Coolant leak around trans heater help!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by pitw18, Mar 2, 2024.
  1. Mar 2, 2024 at 3:14 PM
    pitw18
    pitw18 [OP] New Member
    Hello everyone I have a 2014 toyota tubdra 5.7l 4x4 woth 125k miles and have been loosing coolant since i bought it about 1 gear ago i was doing my oil change when I noticed my trans heater and hoses were covered with coolant and I know its coolant because i checked my coolant reservoir and it was almost empty I am not very mechanical inclined but i rented a pressure test kit from my autoparts store abd raised the psi to 17 and it would start dropping immediately and fast withing 5 minutes it would go to 0psi but i could not find the leak any help would be greatly appreciated.
    Thank youu
  2. Mar 2, 2024 at 3:16 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    most likely the water pump. clean it off a recheck.
  3. Mar 2, 2024 at 3:17 PM
    tufftundy11
    2000 tundra limited
    you need to make sure the radiator is full. you probably lost most of your coolant. just use water for test purposes
  4. Mar 2, 2024 at 3:41 PM
    2mchfun
    Most likely the valley plate is leaking and the coolant is draining down and toward the rear. The valley plate is located under the intake manifold and there's sealing surfaces around the perimeter that are a bit narrow and that's usually the cause of the leak. Just not enough width of seal against the internal hot coolant pressure. You can look around under the intake manifold with a flashlight and small telescopic inspection mirror to confirm. You can also clean off the mess and then watch it form again to see where it originates from. Probably can find a video on YouTube about it. Good luck!
    Johnmatrix, Silver17 and Radarninja like this.
  5. Mar 2, 2024 at 3:50 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I bet that job isn’t a barrel of fun.
    Radarninja and 2mchfun[QUOTED] like this.
  6. Mar 2, 2024 at 5:00 PM
    tufftundy11
    2000 tundra limited
    some say to replace the top plate after removing it too since it can crack from prying it off and you may not be able to tell
  7. Mar 2, 2024 at 5:48 PM
    2mchfun
    True, and as an alternative one can purchase cleaner, dye, and developer to conduct a non destructive dye penetration test to check for cracks as well. Similar cost for a one time job unless it's cracked, one already has the test supplies, or will benefit from the leftover supplies. Probably videos of dye penetrating tests on YouTube also.
  8. Mar 2, 2024 at 6:01 PM
    Radarninja
    Radarninja New Member
    Ca
    I saw this done on a YouTube video and It was jaw droppin how involved this is.
    Took a pro in a full shop, with a lift, 8 hours just to get to it.
    Talk about balls deep!
    ZappBrannigan[QUOTED] likes this.
  9. Mar 4, 2024 at 7:42 AM
    Radarninja
    Ca
    Let us know what you end up with.
    Fingers crossed, hope for the best
    ZappBrannigan likes this.
  10. Mar 4, 2024 at 7:43 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    So it’s like changing a light bulb on a VAG product.
    Sigh: Volkswagen Audi Group. :annoyed:
    hagrid likes this.
  11. Mar 4, 2024 at 7:51 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    They come with their own illumination now? I've been using my trusty carbide lamp on my miner's haymet.
  12. Mar 7, 2024 at 4:53 PM
    clarks
    clarks New Member
    21 Tundra TRD Sport
    This is what happed to me on my 2011. After researching, this can be a common issue.
    2mchfun[QUOTED] likes this.
