A Few Things Added
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Nov 19, 2023.
  1. Nov 19, 2023 at 9:22 AM
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I took possession of my father in-laws 2016 OR a couple of months ago and I think I'm just about done adding accessories and catching up on the maintenance. The truck only has 20,000 miles on it. Here are some pictures of what I've done.
    Katzkins leather seats
    Leather steering wheel and new shift knob.
    Auto headlights
    Quad fold tonneau cover ($350) and new rubber bed mat ($65)
    Off Road Decal
    New 265/70R18 Michelin Trail tires
    Chrome door handles, mirror caps,new running boards and new 2021 grill.
    Console safe
    Also tinted windows, tail gate lock and ceramic coat.
    I also added LED bulbs throughout, fog light all the time mod, trans service , coolant change and spray in bed liner.
    tinner, Metro14536, Henry1jg and 12 others like this.
  2. Nov 19, 2023 at 10:22 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    You've been buisy......my 19 just turned 22k
    Ruggybuggy[OP] likes this.
  3. Nov 19, 2023 at 8:02 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Sharp looking truck, congrats!
  4. Nov 20, 2023 at 3:04 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nice. How easy was the auto headlight mod. It would be a nice addition for my 17 SR5
  5. Nov 20, 2023 at 3:53 AM
    Bammer
    Monroe, CT
    Very nice Dave.:cheers:
  6. Nov 20, 2023 at 6:05 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not bad. There is a thread on it. Basically you find the body control module which is located under the panel to the left of the steering column. On one of the connectors there is a wire from the fog light relay that is controlled by the BCM. You disconnect that wire and wire it to the wire that goes to you fog light switch which is located in a connector behind the driver side kick panel. The instructions say to use female and male connectors but it's just easier to solder them. I think the connectors are used in case you want to reverse it.
  7. Nov 20, 2023 at 6:15 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Thanks.
  8. Nov 20, 2023 at 6:31 AM
    18" TRD Off Road Wheels
    I thought he asked about the auto headlights? Those tie into fog lights? :confused:
    mustang67408 likes this.
  9. Nov 20, 2023 at 6:33 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My bad. I just woke and I'm half asleep.
  10. Nov 20, 2023 at 6:39 AM
    No worries. I'm tired and going to bed, so I wasn't sure if I wasn't understanding how the auto lights got hooked up or something.
    Hope that sweet truck serves you well for decades to come.
  11. Nov 20, 2023 at 6:39 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry, the auto headlights is also easy to do but does require you remove your air bag, steering wheel and spiral cable (clock spring). You need to buy a new auto headlight switch and install it. Then add the light sensor which is installed next to the speaker in the center of the dash. There is a blank installed which you remove and then install the light sensor. I found a light sensor on AlliExpress.com for about $15. After the new light switch is installed and light sensor the auto feature will work.
    GODZILLA likes this.
  12. Nov 20, 2023 at 6:41 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thanks and I just provided the correct info. :rolleyes:
    GODZILLA[QUOTED] likes this.
  13. Nov 20, 2023 at 7:07 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Haha. No worries, turning the little switch on the end of the stalk seems much easier.
  14. Nov 20, 2023 at 7:17 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    that leather steering wheel cover would be nice but it all looks really good! congrats on the new to you truck.
  15. Nov 20, 2023 at 7:43 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    My Camry that my wife drive my and my previous vehicle have auto headlights. If my wife drives the truck, she is use to having the headlights come on and just doesn't realize they are not on when driving in town because of the street lights.
  16. Nov 20, 2023 at 9:21 AM
    Blue Thunder
    Washington
    Nice work. Great looking truck!
  17. Nov 20, 2023 at 11:05 AM
    DoublePro
    DoublePro New Member
    Nice truck, time to rust proof the underside
  18. Nov 20, 2023 at 11:54 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Already done.
  19. Nov 25, 2023 at 11:04 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
  20. Nov 25, 2023 at 11:08 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    You definitely didn’t waste any time! 20k miles is nothing. My dad gave his 2011 to my brother in law with about 195k. He still has it.
    Henry1jg and Ruggybuggy[OP] like this.
  21. Mar 2, 2024 at 6:21 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just added Toyota power folding mirrors with auto dim and turn signal indicators. Just finishing up the wiring tomorrow and will add some pictures.
    18DCTRD and BoyHowdy like this.
  22. Mar 3, 2024 at 5:06 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Where did you purchase the steering wheel? Or is that just a well done wrap?
  23. Mar 3, 2024 at 5:42 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's a wrap I bought off AliExpress but it's also available on Amazon and Ebay.
    Ace96 likes this.
