Batteries...Is It All About CCA's?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TravisH, Feb 27, 2024.
  1. Feb 27, 2024 at 8:25 AM
    TravisH
    TravisH [OP] New Member
    Travis
    2019 Tundra TRD Off Road Double Cab
    None
    Hi,
    My "Toyota" branded battery is 2+ years old and only showing 600 cca out of the 800 it's rated.
    Meanwhile I replaced batteries on my RV and the old ones surprisingly test out fine with 12.7v and 810 cca. These are 4 year of Deka AGMs. oddly abused to no end being down to around 10.4 volts most of the time but had them on a CTEK charger that seems to have rejuvenated them. They've been holding a 12.7v charge and test as brand new under load!
    Can I use these in my Tundra?
  2. Feb 27, 2024 at 8:28 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    If they'll fit, you can use them. But I believe there is something you need to add when using an AGM battery in the Tundra. Someone else can chime in.
  3. Feb 27, 2024 at 9:21 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    There are several threads about AGM batteries. Charging and heat are the main concerns running them.
    You'll find some people run diodes/voltage devices and others don't; half the batteries will crap the bed while others run fine.
    If you occasionally put the battery on a batt tender you don't need to diode/voltage device to maintain the battery.
    Here is one solution to running AGM but there are several others:
    https://www.tundras.com/threads/gm-diode-install.134029/
    HKB is another solution:
    https://www.hkbelect.com/
    And this is an alternate product:
    https://voltageboosterpro.com/product/spark/
    As mentioned before a tender that can handle AGM charging works as well if you do it periodically.
    hagrid, Ctaylor76 and Tundra234 like this.
  4. Mar 2, 2024 at 4:29 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    just get the stock size in an interstate. it's the best all around battery for your main battery.
    nmsTundra89 likes this.
  5. Mar 2, 2024 at 5:35 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I will disagree. I am a mechanic for a large fleet. Interstates used to be good batteries but have been poor for quite some time now. Plus they are very expensive. Right now I have been using Diehards from Carquest at work for awhile and have been having good luck with them, also very good pricing. Batteries are hit or miss these days. I tell people to buy the battery with the best free replacement warranty and price. Those are the only 2 things you can control as a consumer. All manufacturers have gone to free replacement warranties instead of pro- rating them. I also have Sam's club batteries in a few of my personal vehicles because of price and warranty.
    BLONGTX likes this.
  6. Mar 4, 2024 at 4:08 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Black Wolf, tyr0981 and Leo's first like this.
  7. Mar 4, 2024 at 4:31 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I've been running EverStart's for over ten years definitely best bang for the buck
    Easiest warranty I ever done Straight swap for one I burnt up jumping tow behind air compressor for a week
    pro rated a 2 yr old one that died when I lost the alternator in my Yukon 1500+ miles from home
    I usually get about 5 yrs normal use out of them
    Ruggybuggy[QUOTED] likes this.
  8. Mar 4, 2024 at 4:47 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I've heard Everstarts are decent. I just refuse to step foot in a Walmart. :rofl:
  9. Mar 4, 2024 at 5:08 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    DeKa.
    Ol’Remy likes this.
  10. Sep 10, 2024 at 1:06 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
  11. Sep 10, 2024 at 2:44 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  12. Sep 11, 2024 at 3:53 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    When my OEM batterry bit the dust the first stop was WalMart. They only had 24s in the Tundra post configuration. I asked the dude at the counter and he said they quit carrying 27s. I figure the average WalMart shopper is basing their decision on price. Next choice was Auto Zone and it is now 5+ years old and still strong.
    Leo's first likes this.
  13. Sep 11, 2024 at 4:22 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Been having very good luck with AC Delco batteries. Had 5 in my boat (36v trolling mtr and 2 starting/House). Still fine after 4 plus years. 18 month free replacement. Price seemed reasonable.
  14. Sep 11, 2024 at 7:07 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    hagrid[QUOTED] likes this.
  15. Sep 11, 2024 at 7:11 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I installed the group 24. It actually had a CCA that was higher than the group 27 I had before and it’s also lighter. I’ve been running it for about 9 months without any issues.
