  1. Mar 4, 2024 at 5:27 AM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    Redline Goods is easy to work with. I'm pretty sure all product is made to order, and that they would customize the top of your boot to whatever circumference you need. To me, just looking at pictures, as I've never seen a Teton in person, the bottom is of similar size to the Tundra TRD knob, so I'm thinking it will fit without modification. I may still have my silver TRD knob. If I can find it, I'll get you the circumference where I have the boot zip tied.
  2. Mar 4, 2024 at 5:28 AM
    Bergy24
    Bergy24 New Member
    Thanks
  3. Mar 4, 2024 at 6:00 AM
    Retired Blue
    Steven
    Round Rock, TX
    Found it. Just where I remembered. 4" +/- (I wrapped the string around where I drew the shaky white line in the pic.)20240304_074913.jpg
    copmagnet82 and bulldog93 like this.
  4. Mar 4, 2024 at 6:01 AM
    Bergy24
    Bergy24 New Member
    Thanks for the info, I wall check it out.
  5. Mar 4, 2024 at 6:33 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    While reinstalling my cat plates, I noticed the rear most one is pressing against the transfer case's skid plate. Does anyone else have this problem?
    I'm guessing this probably isn't necessarily bad, but I can't imagine it being good in any way to have the transfer case being pressed up like that. I think it will clear the plate if I remove the skid - do the bolts holding the skid serve any purpose aside from that? Ie, if I snug them back in finger tight, will that be okay?
    Edit: I've added a few washers to try to shim the plate down, but its still touching.
  6. Mar 4, 2024 at 6:44 AM
    That small transfer skid is supposed to be removed before installing the cat plate.
    ATV25, NewImprovedRon, coTony and 8 others like this.
  7. Mar 4, 2024 at 7:21 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I think there are kits for this for any car, but:
    Starlight Headlining (rolls-roycemotorcars.com)
  8. Mar 4, 2024 at 7:44 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    d'oh :homer:
    Edit:
    It has been removed, look at all that clearance!
    Thanks George!
    Really wish I had realized this ~25k ago when I put in the plates; there's a bit of wear on the inside of the cat plate where the xfer case skid rubbed against it. Live and learn though...hopefully no long term damage. The xfer case itself appears to be undamaged.
    Wallygator, bflooks, Jego and 3 others like this.
  9. Mar 4, 2024 at 8:08 AM
    eSkittles
    eSkittles New Member
    2021 Tundra Amy Green 1794
    no mods but conquered tahoe blizzard! Toyo MTs did great in the snow
  10. Mar 4, 2024 at 10:02 AM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Update to my steering wheel shake, I have one bad K02, the machine requested some absurd amount of weight to balance perfect.
    mfelton18 and bulldog93 like this.
  11. Mar 4, 2024 at 10:08 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    This is a good looking truck :thumbsup:
    bulldog93 likes this.
  12. Mar 4, 2024 at 11:40 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    That's a tough-looking truck! Should've timed it so the mere cars behind it weren't there, so it looks like ONLY YOU could make it! :)
  13. Mar 4, 2024 at 12:47 PM
    moodywizard
    moodywizard New Member
    Lost
    2017 Tundra 4x4 Crew Max
    Ordered the imitation trd rear sway bar from Amazon, installed and removed the front. Much better with rear on front off vs both off. Rear end tight and front a little loose. Quick shake down run close to home was fun with the fam and mud puddles. Sorry no pics this time.
    rattled canned it black as the red gives me ocd bumps.
    HulkSmurf14, AGTundra and reywcms like this.
  14. Mar 4, 2024 at 1:44 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Went out for a little drive on Saturday to see where the snow level was at. Not quite as low as I would have expected considering the hype the storm got.
  15. Mar 4, 2024 at 2:34 PM
    NTX_Tundra
    NTX_Tundra New Member
    Added Bilie bars, a 23Zero Walkabout 62 RTT and some black topographical Tailgate letters from Yota Xpedition.
  16. Mar 4, 2024 at 3:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Couple things going in this week. Also working on a larger intake tube setup since we believe we’re maxing the maf out on the 4.5” tube. Will also be adding an LS 103mm throttle body while we redo the intake tube to 5”. Should pick up a few more horse powers.
  17. Mar 4, 2024 at 5:40 PM
    moodywizard
    Lost
    Discovered a love tap on the rci skids. Wonder if I can order replacement door, will try to beat this one straight beforehand.
  18. Mar 4, 2024 at 5:44 PM
    moodywizard
    Lost
    I haven’t been impressed with my last set of odyssey batteries. The new goto I’ve heard is full throttle flame river, if my last set of odysseys wasn’t covered in warranty was going that route.
  19. Mar 4, 2024 at 5:47 PM
    SAGE63
    San Diego County
    lol you should see mine.... more than a love tap... several... a little rattle can and good as used...
  20. Mar 4, 2024 at 6:05 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Ripped up the West in style! Best snow I've skied in 20 years!! Skied the 'ghee and Bernies Bowl...truck was a beast and my legs are toast!! Not Tahoe amounts but 48" of skiable gnar!
  21. Mar 4, 2024 at 6:28 PM
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    What bearing assembly did you order?
  22. Mar 4, 2024 at 6:29 PM
    InfernoBoyz
    Reno, NV
    Finally found a deal on a decked system. Almost too good to be true. Previous owner had it in a shell too so it's mint. Quickly tested in wet conditions and drawers are dry. IMG_3276.jpg
    Also, Seat Jackers. so pumped on these. really fixed my issue with the tundra seats.
  23. Mar 4, 2024 at 6:45 PM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    1.5"
    Feels perfect for my tiny tires.
  24. Mar 4, 2024 at 6:53 PM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    I put in the TRD Pro LED headlights on my 19 SR5, using the iHacker harness.
    Was super easy and looks great. I guess I need to reaim my headlights now.
  25. Mar 4, 2024 at 7:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Been running them for years in the old man’s rig no issues.
  26. Mar 4, 2024 at 7:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Koyo bearing which is the one I’ve seen be the go to.
  27. Mar 4, 2024 at 7:27 PM
    InfernoBoyz
    Reno, NV
    I went with Koyo last year, seem to be holding up good. I was just wondering what other people are running lately. I got mine ebay so hoping they last.
  28. Mar 4, 2024 at 7:36 PM
    InfernoBoyz
    Reno, NV
  29. Mar 4, 2024 at 7:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep same eBay find. They looks stout, if they last with my use case you should be ok lol
    coTony likes this.
  30. Mar 5, 2024 at 9:17 AM
    seydou
    seydou Distinguished Member
    That right there is exactly why I got mine in raw alminum. I am not painting that shit.
    koditten and bulldog93 like this.
