:56 PM
    FloydH
    Hank
    Tundra 2015
    Good idea thx
    2mchfun[QUOTED] likes this.
  13. Mar 5, 2024 at 9:57 PM
    vmkeith
    Vince
    Clark County, Wa
    I've got a couple Ring cameras that has 180 degree coverage of the front of my house. Pretty inexpensive including the subscription.
    Gene_in_FL and 1lowlife like this.
  14. Mar 5, 2024 at 9:59 PM
    FloydH
    Hank
    Tundra 2015
    Found it unlocked and found item missing and console and glovebox open. Only thing of value was the handicap placard. No evidence of forced entry. Just hacked I think.
  15. Mar 5, 2024 at 9:59 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    2015…..shouldn’t have push to start I wouldn’t think, meaning you probably have a physical key. You sure at that model age that when you press lock on the actual key that your door lock actuator isn’t hanging? It’s common. Press lock on the actual key, truck doesn’t lock. Put the key in the keyhole and turn it and it locks. These models and the similar Tacoma years are notorious for the door lock actuator to stop working properly. Replace that and it works properly again when you press lock. My money goes towards that.
    Edit: I just replaced both front doors a few weeks ago on my 2018 for this very reason.
  16. Mar 5, 2024 at 10:00 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Probably opportunity theft with an unlocked door. Especially if that was the only thing taken.
  17. Mar 5, 2024 at 10:01 PM
    FloydH
    Hank
    Tundra 2015
    Thinking about adding. Did add driveway lights that turn on at sunset and off at sunrise
  18. Mar 5, 2024 at 10:03 PM
    2mchfun
    Really easy to pry open a door at the top. Then stick in a wedge and use a stick to hit the switch. Really easy. That said, the alarm should be triggered by the door switch.
  19. Mar 5, 2024 at 10:05 PM
    FloydH
    Hank
    Tundra 2015
    It uses a separate fob and truck clicks once for lock and twice for unlock using the fob. I’m as certain as I can be that I did lock it with the fob.
    Thanks.
  20. Mar 5, 2024 at 10:06 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Aftermarket? And did you actually pull the door handle and not just click the button?
  21. Mar 5, 2024 at 10:07 PM
    FloydH
    Hank
    Tundra 2015
    It is possible but 3 times in the last year seems unlikely.
  22. Mar 5, 2024 at 10:08 PM
    FloydH
    Hank
    Tundra 2015
    No came with truck. Just clicked the button.
  23. Mar 5, 2024 at 10:13 PM
    offsetplayer2
    2018 Inferno CM 4WD
    My money still goes towards actuator no matter if you have a 2 piece key like this:
    Or a single whole key like this:
    actuator acts the same. Do you stick the key in and turn it to start it?
    also the click you hear may be the rear doors locking. Not the fronts.
  24. Mar 10, 2024 at 2:45 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    i had drivers door on my 17 stop locking . Actuator went bad. Now pass side front door actuator is making noise ,it'll be dead soon also . Very common on toyotas ive found .
  25. Mar 10, 2024 at 3:10 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I had my 17 withe the key and separate fob opened like this a few years ago in Yuma. Neighbor got it on camera and let me know. Guy hit all the neighbors vehicles, different brands. Only ones he didn’t get into were my old 4Runner and Mazda 3 which didn’t have a fob. Guy stood on sidewalk, played with some device and everyone’s cars/trucks lights blinked and he started pillaging. He was caught a couple days later. At least nothing was broken during the theft, so at least there was that.
